1969 GTX broadcast sheet help #817231
09/29/10 02:47 AM
09/29/10 02:47 AM
New Berlin,Wi
Firepowerflyer Offline OP
New Berlin,Wi
I have a couple of questions on my 69 gtx build sheet.Under the radio section it's marked 31 with a 1 below it,can anyone tell me if the car is suppose to have rear speakers?Also under heavy duty-fleet secton,for the battery it's marked 25 would that be a group 27 or does it mean something else?I have one more I assumed that it being a ac car that it would have the clutch fan but after looking at my broadcast sheet nothing is checked for the fan?Did it have a standard fix blade fan?Sorry for all the questions just getting down to the final details and trying to figure it out correctly.
Thanks Joe
Re: 1969 GTX broadcast sheet help [Re: Firepowerflyer] #817232
09/29/10 02:55 AM
09/29/10 02:55 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
R31 in 69 is single rear seat speaker
F25 is a Group 27 with Red caps
Re: 1969 GTX broadcast sheet help [Re: 1_WILD_RT] #817233
09/29/10 03:00 AM
09/29/10 03:00 AM
New Berlin,Wi
New Berlin,Wi
Ok thank you,so the speaker attaches to the middle of the seat,was there a switch on the dash or was it controlled internally in the radio?Is there a wiring harness avalible for that option?
Thanks Again
Joe
Re: 1969 GTX broadcast sheet help [Re: Firepowerflyer] #817234
09/29/10 03:56 AM
09/29/10 03:56 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
The single rear speaker goes in the drivers side speaker hole. The package shelf is perforated on each side like for 2 speakers, but the passenger side is for the rear defroster air intake, if equipped. There is an underdash fader switch and wiring for this speaker. The wiring runs down the left side with the taillight wiring.
Re: 1969 GTX broadcast sheet help [Re: Firepowerflyer] #817235
09/29/10 05:29 AM
09/29/10 05:29 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
as far as the battery - on line 3 under BAT you should have 69 for part #2642 969 (group 27)
Also line 3 under FAN = 16 - part #2863 216 - 7-blade for clutch
again line 3 under FAN SPAC = 56 - part #2658 456 - thermal clutch
Re: 1969 GTX broadcast sheet help [Re: 6bblgt] #817236
09/29/10 10:27 AM
09/29/10 10:27 AM
New Berlin,Wi
New Berlin,Wi
OK this helps It does have a 56 under fan spac.Under the battery listing on line 3 it has a 69,does that equate to a group 27?
Joe
Re: 1969 GTX broadcast sheet help [Re: Firepowerflyer] #817237
09/29/10 12:14 PM
09/29/10 12:14 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Joe
Yes Joe - a group 27 with red caps
