Shoulder Harness ? #801616
09/14/10 08:54 PM
09/14/10 08:54 PM
Forest Grove,Oregon
beepbeepdon Offline OP
Forest Grove,Oregon
OK I bought the 5 point RCI harness listed as a "wrap around"...SO I did just that,wrapped it around the roll cage behind the seat,used the metal piece that comes with it cinched it up as tight as I could and the track tech inspector didn't like the fact that the harness moves.( slightly side to side).Am I a dim bulb but does "wrap around" mean something else.Would any of you have pics showing how you secured the shoulder straps to your roll cage. He said I should weld some tabs or something....Thanks for the help
Re: Shoulder Harness ? [Re: beepbeepdon] #801617
09/14/10 09:28 PM
09/14/10 09:28 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
mine are just wrapped like you discribed, i have them cinched tight against the rollbar, never been called on it, sorry no pics
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Shoulder Harness ? [Re: Stroker Scamp] #801618
09/14/10 10:29 PM
09/14/10 10:29 PM
Forest Grove,Oregon
Forest Grove,Oregon
Thanks Mike...I met you at Woodburn a couple of months ago....Finally got the car to the track
Re: Shoulder Harness ? [Re: beepbeepdon] #801619
09/14/10 10:38 PM
09/14/10 10:38 PM
You can get cute and do it like this.
Re: Shoulder Harness ? [Re: ] #801620
09/14/10 11:51 PM
09/14/10 11:51 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Did you put those on before you welded on the bar? That's one way to keep them from moving.
I have the wrap around type and have no problem with tech.
Re: Shoulder Harness ? [Re: ] #801621
09/15/10 12:18 AM
09/15/10 12:18 AM
Forest Grove,Oregon
Forest Grove,Oregon
That is a great idea...Thanks!!!
Re: Shoulder Harness ? [Re: beepbeepdon] #801622
09/15/10 02:13 AM
09/15/10 02:13 AM
Re: Shoulder Harness ? [Re: ] #801623
09/15/10 12:15 PM
09/15/10 12:15 PM
Forest Grove,Oregon
Forest Grove,Oregon
Thank you very much for the source. I will call them today
Re: Shoulder Harness ? [Re: beepbeepdon] #801624
09/15/10 01:18 PM
09/15/10 01:18 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Re: Shoulder Harness ? [Re: beepbeepdon] #801625
09/15/10 05:48 PM
09/15/10 05:48 PM
I have used the wrap arounds and use a hose clamp on each side to limit the movement, I also cross the right side(installed the belts so they will fit the buckle correctly ) to the driver side to prevent lateral movement in case thy need to be tested at the track in competion That, the hose clamps, is not needed if your shoulder harness go through the seat backs
Re: Shoulder Harness ? [Re: Cab_Burge] #801626
09/15/10 08:15 PM
09/15/10 08:15 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
..... the hose clamps, is not needed if your shoulder harness go through the seat backs
Not sure that seat back openings will pass tech to prevent belts from sliding in many other sanctions.
