Re: changed cams......pops out the exhaust now
[Re: GTX MATT]
#798802
09/12/10 01:13 AM
09/12/10 01:13 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Double check the cam and make sure that its not for a 426 hemi
Ouch... Actually it wouldn't run because that would effect all cylinders equally... Which is what is odd about this whole thing cause anything related to cam timing would be effecting all cylinders too... Unless theres a problem with how the cam was ground or the condition of the lobes... The fact all cylinders show good compression makes that unlikely... Which is why I liked the firing order idea but thats been double checked sooo....
[Re: GTX MATT]
#798803
09/12/10 01:17 AM
09/12/10 01:17 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Ouch...
[Re: 1_WILD_RT]
#798804
09/12/10 01:22 AM
09/12/10 01:22 AM
Posts: 5,164 CT
GTX MATT
CT
Good point, the compression test would have turned back something odd.
Heres and odd question open to your judgement, does it sound like an 8 cylinder engine?
[Re: E85-408]
#798808
09/12/10 01:41 AM
09/12/10 01:41 AM
RapidRobert
IF it's a vac leak the bathtub gasket may have a leak on the underside
[Re: E85-408]
#798810
09/12/10 01:51 AM
09/12/10 01:51 AM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
Your NOT using the MP chart to set lash? Correct. I hope so.I assume the plug wires are installed correctly. Did you drop a plug? I'd remove them all and have a look maybe you will find a cylinder to look at more closely. You don't need a degree wheel or to remove the timing cover to confirm cam timing. PM me if you exhaust all these other simple things.
Ive set the lash 3-4times now I just use the starter bumper until I see the intake close one more bump and then set it. With plugs in or the starter bump rotates the motor too far. I dropped the number 6 plug more times then I care to think about but make sure I didnt smash it closed. 440 with TTI headers in a dart with inner fenders is a royal pain to change. I'll run through all again tomorrow see if I over looked anything.
Change the number 6 plug if you have kept up with it and not moved it to another hole.. Plugs are easily damaged without smashing them closed. Try it,easy and cheap.
[Re: Baxter61]
#798811
09/12/10 08:07 AM
09/12/10 08:07 AM
Posts: 397 North Carolina
jt1
North Carolina
BB dist rotate counter-clockwise, so your firing order may be correct for a SB but not BB.
Double check this, it's bit me before. Almost unbelievably, the thing would run but very poorly, firing order correct but direction of rotation wrong.
John
[Re: E85-408]
#798812
09/12/10 02:06 PM
09/12/10 02:06 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
This isn't the correct way to set valves. The MP chart works with sold flat tappet and small roller cams.
Without the MP chart; Set the int just as the exh begins to open. Set the exh just before the int fully closes.
