1998 V10 2500 Truck - Techs? #800036
09/13/10 11:03 AM
09/13/10 11:03 AM
NC
BillNC Offline OP
BillNC  Offline OP
NC
My 1998 2500 V-10 shut down while driving yesterday. A small pop sound, then it died. Will turn over but not start. Fuel pump is working. Fuses okay. Only thing found, air pump hose was "blown off" the pump nipple. I'm guessing either crank sensor or computer. Any other thoughts? Thanks!
Re: 1998 V10 2500 Truck - Techs? [Re: BillNC] #800037
09/13/10 12:44 PM
09/13/10 12:44 PM
Bama
Randy.. Offline
Randy..  Offline
Bama
sounds like the crank sensor, not hard to change and cheaper than the ECM.
Re: 1998 V10 2500 Truck - Techs? [Re: Randy..] #800038
09/13/10 04:37 PM
09/13/10 04:37 PM
NC
BillNC Offline OP
BillNC  Offline OP
NC
More info. The check engine light never came on, and a friend's code reader showed NO codes in the system.......
Re: 1998 V10 2500 Truck - Techs? [Re: BillNC] #800039
09/13/10 09:30 PM
09/13/10 09:30 PM
NC
BillNC Offline OP
BillNC  Offline OP
NC
Back to Top
Re: 1998 V10 2500 Truck - Techs? [Re: BillNC] #800040
09/14/10 08:15 AM
09/14/10 08:15 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
When my 96' V-10 Ram did that it was the computer.Although it wasn't while driving. Came back from the race track dropped off a few buddies in the driveway. We were B.S.'in for 15-20 minutes. Went to go start it & just turned over but would not start.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 1998 V10 2500 Truck - Techs? [Re: BillNC] #800041
09/14/10 12:30 PM
09/14/10 12:30 PM
MI
Blown69 Offline
mopar addict
Blown69  Offline
mopar addict
MI
Need to check for spark, and make sure you injectors are pulsing before you go swapping parts
