Re: Check under your MSD distributor cap now!
[Re: scottydog]
#817019
09/28/10 11:29 PM
09/28/10 11:29 PM
Posts: 315 Russiaville, IN
mopar376d
Russiaville, IN
Just put a MSD in my car I had laying around. Rust like you said. Read the post on here from a while back. Cleaned it with emry cloth and used WD 40. Working good.
Bought a extra pickup just in case.
Why does divorce cost so much?
Because it is worth it!!!!!
[Re: thehemikid]
#817021
09/29/10 03:17 AM
09/29/10 03:17 AM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
This is a good reminder. I read a post about this a while back. When I bought one, I sprayed the inside with Zep45- a commercial grade WD-40 like spray. It hasn't rusted a bit in 2 years. My buddies, on the other hand, was starting to rust pretty good when we had it opened up to shorten his advance curve so he could run more initial timing.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: Scamp408]
#817024
09/29/10 08:37 PM
09/29/10 08:37 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
Cap after cap that racers took off at the CC at Norwalk, were rusty..
EDIT>. Not the cap. the reluctor and misc. parts under there.. I heard that their terminals are aluminum with brass coating.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
[Re: joedust451]
#817026
09/29/10 09:07 PM
09/29/10 09:07 PM
Posts: 4,247 Newfoundland
codfish
Newfoundland
I too live where there is high humidity, but no rust under mine. I did drill a couple of 1/8 holes in my MSD cap when I put it all together two years ago. Had the cap off last week, and it still looks good. codfish
[Re: nss guy]
#817028
09/29/10 10:17 PM
09/29/10 10:17 PM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
Not just rust on the cap but the reluctor and pickup also. The Firecore Dist. doesn't seem to have these issues
Which one is the "Firecore"?
