Viper Brake conversion Q's #817654
09/29/10 05:43 PM
09/29/10 05:43 PM
Berwyn, IL
challenger70 Offline OP
Berwyn, IL
I am getting more serious about the upgrade and had a few q's. Is there anywhere I can get just the AR Engineering kit w/ out the rotors, I already have them?
What is a good source for the newer '03+ calipers besides e-bay?
Finally can the rear viper brakes be adapted to an 8.75? I was planning on pbr's for the rear which I think will work but was wondering why the viper backs wouldn't work as well.
Re: Viper Brake conversion Q's [Re: challenger70] #817655
09/29/10 10:32 PM
09/29/10 10:32 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I just have one question, why? There are plenty of current options that fit. And yes I understand Mopar people like to be a little different, but if I could take you down the track in 10s or less in my Cuda and hit the brakes, I guarentee you wouldn't let me without you having your seat belt on!
Heck I went 11.1s at 121mph in a 4010lb Hemi Charger the other week with only drums on it! And then got promptly told if I go 11.0's with only a lap belt, I will asked to leave until there is a bar and a harness in it.....Why Viper brakes?
Re: Viper Brake conversion Q's [Re: challenger70] #817656
09/30/10 02:07 AM
09/30/10 02:07 AM
AndyF Offline
AndyF  Offline
I have a used set of Viper calipers. They only have a few hundred miles of use as well as a few track days. Still in nice shape and the pads are included.
I can sell you a kit without rotors if you want. Are you sure you have a set of the correct rotors? I'm the only person that makes those rotors so you would've had to have gotten them from me or one of my customers.
Re: Viper Brake conversion Q's [Re: Dragula] #817657
09/30/10 07:57 AM
09/30/10 07:57 AM
Montana
FuryUs Offline
FuryUs  Offline
Montana
So are you saying he should get Viper seat belts instead? Why does anyone upgrade any working component on an old car? That hemi isn't stock running 11.1. Why were changes made? Because the owner wanted something different/newer/better/faster/shinier?
Re: Viper Brake conversion Q's [Re: Dragula] #817658
09/30/10 11:25 AM
09/30/10 11:25 AM
Berwyn, IL
Berwyn, IL
If it was a drag car I wouldn't care, but I plan on doing some open track days once I get the Charger together and sorted out, it will have subframe connectors, torque boxes, inner fender braces, XV level 1 suspension and hopefully 4 wheel disks. I would consider the 11.75 cop brake upgrade that I have on my Challenger but those parts are getting harder to locate and since I am starting fresh why not update them? + viper brakes poking out through my chargers wheels would be badass And just because you can run 10-11 second 1/4's w/ drum brakes doesn't mean I want to risk my life in modern traffic with them as I drive my cars alot.
Re: Viper Brake conversion Q's [Re: challenger70] #817659
09/30/10 11:50 AM
09/30/10 11:50 AM
Dragula Offline
Dragula  Offline
The Charger's brakes are stock and it's a street car. It is pretty close to stock, you would be very surprised, we were. Darn hemi's are fast.
I drive mine whenever weather permits, which has been most of this summer. I just think if you don't have the sneakers to go with the brakes, they are overkill and won't stop any sooner, like a cam matched to head flow if the tires don't match the brakes, what's the point.
Re: Viper Brake conversion Q's [Re: Dragula] #817660
09/30/10 03:14 PM
09/30/10 03:14 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I can tell you that I LOVE the big brakes, wheels, and tires on the hot rod. They are amongst the best changes I ever made to the car.
When you lean on the brakes the car stops straight and does so quickly. Wet or dry. Driving through deep water doesn't phase 'em. I've definitely had them way too hot to touch but never felt any fade.
When I had the 11.75" cop car rotors on the car I could brake boost (load the engine against the brakes at speed to build boost) on the highway and push through the brakes. That never happened with the AMG brakes.
I made a shakedown run at the Texas Motorplex. I trapped at 114 mph and was able to make the first tun off with no trouble. That same exit was a little hard to make at 105 mph with the old brakes.
- Stu Harmon
Re: Viper Brake conversion Q's [Re: Dragula] #817661
09/30/10 03:27 PM
09/30/10 03:27 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Ever drive Arizona Rt. 89A - fast? Tail of the Dragon? Mulholland Drive? Storm King Mountain? Sure, drums or small rotors stop great once -- but don't try it several times in short order. This is why NASCAR racers get away with smaller brakes on superspeedways!
Also, good luck threshhold braking with Bendix Duo-Servos in poor traction or split Mu conditions. They have 2 positions, like a light switch. (The old Total Contact brakes were far superior in that regard).
And, I wish you the best should you need to get on the brakes in a curve.
Harness? heck, if you never crash, it is just dead weight. I drive great, so do you. But how about the drunk coming at you?
Just my 2¢....
Rick
Re: Viper Brake conversion Q's [Re: Rick_Ehrenberg] #817662
09/30/10 03:33 PM
09/30/10 03:33 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Rick, I'd love to run those roads. Unfortunately, they're a wee bit of a drive from DFW.
The hot rod is also going away and it's Imperial replacement will require a bit more work to handle well. Throwing 5100 lbs around those curves is going to be living on the edge even with some updates.
