Exhaust / Mufflers ?? Too Loud #809151
09/20/10 12:20 PM
09/20/10 12:20 PM
South Shore MA
67GTMIKE Offline OP
67GTMIKE  Offline OP
South Shore MA
I have a high compression large cam big block running thru 3" headers and I am looking for mufflers that will quiet the car down yet still have a nice tone. I am tired off loud exhaust.
Any recommendations?
Re: Exhaust / Mufflers ?? Too Loud [Re: 67GTMIKE] #809152
09/20/10 12:25 PM
09/20/10 12:25 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Dynomax superturbo
Re: Exhaust / Mufflers ?? Too Loud [Re: 67GTMIKE] #809153
09/20/10 12:25 PM
09/20/10 12:25 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I had hooker super comp mufflers on my old 67 coronet. They were great. decent soft sound at cruise and nice and rumbly at WOT.
Coming soon!!!!
Re: Exhaust / Mufflers ?? Too Loud [Re: Mr.Yuck] #809154
09/20/10 01:09 PM
09/20/10 01:09 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
dynomax pn 17768 or 17769 depending on inlet/outlet config...
I'd also look at the new dynomax VT's...
the bigger the case, the better the chance of noise attenuation...if a straight through design, look at some of the BIG magnaflows (the 5x12x20" or 5x8x22" cases)
2017 Grand Cherokee Overland
Re: Exhaust / Mufflers ?? Too Loud [Re: patrick] #809155
09/20/10 01:37 PM
09/20/10 01:37 PM
South Shore MA
67GTMIKE Offline OP
67GTMIKE  Offline OP
South Shore MA
Thanks guys.. I will look into these.
Re: Exhaust / Mufflers ?? Too Loud [Re: 67GTMIKE] #809156
09/20/10 01:44 PM
09/20/10 01:44 PM
Assuming you're all together & just want to change to (quieter) muffs but I'd suggest adding an X pipe, resonator muffs in the very rear by the leafs (glasspacks w no neckdown where the nipples are welded to the body/louvers punched toward the outside) dyno max muffs as said and one guy who understood accoustics welded horizontle exhaust pipe a foot or so long & capped on the end welded on each bend out sideways as it went over the axle (one to the left and 1 to the right) & said it made a heck of a difference. sounds strange but evidently it cancels sound waves. I would maintain your mandrel bends throughout.
Re: Exhaust / Mufflers ?? Too Loud [Re: RapidRobert] #809157
09/20/10 05:11 PM
09/20/10 05:11 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
if it is already together, a first test would be to put some glasspacks in the tailpipes as resonators...that alone might quiet it down to meet your needs.
Re: Exhaust / Mufflers ?? Too Loud [Re: 67GTMIKE] #809158
09/20/10 07:31 PM
09/20/10 07:31 PM
MO, USA
Tom Hand Offline
Tom Hand  Offline
MO, USA
http://www.youtube.com/profile?user=VOETOM
Mike, listen to Dad's wagon run. He runs 5" by 11" by 22" Goerlich 3" XLERATORS with a true Dr. Gas X-crossover in this video. Very similar sound to the large Magnaflows mentioned above.
We also are running some VTs on a couple of other cars you need to wait a tad longer while they get some more suited to thumping 3" equipped engines.
Tom
Re: Exhaust / Mufflers ?? Too Loud [Re: Tom Hand] #809159
09/20/10 08:07 PM
09/20/10 08:07 PM
South Shore MA
67GTMIKE Offline OP
67GTMIKE  Offline OP
South Shore MA
Thanks guys.. I guess I should be more detailed:
Currently has headers out to Bullets out to a slight bend. It is not a full exhaust and I do not think I will be able to run a full exhaust.
So I am thinking off the headers to some electric cutouts to muffs then dump out in front of rear tires.
Looking to see what my best bet for muffs are to get a respectable street tone with out it being too loud.
Re: Exhaust / Mufflers ?? Too Loud [Re: 67GTMIKE] #809160
09/21/10 09:18 AM
09/21/10 09:18 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
TTI's followed by QTP's followed by Dynomax Super Turbos on the 440 are the best of both.
Re: Exhaust / Mufflers ?? Too Loud [Re: 67GTMIKE] #809161
09/21/10 09:22 AM
09/21/10 09:22 AM
VA
DAMOPARS Offline
DAMOPARS  Offline
VA
Quiet not but an X pipe will help.
Re: Exhaust / Mufflers ?? Too Loud [Re: 67GTMIKE] #809162
09/21/10 11:22 AM
09/21/10 11:22 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
it'll never be quiet dumping before the axle....
Re: Exhaust / Mufflers ?? Too Loud [Re: patrick] #809163
09/21/10 11:36 AM
09/21/10 11:36 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
ditto. I bought a 67 GTX w/ mani's 2.5 X-pipe and BIG factory mufflers...no tail pipes and it sounded awful. You need tail pipes to get the job done. They do more than you think. If you don't run tail pipes do not dump the exhaust towards the ground, either direct it out towards the sides or towards each other.
Coming soon!!!!
Re: Exhaust / Mufflers ?? Too Loud [Re: 67GTMIKE] #809164
09/21/10 02:59 PM
09/21/10 02:59 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
I had 2 ich hookers into 3 inch exhaust,turned down at the rear axel...with series 40 flowmasters. I could idle through downtown lockport NY and set off all the car alarms...I then extended the exhaust with 2 1/2 inch pipe to the rear bumper and it sort of "neutered" the sound but alot of My mopar buds say that's how a mopar should sound..IF...I build another car...I'm going to keep the original configuration as I like it loud...even at 60 years old....lol
Mine also has an "H" pipe
Re: Exhaust / Mufflers ?? Too Loud [Re: patrick] #809165
09/21/10 04:20 PM
09/21/10 04:20 PM
South Shore MA
67GTMIKE Offline OP
67GTMIKE  Offline OP
South Shore MA
Well I hope your wrong because I really don't think I can get it out the back...
Looking more like out before the rear tires is my best bet.
As for muffs- sounds like more people saying to use the Dynomax super Turbos
One guy PM'd and says he used Flowmaster Delta flow and they quieted it down bigtime over the 40 and 44 series
Re: Exhaust / Mufflers ?? Too Loud [Re: 67GTMIKE] #809166
09/21/10 04:33 PM
09/21/10 04:33 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I was worried about the exhaust being too loud on my car too, as I had to dump before the axle as well. Not as much engine as you, but I went with a full 2.5" system I made up from scratch pretty much using an X pipe and Spintech side exit mufflers. I am still making the tips for it (which will be angled back and end right under the sill infront of the rear) but here is how they sound..
http://www.youtube.com/watch?v=CK6qKTXjJKM
As well, I mocked up a tip on one side and it makes a very noticable difference with about 10" of tubing out of the muffler. This is inside the garage too...with it outside, you can hear it enough, but not too loud at all I think.
Here it is with the mounts all done and painted by the way...
Re: Exhaust / Mufflers ?? Too Loud [Re: 67GTMIKE] #809167
09/21/10 05:10 PM
09/21/10 05:10 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
On My 69 Bee I have a TTI system from stock hi po exhaust manifolds back. It's 2 1/2 all the way with TTI mufflers.(H pipe) Not much sound until the 6 pak opens up. The system fit perfect out of the box...but then I had no money left . TTI IS expensive but is nice.
