Re: Anybody Used The KB Forged Pistons?
[Re: Jwilli500]
#818556
09/30/10 07:15 PM
09/30/10 07:15 PM
Posts: 377 Michigan Troll
blk00rt
Michigan Troll
I run the keith black forged pistons in my stroker magnum engine...the builder did not say he had any problems with them. Mine sees some hard street miles every year and has been built for about 4-5 years now...probably have 10-15k on it..
Rob Dunn 1976 Dart Sport 360 2000 dakota RT 408 with 150 nitrous 2013 Dodge Ram 1500 Hemi 2009 Jeep Patriot
[Re: BradH]
#818558
10/01/10 01:53 PM
10/01/10 01:53 PM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
I built a 440 with them a while back. Real nice looking pistons. No immediate issues with them. About 50 gram heavier than a comparable Ross or Diamond.
I got a smoking deal on them through summit. Like $299 IIRC.
FWIW, I'm almost certain these are the same as 440Source house brand.
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
[Re: Jwilli500]
#818561
10/02/10 12:08 AM
10/02/10 12:08 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
just make sure that you are comparing the pistons only and the weight of the pin is not included.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#818562
10/02/10 12:23 AM
10/02/10 12:23 AM
RapidRobert
Stock pins can be shortened 1/4" on each end as w 1.09" dia there is still plenty of contact area (pressed pins of course) to have no prob. And w your drill press & dremel might be able to lighten the piston. This worked fine on a stock cast piston that was raced but they are heavy & have alot of extra material to work w whereas yours may not. Just food for thought
[Re: 471Magnum]
#818565
10/03/10 04:27 PM
10/03/10 04:27 PM
Posts: 2,077 Oklahoma City
Jwilli500
Oklahoma City
Well the KB's are a "Stepped Dish" piston listed as 12cc? (The Diamond Piston is not stepped and yet it's still 12.5cc?) Must not be much of a step? Yet it is enough to require a bottom ring support...
[Re: Jwilli500]
#818568
10/04/10 04:32 PM
10/04/10 04:32 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Are they Domed or Flat-Tops or Dished or Step-Dished? ![](/ubbthreads/images/graemlins/grin.gif)
I have the KB pistons in my 63's 440 and my sons 400. Been running them and racing with them for years. Ron
Flat tops with valve reliefs. Ron