- Stu Harmon
Re: Viper Brake conversion Q's [Re: challenger70] #817663
09/30/10 04:07 PM
09/30/10 04:07 PM
AndyF Offline
AndyF  Offline
If you're going to be running track days with a big B body car then stepping up to a 13 inch kit is smart. You'll have better choices with 17 inch rims and the bigger rotors will work better than the 11.75 inch stuff.
DoctorDiff sells a 14 inch brake kit using new Charger rotors and Viper calipers if you're willing to run 18 inch rims. I'll send you a PM with info on the used Viper calipers that I have for sale.
I'd recommend a rear disc kit from DoctorDiff rather than trying to use the Viper setup out back. The Viper uses two calipers per wheel in the rear which requires double fabrication. Also, the Viper bolt pattern is 6x4.50 so the stock rotors don't fit on a 8.75 rearend. By the time you fabricate the custom mounts and get new rotors built you'll have a bunch of money invested.
Re: Viper Brake conversion Q's [Re: feets] #817664
09/30/10 04:48 PM
09/30/10 04:48 PM
Marlboro, NY, USA
Marlboro, NY, USA
What year Imp? I have always been amazed how well the '60s Imps handle. Very stiff platform, body-on-frame with NO RUBBER, bolted solidly. Also a pair of trailing arms plus the leafs.
Get FFI to carve you out a pair of wrist-size swaybars, get some 9" or 10" wheels and decent rubber, and go blow some minds!
Rick
Re: Viper Brake conversion Q's [Re: AndyF] #817665
09/30/10 05:11 PM
09/30/10 05:11 PM
Berwyn, IL
Berwyn, IL
I wouldn't be opposed to 18's but I have a buddy w/ extra mustang bullit wheels (17") that work with the viper conversion(right?) so I can save some coin there. I could see upgrading to 18's down the road but I think for what I will be doing(rare track day and "enthousiastic" street driving 13" rotors will be fine.
Ok so critique my plan.
This will be for a '68 Charger, 4 speed Manual brakes and would like to completely replace the 4 wheel manual drum setup on the car.
I was planning on using rotors and wheels I got from my buddy that had an '04 Cobra and was hoping to duplicate the setup on that car but upgrade to the Brembo Viper calipers up front. I guess the rotors won't work so I'd be looking at the full Viper kit from AR engineering up front, I have a set of '73-76 A-body spindles already. For the rear I was planning on PBR calipers assuming they can work with the 8.75 and have a parking brake. Do I need custom rotors for the rear too? Master cylinder recomendations (I'd like to keep it manual brakes).
Who makes the "custom" front rotors for the viper coversion? Brembo? I guess I am concerned about part availability in the future as opposed to an off the shelf part.
Re: Viper Brake conversion Q's [Re: challenger70] #817666
09/30/10 05:21 PM
09/30/10 05:21 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
You could always make your own caliper brackets. Once you have some hubs, just get the rotors on them and make up brackets to hang the calipers from there.
I did it, and went quite well. I used Mercedes rotors (just over 14") and Brembo calipers.
I would have liked to use the 8 piston AMG ones like Feets has but they were abit pricey and I did get a great deal on the Brembos.
Re: Viper Brake conversion Q's [Re: OzHemi] #817667
09/30/10 05:22 PM
09/30/10 05:22 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Bracket I made from 5/8" thick steel.
Re: Viper Brake conversion Q's [Re: challenger70] #817668
10/01/10 03:22 AM
10/01/10 03:22 AM
AndyF Offline
AndyF  Offline
Here is a picture of the Viper calipers that you were asking about.
Re: Viper Brake conversion Q's [Re: challenger70] #817669
10/01/10 03:26 AM
10/01/10 03:26 AM
AndyF Offline
AndyF  Offline
Yes, the Mustang wheels fit my brake kit. Here are a couple of cars with my 13 inch brake kits installed. Both have Mustang rims.
Re: Viper Brake conversion Q's [Re: AndyF] #817670
10/03/10 05:06 PM
10/03/10 05:06 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
What year are they from, and are they front or rear Viper calipers? Do you know if they would fit with 15" rims?
Thanks Brad
Re: Viper Brake conversion Q's [Re: brads70] #817671
10/03/10 05:36 PM
10/03/10 05:36 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Andy's Viper caliper kit on stock rotors will fit a 15" wheel.
The Viper caliper kit on 13" rotors will fit 17" wheels.
Both kits use front calipers.
http://www.arengineering.com/caliper_menu/calipermenu.html
- Stu Harmon
Re: Viper Brake conversion Q's [Re: feets] #817672
10/04/10 03:06 AM
10/04/10 03:06 AM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Not true. They may fit SOME 15" wheels, probably all steel wheels, but not all aluminum/alloy wheels.
I have the kit on my RR, and the 15x8 AR 200S wheels (from the 80s) (3-3/4" BS) rub slightly on the calipers. Not enough to prevent me from moving the car around the garage, but certainly enough to prevent driving it. New wheels/tires (17") are on the list.
Re: Viper Brake conversion Q's [Re: MoparMarq] #817673
10/04/10 11:06 AM
10/04/10 11:06 AM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
I think drop center type 15" wheels like rallyes will not fit.
