What was your best combo? #801743
09/14/10 11:35 PM
09/14/10 11:35 PM
USA IN
E85-408 Offline OP
E85-408  Offline OP
USA IN
I know that even if you use the best products for a motor on market doesn't mean you'll make a ton of power so curious to hear about the best combos you've found. Doesnt have to be the most power or the motor that got you the fastest et just a motor that the combo was spot on and eveything worked great together. List cam, heads, compression, carb and ect please. Thanks
Re: What was your best combo? [Re: E85-408] #801744
09/14/10 11:56 PM
09/14/10 11:56 PM
Colorado
506RR Offline
506RR  Offline
Colorado
This combo worked really well in a heavy (4000 lbs) B-Body at high altitude. Really fun street motor!
505 Cubic Inches
440 Block +.030
4.25 Stroke Crank
7.1 Rods with 2.2 Journals
11.1:1 Compression (0.040 Quench) (0 deck)
1/2 inch internal oil pickup w/ Milodon 7 Qt. Pan
Comp XS282S Solid Tlat Tappet Cam
244/252 @ .050
.520/.540 lift with 1.5 Rockers
.555/.576 lift with 1.6 Rockers
Indy EZ Heads Standard Port
Crane Gold 1.6 Roller Rockers
Holley Street Dominator Intake
1000 cfm Holley HP
Headers Ceramic Coated TTI 1 7/8 to 3 inch collectors
Re: What was your best combo? [Re: E85-408] #801745
09/15/10 12:01 AM
09/15/10 12:01 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
The one I run now........12.11 comp. stroked 400(470),home ported rpm`s,Isky solid roller w/.680-.660 lift and 275-280 dur.@ .050,victor jr. intake,1050 dommy w/adapter,2" supercomp headers,3 1/2" pipes w/bullet muffs,727 w/a 5000+ 8" vert,8 3/4 w/4.11`s and a spool @ 3150lbs...........driver often and hard on pump 91..........strokers rule.
Re: What was your best combo? [Re: E85-408] #801746
09/15/10 12:09 AM
09/15/10 12:09 AM
Woodburn,OR
W
Womanator Offline
Womanator  Offline
W
Woodburn,OR
This one was pretty good.
Needed more than a 1/4 race cam.
Maybe a little less timing.
But the split rods had to go.
The new twisted rod didn't work out either.
A como that did work
Basic 499 ci
Indy SR heads ported
Indy intake
Holley Dominator
MSD Ignition
Comp Solid Cam with around 650 lift
Car with this combo ran 9.50's
Re: What was your best combo? [Re: E85-408] #801747
09/15/10 08:48 AM
09/15/10 08:48 AM
an8sec70cuda Offline
Here's a good low budget combo I ran for a few years. Went 11.40s at 117 mph in a 3700# cuda, driven on the street all the time.
440 w/ ported 915s
12:1 w/ Ross flattops
509/292 purpleshaft, stock pushrods and rockers
E-brock RPM, 830 holley
full exhaust w/ the factory cuda tips
727, 10" TCI streetfighter converter
4.10s and 28x10.5 tires
With a little nitrous it went mid 10s.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: What was your best combo? [Re: E85-408] #801748
09/15/10 10:48 AM
09/15/10 10:48 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Depends on what you are looking for I guess. A good consistant, reliable bracket combo seems to be: 440, 11-12:1 pistons, ported iron or e-heads, 1 7/8" headers, 509 cam (or 557 if you like solid), RPM intake 850DP, 3800-4k stall, manual valve body and 4.10's. Not complicated, not too many high dollar parts and can run well into the 11's in a B-body, high 10's in an a-body.
Coming soon!!!!
