Did 1969 A12 cars have a special K member? #800893
09/14/10 01:00 AM
09/14/10 01:00 AM
California
BigDaddy440 Offline OP
California
I thought I read somewhere that hemi cars and A12 cars had a special K member. But if A12 cars began life as a standard 383 car, then it seems they would not.
Anyone?
-Dan
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: Did 1969 A12 cars have a special K member? [Re: BigDaddy440] #800894
09/14/10 01:44 AM
09/14/10 01:44 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
1969 HEMI cars have their own k-frame (skid plate & HEMI mounts) SPECIAL
1969 A12 cars use a mid-model year V8 k-frame (used '70 K-frame lower half with provisions for the "pass-thru" sway bar, yet retained '69 sway bar) not special
An early '69 model year V8 k-frame is different.
Re: Did 1969 A12 cars have a special K member? [Re: 6bblgt] #800895
09/14/10 02:03 AM
09/14/10 02:03 AM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
I had a June 26 '69 scheduled production date '69 383 road runner that had the '69 soon to be '70 (with the different swaybar and mount) K-frame so it wasn't an A12 special K-frame it's just that it seems most of the A12's just happened to have this style of K-frame Here's what I put together with a K-frame I have that came off of another late production '69 383 road runner, again the K-frames were going to have a different type and style swaybar and these were the pre-change over K-frames
MikeR
Re: Did 1969 A12 cars have a special K member? [Re: 6bblgt] #800896
09/14/10 03:08 AM
09/14/10 03:08 AM
California
California
Ok, So I'm hearing you say that the A12 cars had a 1970 style K Frame, but the used a 69 sway bar whereas the 1970 cars used the same K frame, and a different sway bar? -Dan
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: Did 1969 A12 cars have a special K member? [Re: BigDaddy440] #800897
09/14/10 03:18 AM
09/14/10 03:18 AM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
Yep, and so did some later production '69 B-bodies or at least some later production '69 road runners that I've seen and owned.
MikeR
Re: Did 1969 A12 cars have a special K member? [Re: BigDaddy440] #800898
09/14/10 03:22 AM
09/14/10 03:22 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
No, it was a specific last half of '69 Model year only (due to sway bar mounting holes).
estimated dates
August '67 to February '69 ('68 & early '69 V8 b-body)
March '69 to July '69 (late '69 V8 b-body)
August '69 to ?? w/skidplate 440 ('70+ b-body)
August '69 to ?? 318 & 383 ('70+ b-body)
Re: Did 1969 A12 cars have a special K member? [Re: A12] #800899
09/14/10 03:25 AM
09/14/10 03:25 AM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
Here's the '69 383 6-26 SPD road runner K-frame with the '70 bottom with the cutouts for the '70 swaybar. Again NOT an A12 car but already had the '70 style K-frame but with the '68/'69 swaybar mounted at the front of the K-frame.
Re: Did 1969 A12 cars have a special K member? [Re: 6bblgt] #800900
09/14/10 03:41 AM
09/14/10 03:41 AM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
estimated dates
Dan, your list seems pretty spot on to me with '69 models starting in late March having the change over style K-frames ('70 bottom with '69 swaybar). The '70 models I know nothing about except that skid plate thing
March to July '69 at least for the Lynch Road cars seems to be spot on Don't know what happened at the "E"-LA and the "G"-St Louis assembly plants
