Page 1 of 5 1 2 3 4 5
Passon 5 Speed #802899
09/16/10 11:10 AM
09/16/10 11:10 AM
Sugarloaf, PA. USA
JamiePasson Offline OP
Sugarloaf, PA. USA
Forgive my absence on the board here lately. I have been buried trying to stay on top of things. I just checked some posts and people were asking about progress on the 5 speed trans.
Well let me assure you that we ARE making progress on it. It has been slower than we wanted. Keep in mind, we started with a clean sheet of paper here. We are a small company and things take time.
This is why my intention from the beginning was not to mention anything until we were closer to production. However, the McLeod M800 thing kinda threw a wrench in that and I felt that I had better mention that we were working on a project so that people knew that another option was coming.
Regardless, in the spring, we had several casting changes to make. These have been made and we are working on the gear interlock mechanism now. We are currently waiting on the shift forks and parts for the interlock mechanism.
We had hoped to have a display piece for the Mopar Nationals, but vendor time frames kept us from accomplishing that.
Yes, this is taking longer than I originally thought. There have been plenty of hiccups along the way. However, due to the fact that there will be no mods needed to install it like some of the other options out there. It is truly an afternoon swap if your car is currently a 4 speed.
I am cleaning out my PM mailbox as soon as I post this. Feel free to contact me with any questions, OR you can always call or e-mail.
Thanks,
Jamie
Passon Performance 309 Turkey Path Sugarloaf, PA 18249 (570) 401 8949 www.passonperformance.com
Re: Passon 5 Speed [Re: JamiePasson] #802900
09/16/10 01:03 PM
09/16/10 01:03 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
That good to hear Jamie,...I'd be interested in seeing what you've come up with,....any estimates on weight, just the transmission, and finial OD ratios available?...I'm curious are I'm sure others are
Mike
Re: Passon 5 Speed [Re: DAYCLONA] #802901
09/16/10 01:57 PM
09/16/10 01:57 PM
Sugarloaf, PA. USA
Sugarloaf, PA. USA
At this point, .70:1 is final drive. I don't really want to comment on a weight estimate yet.
Re: Passon 5 Speed [Re: JamiePasson] #802902
09/16/10 02:02 PM
09/16/10 02:02 PM
Canada
Ghoste Offline
Ghoste  Offline
Canada
Still nice to know you are making progress. Looking forward to the final announcement.
I see a light at the end of the tunnel, and it's... ELECTROLUMINESCENT!
Re: Passon 5 Speed [Re: JamiePasson] #802903
09/16/10 02:11 PM
09/16/10 02:11 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Test cars needed???????
Re: Passon 5 Speed [Re: Commando1] #802904
09/16/10 02:19 PM
09/16/10 02:19 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Hmmmmmm,...I got a nice T/A with a stroked small block 443 dynoed horsepower 6 pack, currently chrysler 4 spd with a 2800 lb 11" clutch, if you need someone to thrash one of your test units......I'd have no problem with that
Mike
Re: Passon 5 Speed [Re: DAYCLONA] #802905
09/16/10 02:25 PM
09/16/10 02:25 PM
Saline, MI
E
efisixpack Offline
efisixpack  Offline
E
Saline, MI
What do you estimate the torque capacity to be? I'm definately interested if it can handle decent power and truely is a bolt-in kit. I've put 5000 miles on my 71 demon this summer and the 4-spped is killing me on the highway with just a 3.55 gear. Pleas e keep us updated as time/progress allows.
When I die I want to go like my Grandfather did, quietly in his sleep. Not screaming like the passengers in his car.
Re: Passon 5 Speed [Re: efisixpack] #802906
09/16/10 03:11 PM
09/16/10 03:11 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I see this seems to be more street orientated trans but, forgive me for not looking up the older post, can this thing be used street/strip with slicks and a big block? Just curious on what rating you will be giving it and what kind of car its aimed at. Seems to be lots of choices in the lower hp areana, but less when you build a big block.
Re: Passon 5 Speed [Re: Dragula] #802907
09/16/10 04:05 PM
09/16/10 04:05 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Will stock sb/bb clutch work?
Re: Passon 5 Speed [Re: Dragula] #802908
09/16/10 04:09 PM
09/16/10 04:09 PM
Sugarloaf, PA. USA
Sugarloaf, PA. USA
This unit will certainly be able to be used in a race application. We are looking at being able to handle reasonable torque with the stage 1 unit. I will get back to people on closer numbers when we are further along. The Stage 2 trans will handle more power.