Re: What was your best combo? [Re: Mr.Yuck] #801749
09/15/10 09:43 PM
09/15/10 09:43 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
My 63's combo is close to that and I am very happy with it. It is a .030 over 440 (446) with stock bottom end and KB pistons that give me 10.0 comp and good quench with my 906 heads I ported. I used the solid MP .557 cam and put Isky ductile iron rockers on it. Has the Holley SD and an 850 DP. Hedman 1-3/4 headers with 3" pipes. Dynamic 9.5 converter and I use 4.30's with a 30 x 9 tire. It runs fine on 92 pump and I drive it everywhere. I was looking to get high 11's as I just wanted an 11 second driver that I could drive to the track and have fun . I am very pleased with its best of 11.49 @ over 116 thru the pipes. The car drives great and runs good driving on the street. It really is a fun street/strip car that did not cost big money to build. And I love the fact that it runs fine on 92 pump. No race gas for me. Ron
Re: What was your best combo? [Re: 383man] #801750
09/15/10 09:48 PM
09/15/10 09:48 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Re: What was your best combo? [Re: Mr.Yuck] #801751
09/16/10 10:20 AM
09/16/10 10:20 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Same question here. What would determine "best" between an OEM iron-head 440 combination that ran 11.0s on pump gas, or an aftermarket-head 440 combination that ran 10.5s on pump gas? Both were pretty well dialed in and ran strong for what they were.
Re: What was your best combo? [Re: BradH] #801752
09/16/10 10:17 PM
09/16/10 10:17 PM
USA IN
E85-408 Offline OP
E85-408  Offline OP
USA IN
Thanks for the replies. I dont have a goal or anything like that in mind. I was just curious about some of your best combos and ones that kinda suprised you on how well it ran with the some of parts.
Re: What was your best combo? [Re: Womanator] #801753
09/16/10 10:26 PM
09/16/10 10:26 PM
iowa
wesw Offline
wesw  Offline
iowa
man your hard on parts. i like that short stroke rod.
Basic 499 ci
Indy intake
Holley Dominator
MSD Ignition
598 ci predator
Re: What was your best combo? [Re: Womanator] #801754
09/16/10 11:34 PM
09/16/10 11:34 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
Basic 499 ci
Indy intake
Holley Dominator
MSD Ignition
what is the race weigth
1.39 9.85 - 137 mph
Re: What was your best combo? [Re: Ari440] #801755
12/21/10 10:13 PM
12/21/10 10:13 PM
Woodburn,OR
W
Womanator Offline
Womanator  Offline
W
Woodburn,OR
#2750
Re: What was your best combo? [Re: Womanator] #801756
12/21/10 10:30 PM
12/21/10 10:30 PM
Orange County, Ca.
B1CUDA Offline
B1CUDA  Offline
Orange County, Ca.
Get ahold of Al Alguire, and ask him about his B1 Combo. I hear the guy that originally designed it, put a bunch of thought and research into building that motor.
Pound for Pound, considering it is a small displacement, single carb motor, it is one of the most impressive B1 combos I have heard of.
Re: What was your best combo? [Re: E85-408] #801757
12/21/10 10:47 PM
12/21/10 10:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've never built for max power... I tend to go for
longevity
Re: What was your best combo? [Re: MR_P_BODY] #801758
12/21/10 11:07 PM
12/21/10 11:07 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
My best combo ever, was in my 73 DartSport.
400/451 low deck
11.2:1 compression flat tops
CNC ported Eddy heads
MP 590 purpleshaft cam
Streetable Isky 1005a springs
2" MadDog headers
M1 Tunnel ram
750 Quickfuel carbs
Ran high 9's at 3050#'s through an X-pipe exhaust system.
Re: What was your best combo? [Re: E85-408] #801759
12/22/10 12:14 AM
12/22/10 12:14 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
340 bored 40 over,edelbrock heads,4.30 gears 10.5 to 1 compression,3200 74 dart 10.80's all day,thats my 2nd best the new one is in my cuda
Re: What was your best combo? [Re: fishy340] #801760
12/22/10 12:14 AM
12/22/10 12:14 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
ps 255/255 588 lift bullet flat tappet
