Using tubes in Hoosier DOT quicktime tires #815972
09/27/10 04:27 PM
09/27/10 04:27 PM
Santa Barbara, CA
HitIt Offline OP
HitIt  Offline OP
Santa Barbara, CA
Anybody run these without tubes?
Is using tubes in these tires is absolutely necessary? I have heard some people run them without tubes if they are not using rim screws.
Thanks.
very clever dinner. appetizing food fit neatly into interesting round pie.
Re: Using tubes in Hoosier DOT quicktime tires [Re: HitIt] #815973
09/27/10 04:30 PM
09/27/10 04:30 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I ran wheel screws and tubes in mine and liked that way to do it. Never ran without tubes, but i dont see why you couldnt. It just nade the tire a little stiffer.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Using tubes in Hoosier DOT quicktime tires [Re: HitIt] #815974
09/27/10 04:52 PM
09/27/10 04:52 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I ran QT Pros w/ screws and w/o tubes using the old "coat the inside w/ dishwashing liquid" trick. The sidewalls seemed pretty stiff compared to the M/T slicks I had at the time.
EDIT: I don't know if the standard Quick Time tires have the same stiff sidewall as the QT Pros do. I don't think I'd run the regular Quick Times w/o tubes.
Re: Using tubes in Hoosier DOT quicktime tires [Re: BradH] #815975
09/27/10 04:54 PM
09/27/10 04:54 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Ive ran my 28x11.5 QTP's with NO tubes for several yrs now. over the winter and sitting a long time,sometimes they would go flat but once I drive them around,there fine.
Re: Using tubes in Hoosier DOT quicktime tires [Re: HitIt] #815976
09/27/10 05:00 PM
09/27/10 05:00 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...I ran the Quick Time "Pro's" (Cheater slick)33x22.5 with no tubes on the street till the threads showed. Then put on the Quick Time (more tread) 33x22.5 with no tubes for the remainder of the 6 yrs it was on the street. To run them with out tubes & not having them slowly leak down, spread some (I think its ivory) dish washing liquid liberally,over the complete inside of the tire, & they will hold air well. That will give you less rotating weight for ET's at the strip also. There's a lot of weight in those BIG tubes. Just my opinion.
...EDIT: with screw's
Re: Using tubes in Hoosier DOT quicktime tires [Re: B3422W5] #815977
09/27/10 05:17 PM
09/27/10 05:17 PM
Az
Crizila Offline
Crizila  Offline
Az
Thats how I run mine also. The best foot print with tubes seems to be around 14psi.
Fastest 300
Re: Using tubes in Hoosier DOT quicktime tires [Re: Crizila] #815978
09/27/10 06:53 PM
09/27/10 06:53 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
i run QTPs without tubes...the local Hoosier dealer says that they aren't really needed
Re: Using tubes in Hoosier DOT quicktime tires [Re: Crizila] #815979
09/27/10 07:08 PM
09/27/10 07:08 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Yep, ran mine at 13.5 to 14 all the time.
1.41 best 60 foot
6.56 at 104.17
Re: Using tubes in Hoosier DOT quicktime tires [Re: B3422W5] #815980
09/27/10 07:33 PM
09/27/10 07:33 PM
Santa Barbara, CA
HitIt Offline OP
HitIt  Offline OP
Santa Barbara, CA
Interesting, thanks very much guys. This is a street car and now I'm leaning towards no tubes.
Re: Using tubes in Hoosier DOT quicktime tires [Re: HitIt] #815981
09/27/10 08:30 PM
09/27/10 08:30 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...What size are you planning on using. The taller the tire the more left to right movement of the wheel in the tire. An odd feeling the first time you notice it like on a highway with wagon track's from the heavy coal trucks. The lower the air pressure the worse it is.
Re: Using tubes in Hoosier DOT quicktime tires [Re: thehemikid] #815982
09/27/10 10:42 PM
09/27/10 10:42 PM
sycamore,ohio
BobsProFab Offline
BobsProFab  Offline
sycamore,ohio
i ran mine with no tubes @ 13 to 14 psi
29 x 14.50 on 12 inch wheels
never had a problem leaking air on them
as you can see in my sig pic they hooked pretty good on the track and not bad on the street
Re: Using tubes in Hoosier DOT quicktime tires [Re: BobsProFab] #815983
09/28/10 11:31 AM
09/28/10 11:31 AM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I am running 28x14.50 quick time pro's and Hoosier told me to coat them with joy dish soap. They said something about whats in joy brand specific that works very well to keep them holding air. I dont have any screws in mine. I have been running about 13-14 p.s.i. in them and last time I ran I marked the stems and ran it one pass and it looks like the marks are off about 1"-2" . Is it possible the tires turned on the rims? I asked someone at the track and they said if they turn on the rims they normally break the beads.???? Been on there for 6 months and seem to hold air real good.
67' charger 499 RB 10.57 at 127
Re: Using tubes in Hoosier DOT quicktime tires [Re: dragram440] #815984
09/28/10 05:48 PM
09/28/10 05:48 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
I had the same size tire with screws and never lost any air. I did pour the dish soap in and moved it around. When the soap collected in the bottom of the tire, I would rotate the tire and move the soap around some more. I repeated this until the soap was fully absorbed. I don't remember what brand dish soap I used.
Drove around many years with those tires until they were bald.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Using tubes in Hoosier DOT quicktime tires [Re: HitIt] #815985
09/28/10 05:50 PM
09/28/10 05:50 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
No tubes and no problems w/em leaking w/rim screws. Mine are 29x13.5x15`s.