I appreciate all the offers for test cars. We have that pretty well taken care of. We have at least one of each body style here, plus I know other people in warmer climates that can handle "winter" testing because they never see snow. So, we are good I think.
As for standard SB/BB clutch working? I am confused by your question. The clutch required will be your standard garden variety 18 spline clutch and throwout bearing with the appropriate pressure plate of course. One more plus for the consumer. Not being tied to us for a special clutch.
It will be made in both 4.35" and 4.80" bearing retainer. This way, you can bolt it up to ANY stock small block (except OD) or big block bellhousing with NO MODS to your bellhousing.
Re: Passon 5 Speed [Re: JamiePasson] #802909
09/16/10 11:17 PM
09/16/10 11:17 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
JB Rhinehart, Realist
A-Body's RULE!
Re: Passon 5 Speed [Re: JamiePasson] #802910
09/16/10 11:46 PM
09/16/10 11:46 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
What a wonderful way to spend an afternoon! There's more than a few of us that can hardly wait.
Re: Passon 5 Speed [Re: JamiePasson] #802911
09/17/10 12:44 AM
09/17/10 12:44 AM
Nampa, ID
MadMatt Offline
MadMatt  Offline
Nampa, ID
Hi Jamie,
My post is one of the ones I think you were referring to. Anyway, I'm trying to gather parts in anticipation of your trans coming out. Just to be certain, I can purchase a standard A-833 Quicktime bellhousing, a standard LA 360 flywheel, and an 18 spline clutch and T/O bearing and all will be fine, right? Basically all I will need from you is the trans and shifter?
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: Passon 5 Speed [Re: MadMatt] #802912
09/17/10 08:51 AM
09/17/10 08:51 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
did i miss it somewhere? but what are the rest of the ratios in the trans?
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Passon 5 Speed [Re: Jerry] #802913
09/17/10 09:01 AM
09/17/10 09:01 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I'll have a nice winter project that may be a good place for a stock outward appearing 5 speed. Hopefully to replace the heavyweight 4 speed with NO modifications to the chassis of the intended car. AND still retains the stock factory looking console shifter
Re: Passon 5 Speed [Re: Jerry] #802914
09/17/10 05:16 PM
09/17/10 05:16 PM
Sugarloaf, PA. USA
Sugarloaf, PA. USA
That is correct. The shifter is actually part of the trans. It will be available in press in or bolt on type so that you can use your existing factory 4 speed handle if you desire.
The ratios are as follow:
2.65
1.92
1.40
1.00
.70
Thanks,
jamie
Re: Passon 5 Speed [Re: JamiePasson] #802915
09/17/10 06:28 PM
09/17/10 06:28 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
2.65
1.92
1.40
1.00
.70
Thanks,
jamie
Nice ratio selection, I drove a buddies Keisler equipted, 3.54 geared 440 b-body the other day, and it just felt like the car could use a bit steeper overdrive. Even with 3.54's, when you launch through the gears, you're shifting pretty quickly from 1st through 3rd.
On a track with slicks in the quarter mile it's obviously another story, but in the real world we're talking about top-end speed that is limited only by the car's ability to stay on the road and not start flying.
Wasn't it Richard Petty who said that with 3.54 rear-end gears, his top end was almost unlimited? Imagine if they had this tranmission back in the days of Rapid Transit and Vanishing Point!
Your ratios with the .70 OD sounds perfect, especially with a stroker motor on the freeway these days.
After looking atr the Kiesler website, it seems I was misinformed about the Kiesler 5th gear ratio. Sorry.
Re: Passon 5 Speed [Re: JamiePasson] #802916
09/17/10 07:03 PM
09/17/10 07:03 PM
California
Moneypit6 Offline
Moneypit6  Offline
California
I remember some time ago that steeper ratios for the lower gears may have been an option. Will there be any possibility of getting something with a steeper 1st gear??
70 Roadrunner almost ready to come off the rotisserie smile
Re: Passon 5 Speed [Re: Moneypit6] #802917
09/18/10 08:40 AM
09/18/10 08:40 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You planning on running a 2.26 rear gear or something? 2.65 first gear is fine, anything lower is getting into granny gear territory.
Don't be the exception.
Re: Passon 5 Speed [Re: Supercuda] #802918
09/18/10 10:25 AM
09/18/10 10:25 AM
Vernon Ct.
bp27 Offline
bp27  Offline
Vernon Ct.
Really I run 3.09 first with 4.10 rear and I like the way the car launches
