Re: !!!!!!!!Need help wiring up a 2-Step for a 4 speed!!!!!
[Re: NoJoke]
#812637
09/23/10 02:52 PM
09/23/10 02:52 PM
Posts: 12,339 somwhere
smokinwoody
somwhere
[Re: theclutcher]
#812643
09/23/10 06:38 PM
09/23/10 06:38 PM
Posts: 10,043 MN
JERICOGTX
MN
I have my 2 step wired so it can only work when the clutch pedal is pushed in, AND the line lock button is pushed in. If I release either one, it comes off the 2 step. Having it just with your line lock will not give you enough RPM in the burnout box, and it's hard to release the button consistantly with the line lock button, and be ready to pull 2nd gear right away. Also it will not stutter while using the clutch down track.
Jeff
69 GTX
68 Road Runner
[Re: JERICOGTX]
#812645
09/23/10 06:53 PM
09/23/10 06:53 PM
Posts: 641 Bergen County NJ
NoJoke
Bergen County NJ
Jeff
The way you have yours set up sounds like the way to go.. I will have to get some kind or diagram to wire this up..
[Re: NoJoke]
#812646
09/23/10 07:09 PM
09/23/10 07:09 PM
Posts: 2,172 Ohio
theclutcher
Ohio
I always had trouble releasing the button consistantly with it tied to lineloc. Once talking to John Calvert, he said he has his switch mounted somewhere just in reach of finger while in first gear. I ended up welding bracket to shifter mount, put switch on it. Much easier to let off switch while closing grip rather than trying to release grip. Worked for me.
[Re: theclutcher]
#812647
09/23/10 07:33 PM
09/23/10 07:33 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
I run 2 switches in series with one on the clutch pedal stop and the other on the trans so the first gear lever closes it.That way the only time the 2-step is engaged is when the pedal is on the stop and the trans is in first gear. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#812648
09/23/10 07:57 PM
09/23/10 07:57 PM
Posts: 7,496 Minnesota
Hemi_Joel
Minnesota
I use the latching relay circuit that is shown on figure 2 of page 2 in the MSD link that Fred refers to above. With that circuit, everything works off the clutch pedal switch at launch; you don't need to release any other switch when you launch, and it does NOT activate your launch rev limiter when you jab the clutch to shift. I set the clutch pedal switch to a point where it does not trigger untill the pedal is almost fully released. That way I can pre-stage, push in the clutch to stop in the 1st beam, hit the momentary switch to arm the latching relay, feather the clutch a little to move the car forward and stage (without tripping the clutch pedal switch and de-activating the two-step), then launch by dumping the clutch peadl, which hits the switch and deactivates the 2 step. I don't use a line lock yet, but if I did, it would also deactivate by the same switch. [show off] here's an in car video where you can see how slick it works, right at 1:45 where if flip the activator for the latching relay on and off then go: http://www.youtube.com/watch?v=nKfPiVjUdjU [/show off]
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: JERICOGTX]
#812649
09/24/10 08:54 AM
09/24/10 08:54 AM
Posts: 726 ohio
mike67net
mopar addict
mopar addict
ohio
Jeff
That's how I have mine. I put a "normally closed" switch at the top of the clutch pedal so it will break the circut for the 2-step and the line lock when the clutch is all the way out. Just in case I forget to let go of the button when I launch the car
I believe the switch was a Chevy brake light switch.
