'75 Big block I.D.- 440 or 400? #814476
09/25/10 11:36 PM
09/25/10 11:36 PM
Milwaukee, WI
In_The_Pink Offline OP
Milwaukee, WI
Can anyone I.D. this circa-'75 big block as either a 440 or 400?
Re: '75 Big block I.D.- 440 or 400? [Re: In_The_Pink] #814477
09/26/10 12:18 AM
09/26/10 12:18 AM
Doo-Dah, KS
440fied Offline
440fied  Offline
Doo-Dah, KS
Looks like a 440. See if you can have the owner check under that a/c bracket for the machined pad. Most full size Winnebago's that I've seen, like that one, had the RB motor.
Re: '75 Big block I.D.- 440 or 400? [Re: 440fied] #814478
09/26/10 01:41 AM
09/26/10 01:41 AM
Milwaukee, WI
Milwaukee, WI
Thanks, will do. Will it be stamped "440" in that location?
Re: '75 Big block I.D.- 440 or 400? [Re: In_The_Pink] #814479
09/26/10 02:38 AM
09/26/10 02:38 AM
gtx69 Offline
super gas
gtx69  Offline
super gas
What is the casting numbers on the side of the block?
Re: '75 Big block I.D.- 440 or 400? [Re: gtx69] #814480
09/26/10 02:47 AM
09/26/10 02:47 AM
Milwaukee, WI
Milwaukee, WI
No clue, as I really didn't want to climb under this motorhome.
I was just hoping there was a "a 440 has the #3 intake runner straight and a 400 has it curved" type easy to I.D. difference since I know little about big blocks.
Re: '75 Big block I.D.- 440 or 400? [Re: In_The_Pink] #814481
09/26/10 02:56 AM
09/26/10 02:56 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Easy...if you look under that bracket, a 440 will have a raised pad area, and a 400 will not..
383/400
413/440..
The raised pad area is right under the bracket in your pic, and just in front of the intake sealing rail basically..(left side of pic in the 2 pics above)
Re: '75 Big block I.D.- 440 or 400? [Re: OzHemi] #814482
09/26/10 03:00 AM
09/26/10 03:00 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Re: '75 Big block I.D.- 440 or 400? [Re: OzHemi] #814483
09/26/10 03:27 AM
09/26/10 03:27 AM
Milwaukee, WI
Milwaukee, WI
Gracias.
Re: '75 Big block I.D.- 440 or 400? [Re: In_The_Pink] #814484
09/26/10 01:13 PM
09/26/10 01:13 PM
Doo-Dah, KS
440fied Offline
440fied  Offline
Doo-Dah, KS
Yes, it should be stamped 440 or even 413.
