1969 GTX broadcast sheet help
#817231
09/29/10 02:47 AM
09/29/10 02:47 AM
Posts: 178 New Berlin,Wi
Firepowerflyer
New Berlin,Wi
I have a couple of questions on my 69 gtx build sheet.Under the radio section it's marked 31 with a 1 below it,can anyone tell me if the car is suppose to have rear speakers?Also under heavy duty-fleet secton,for the battery it's marked 25 would that be a group 27 or does it mean something else?I have one more I assumed that it being a ac car that it would have the clutch fan but after looking at my broadcast sheet nothing is checked for the fan?Did it have a standard fix blade fan?Sorry for all the questions just getting down to the final details and trying to figure it out correctly. Thanks Joe
Re: 1969 GTX broadcast sheet help
[Re: Firepowerflyer]
#817235
09/29/10 05:29 AM
09/29/10 05:29 AM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
as far as the battery - on line 3 under BAT you should have 69 for part #2642 9 69 (group 27) Also line 3 under FAN = 16 - part #2863 2 16 - 7-blade for clutch again line 3 under FAN SPAC = 56 - part #2658 4 56 - thermal clutch
#817237
09/29/10 12:14 PM
09/29/10 12:14 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
OK this helps It does have a 56 under fan spac.Under the battery listing on line 3 it has a 69,does that equate to a group 27? Thanks Joe
Yes Joe - a group 27 with red caps
