Trans Dipstick BB A-Body #795384
09/07/10 12:48 PM
09/07/10 12:48 PM
Oh
RacerGofKGB Offline OP
Got The Big One
Got The Big One
Oh
I have a 70 Dart with a low deck stroker/727 with 2" Fenderwell headers. Last weekend i was trying to get the tranny dipstic tube in and there was no way it was going to fit. So i try the ol "bend it a little over your knee" trick. Well i bent it allright. Bent it right in half. Im not too upset because i didnt figure it would fit all that well anyway. So I have been searching the intrawebs looking for different options. From reading on here, it would seem that certain GM dipstics will work on our old 727's. For my application, a flexible one would be very helpful. I found these on the EBAY: http://cgi.ebay.com/ebaymotors/Flexible-...sQ5fAccessories Would this work? If not, What GM tranny should i be looking for?
Re: Trans Dipstick BB A-Body [Re: RacerGofKGB] #795385
09/07/10 05:56 PM
09/07/10 05:56 PM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
I know Lokar makes a flexible dipstick. You can get it from summit or im sure that 1 of the sponsers here can get it as well.
Re: Trans Dipstick BB A-Body [Re: None2Slow] #795386
09/07/10 06:14 PM
09/07/10 06:14 PM
florida
74fldart Offline
74fldart  Offline
florida
i know what you mean by trans. dipsitck tube in dart w bb = doesnt want to fit in there.
i got mine to fit in by cutting off the bracket on it that bolts to the engine to trans bolt and then it would swivel more toward the pass. side and i made up my own bracket to bolt to the firewall. i looked at the lokar but i couldnt justify the 70 or 80 bucks. i do have regular under chassis headers tho. so i might of had more room than you. those tubes dont want to bend ive tried too but gave up before it bent in two.
i dont think the gm would be the right depth stick and all but that price isnt bad at all.
Re: Trans Dipstick BB A-Body [Re: RacerGofKGB] #795387
09/07/10 08:14 PM
09/07/10 08:14 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
I went with a locking dipstick from Mancini on my BB duster. It's close to the firewall but works fine and I like the improved seal at the trans.
Re: Trans Dipstick BB A-Body [Re: 74fldart] #795388
09/07/10 09:36 PM
09/07/10 09:36 PM
Oh
Got The Big One
Got The Big One
Oh
Yea i have a hard time justifying $80 for something as silly as a dipstick tube. I didnt think the $25-$30 for the flexable GM one was all that bad though.
Re: Trans Dipstick BB A-Body [Re: RacerGofKGB] #795389
09/07/10 10:29 PM
09/07/10 10:29 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Easy fix but a little expensive, GO 4-SPEED!
JB Rhinehart, Realist
A-Body's RULE!
Re: Trans Dipstick BB A-Body [Re: Rhinodart] #795390
09/07/10 10:58 PM
09/07/10 10:58 PM
Oh
Got The Big One
Got The Big One
Oh
Im sure a 4 speed swap will cost just a smidge more than an $80 dipstick tube.
Re: Trans Dipstick BB A-Body [Re: RacerGofKGB] #795391
09/08/10 12:34 PM
09/08/10 12:34 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
the stock tube fit my 71 dart w/400. i remember it was hard to get the bolt in there but not impossible.
Re: Trans Dipstick BB A-Body [Re: 74fldart] #795392
09/08/10 04:06 PM
09/08/10 04:06 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
i got mine to fit in by cutting off the bracket on it that bolts to the engine to trans bolt and then it would swivel more toward the pass. side and i made up my own bracket to bolt to the firewall. .
Do you have SOLID motor mounts ??? The dipstick is bolted to the engine/trans for a reason , packaging was not the reason .
Re: Trans Dipstick BB A-Body [Re: JohnRR] #795393
09/08/10 07:41 PM
09/08/10 07:41 PM
florida
74fldart Offline
74fldart  Offline
florida
no , but i have a torque strap , glad you pointed that out as i havent fired it up yet since i did the mod. on the tube. i guess i should bolt it back to the motor to be safe.
Re: Trans Dipstick BB A-Body [Re: 74fldart] #795394
09/08/10 07:51 PM
09/08/10 07:51 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Good idea, a torque strap only limits movement.
Re: Trans Dipstick BB A-Body [Re: RacerGofKGB] #795395
09/08/10 08:36 PM
09/08/10 08:36 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Yes, but worth it.
Re: Trans Dipstick BB A-Body [Re: 65rbdodge] #795396
09/08/10 09:54 PM
09/08/10 09:54 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Same here and I use the same tube with either B or RB engine.Motor plate equipped.
Nautilus Racing-
