Re: wheelie bars opinion's
[Re: MOPARCHAS]
#801882
09/15/10 09:12 AM
09/15/10 09:12 AM
Posts: 10,013 Frostbitefalls MN (Rocky&Bullw...
gregsdart
The longest you can tolerate. I have had sprung and unsprung, am now running unsprung bars 66 inches long. You can have your cake and eat it too if you start with a sprung combo, and if it isn't up to the task replace the springs with a piece of tubing.
[Re: Womanator]
#801886
09/15/10 10:17 PM
09/15/10 10:17 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Amazing how when you use the hp to move the car forward instead of up your 60 ft goes down.
The car use rise 3 ft now I've got it down to 6" and the 60 ft has gone from the high 1.30"s down to the low 1.20's
Uh oh, you done it now......you will be attacked by the "my car 60s best, when it nearly turns over" crew...................
By the way, you are dead right
Monte
[Re: MOPARCHAS]
#801887
09/15/10 10:30 PM
09/15/10 10:30 PM
Posts: 11,541 In Limbo
Billy B Bad
In Limbo
ok guys whats everybodies opinion on wheelie bars sprung or unsprung going to have to bite the bullet and put some on
Screw Wheelie bars man....Get a skid plate on that oil pan
[Re: Billy B Bad]
#801888
09/16/10 01:21 AM
09/16/10 01:21 AM
Posts: 903 Saskatchewan, Canada
cudabin
I use the Competition Engineering generic sprung bars and when adjusted correctly my car 60 foots at 1.25 When bars get raised up a little and front shocks loosened?
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
[Re: Dodgeguy101]
#801891
09/16/10 09:58 PM
09/16/10 09:58 PM
Posts: 778 Sherwood park, Alberta.
go green
Put the sprung wheelie bars next to the 1980 folding lawn chairs.( they work like crap and are junk after the first use ) Any one running a 44" Spring wheelie bar should have there head examined. Go solid,, and at least you have repeatability and something that can actual steer your car . If you want the latest in 70's technology be my guest.
[Re: Big Squeeze]
#801895
09/17/10 08:07 PM
09/17/10 08:07 PM
Quicktree
Ideally if adjusted right, the car never touches the bars and they are there to handle those times when the car is making just a little more power (mineshaft air) and might get up on them.
IMHO, there's only one use for them............. If the track is greasy and/or you're down on power, or leaving with less power to avoid spinning the tires, you can drop the wheelie bar to help get the car up on the tires and avoid tire shake.......
maybe so .but wheelies are way cool
Giant wheelies are gay....... barely carrying the front tires for 200 feet without wheelie bars is "way cool"........
dang you need to be helping AJ win a championship in pro stock
