Re: What was your best combo?
[Re: E85-408]
#801745
09/15/10 12:01 AM
09/15/10 12:01 AM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
The one I run now........12.11 comp. stroked 400(470),home ported rpm`s,Isky solid roller w/.680-.660 lift and 275-280 dur.@ .050,victor jr. intake,1050 dommy w/adapter,2" supercomp headers,3 1/2" pipes w/bullet muffs,727 w/a 5000+ 8" vert,8 3/4 w/4.11`s and a spool @ 3150lbs...........driver often and hard on pump 91..........strokers rule.
[Re: E85-408]
#801746
09/15/10 12:09 AM
09/15/10 12:09 AM
Posts: 40 Woodburn,OR
Womanator
Woodburn,OR
This one was pretty good. Needed more than a 1/4 race cam. Maybe a little less timing. But the split rods had to go. The new twisted rod didn't work out either. A como that did work Basic 499 ci Indy SR heads ported Indy intake Holley Dominator MSD Ignition Comp Solid Cam with around 650 lift Car with this combo ran 9.50's
[Re: E85-408]
#801747
09/15/10 08:48 AM
09/15/10 08:48 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
Here's a good low budget combo I ran for a few years. Went 11.40s at 117 mph in a 3700# cuda, driven on the street all the time.
440 w/ ported 915s 12:1 w/ Ross flattops 509/292 purpleshaft, stock pushrods and rockers E-brock RPM, 830 holley full exhaust w/ the factory cuda tips 727, 10" TCI streetfighter converter 4.10s and 28x10.5 tires
With a little nitrous it went mid 10s.
[Re: E85-408]
#801748
09/15/10 10:48 AM
09/15/10 10:48 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Depends on what you are looking for I guess. A good consistant, reliable bracket combo seems to be: 440, 11-12:1 pistons, ported iron or e-heads, 1 7/8" headers, 509 cam (or 557 if you like solid), RPM intake 850DP, 3800-4k stall, manual valve body and 4.10's. Not complicated, not too many high dollar parts and can run well into the 11's in a B-body, high 10's in an a-body.
[Re: Mr.Yuck]
#801749
09/15/10 09:43 PM
09/15/10 09:43 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
My 63's combo is close to that and I am very happy with it. It is a .030 over 440 (446) with stock bottom end and KB pistons that give me 10.0 comp and good quench with my 906 heads I ported. I used the solid MP .557 cam and put Isky ductile iron rockers on it. Has the Holley SD and an 850 DP. Hedman 1-3/4 headers with 3" pipes. Dynamic 9.5 converter and I use 4.30's with a 30 x 9 tire. It runs fine on 92 pump and I drive it everywhere. I was looking to get high 11's as I just wanted an 11 second driver that I could drive to the track and have fun . I am very pleased with its best of 11.49 @ over 116 thru the pipes. The car drives great and runs good driving on the street. It really is a fun street/strip car that did not cost big money to build. And I love the fact that it runs fine on 92 pump. No race gas for me. Ron
[Re: 383man]
#801750
09/15/10 09:48 PM
09/15/10 09:48 PM
383man
Balt. Md
[Re: Mr.Yuck]
#801751
09/16/10 10:20 AM
09/16/10 10:20 AM
BradH
Same question here. What would determine "best" between an OEM iron-head 440 combination that ran 11.0s on pump gas, or an aftermarket-head 440 combination that ran 10.5s on pump gas? Both were pretty well dialed in and ran strong for what they were.
[Re: MR_P_BODY]
#801758
12/21/10 11:07 PM
12/21/10 11:07 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
My best combo ever, was in my 73 DartSport. 400/451 low deck 11.2:1 compression flat tops CNC ported Eddy heads MP 590 purpleshaft cam Streetable Isky 1005a springs 2" MadDog headers M1 Tunnel ram 750 Quickfuel carbs Ran high 9's at 3050#'s through an X-pipe exhaust system.
