Anybody Used The KB Forged Pistons? #818555
09/30/10 07:01 PM
09/30/10 07:01 PM
Oklahoma City
Jwilli500 Offline OP
Oklahoma City
And if so, what was your ipression with them? Fit? Finish? Weight, Etc. The price sure looks good but I never hear anyone mentioning using them. Thanks!
Re: Anybody Used The KB Forged Pistons? [Re: Jwilli500] #818556
09/30/10 07:15 PM
09/30/10 07:15 PM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
I run the keith black forged pistons in my stroker magnum engine...the builder did not say he had any problems with them. Mine sees some hard street miles every year and has been built for about 4-5 years now...probably have 10-15k on it..
Rob Dunn
1976 Dart Sport 360
2000 dakota RT 408 with 150 nitrous
2013 Dodge Ram 1500 Hemi
2009 Jeep Patriot
Re: Anybody Used The KB Forged Pistons? [Re: Jwilli500] #818557
09/30/10 08:49 PM
09/30/10 08:49 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
They seem to have a decent reputation. I picked up a set for a 440 build I'm doing and think they'll do fine for my street / strip application. The valve reliefs are plenty big and the finish machining looks good.
The only thing I wasn't impressed with is that my pistons are quite a bit heavier than advertised. The spec was something like 686 + 141 for the pin and they were actually 703 + 156, IIRC. I wasn't expecting that much extra "beef" compared to the 650-ish gram Rosses my other engine uses.
Re: Anybody Used The KB Forged Pistons? [Re: BradH] #818558
10/01/10 01:53 PM
10/01/10 01:53 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
I built a 440 with them a while back. Real nice looking pistons. No immediate issues with them. About 50 gram heavier than a comparable Ross or Diamond.
I got a smoking deal on them through summit. Like $299 IIRC.
FWIW, I'm almost certain these are the same as 440Source house brand.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Anybody Used The KB Forged Pistons? [Re: 471Magnum] #818559
10/01/10 06:54 PM
10/01/10 06:54 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
ya i have them in my 500" low deck from 440source. they are the pistons that come with their kits so there are lots of people running them.
Re: Anybody Used The KB Forged Pistons? [Re: dirtybee] #818560
10/01/10 11:58 PM
10/01/10 11:58 PM
Oklahoma City
Oklahoma City
Thanks for the replies guys! The weight was a concern, the pistons I am looking at are about 170 grams heavier than the Diamond version!
Re: Anybody Used The KB Forged Pistons? [Re: Jwilli500] #818561
10/02/10 12:08 AM
10/02/10 12:08 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
just make sure that you are comparing the pistons only and the weight of the pin is not included.
Tony
70 AARCuda Vitamin C
Re: Anybody Used The KB Forged Pistons? [Re: 70AARcuda] #818562
10/02/10 12:23 AM
10/02/10 12:23 AM
Stock pins can be shortened 1/4" on each end as w 1.09" dia there is still plenty of contact area (pressed pins of course) to have no prob. And w your drill press & dremel might be able to lighten the piston. This worked fine on a stock cast piston that was raced but they are heavy & have alot of extra material to work w whereas yours may not. Just food for thought
Re: Anybody Used The KB Forged Pistons? [Re: 70AARcuda] #818563
10/03/10 01:50 AM
10/03/10 01:50 AM
Oklahoma City
Oklahoma City
Yeah, that was the first thing I thought too. The KB listing for the IC837 says 709/141 for the Piston/Pin. The Diamond 52407 listing says537 grams. They are both .990 pin pistons. Just seems like a lot of difference, almost 6 1/4 ounces? Also the KB piston online listing mentions a special ring gap for the top ring? I thought that was just on the Hypereutectic pistons...
Re: Anybody Used The KB Forged Pistons? [Re: Jwilli500] #818564
10/03/10 10:50 AM
10/03/10 10:50 AM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
KB specs listed online seem to be a little goofy last time I checked. That note is definitely applicable to the hypers.
Seems they list the same weight for several different pistons regardless of CR and CH. I think they list a standard weight for the basic forging regardless of the finished specs.
-Jim
Re: Anybody Used The KB Forged Pistons? [Re: 471Magnum] #818565
10/03/10 04:27 PM
10/03/10 04:27 PM
Oklahoma City
Oklahoma City
Well the KB's are a "Stepped Dish" piston listed as 12cc? (The Diamond Piston is not stepped and yet it's still 12.5cc?) Must not be much of a step? Yet it is enough to require a bottom ring support...
Re: Anybody Used The KB Forged Pistons? [Re: Jwilli500] #818566
10/04/10 04:09 AM
10/04/10 04:09 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have the KB pistons in my 63's 440 and my sons 400. Been running them and racing with them for years. Ron
Re: Anybody Used The KB Forged Pistons? [Re: 383man] #818567
10/04/10 02:16 PM
10/04/10 02:16 PM
Oklahoma City
Oklahoma City
Are they Domed or Flat-Tops or Dished or Step-Dished?
Re: Anybody Used The KB Forged Pistons? [Re: Jwilli500] #818568
10/04/10 04:32 PM
10/04/10 04:32 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Flat tops with valve reliefs. Ron
