Tranz brake ? #810485
09/21/10 03:40 PM
09/21/10 03:40 PM
CHANDLER, AZ
512 VALIANT Offline OP
CHANDLER, AZ
I have Hughes trans w/ trans brake. After installing trans I have all forward gears, but no reverse. I called Hughes as they are local and he said I needed to have my trans brake hooked up in order to get reverse. Also they stated when I am in nuetral or reverse I need to activate the trans brake to attain reverse. I guess my question is that I have never had a trans brake before and is this normal. I guess then I actually have 2 question, because I need to hook up the brake to the 2 step. So how do you recommend doing that?
Re: Tranz brake ? [Re: 512 VALIANT] #810486
09/21/10 03:49 PM
09/21/10 03:49 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Normal? Not sure how many are designed this way, but definately some are. I have to push the transbrake button while in reverse to actually engage reverse.
Re: Tranz brake ? [Re: TheOtherDodge] #810487
09/21/10 03:58 PM
09/21/10 03:58 PM
Chicago,Illinois
N
nosboy Offline
nosboy  Offline
N
Chicago,Illinois
With MY trans brake, you can get reverse by shifting into NEUTRAL or REVERSE and holding the button.. No button,, no reverse.. Perfectly normal....
Re: Tranz brake ? [Re: nosboy] #810488
09/21/10 04:00 PM
09/21/10 04:00 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Same deal for me with my glide
Re: Tranz brake ? [Re: B1KILLER] #810489
09/21/10 04:05 PM
09/21/10 04:05 PM
CHANDLER, AZ
CHANDLER, AZ
Thanks, I never ran 1 before. How did you guys "wire it in" to the 2step and rev limiter so you can launch and it automatically triggers your high rpm on the 2step when you release the button?
Re: Tranz brake ? [Re: 512 VALIANT] #810490
09/21/10 04:06 PM
09/21/10 04:06 PM
an8sec70cuda Offline
For some transbrakes that's normal, for some it isn't. My T/A pro brake does not need the button pressed for reverse.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Tranz brake ? [Re: an8sec70cuda] #810491
09/21/10 04:52 PM
09/21/10 04:52 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Go to MSDIGNITION.COM
I think you will find a simple diagram there. The two step rev limiter activate wire will hook directly to the positive side of your transbrake. When activated it tells the two step to select it's second rev limiter. The low side.
