Need opinions on which head gasket to use #794567
09/06/10 06:52 PM
09/06/10 06:52 PM
Virginia
RM21N0A Offline OP
RM21N0A  Offline OP
Virginia
Had to take a passenger side head to the machine shop - busted exhaust manifold stud.
I have some Mr. Gasket head gaskets (white) and Felpro (blue).
Any preferences or suggestions from you guys?
Pa, just what can you do with a grown woman?
--- Opie Taylor ---
Re: Need opinions on which head gasket to use [Re: RM21N0A] #794568
09/06/10 06:55 PM
09/06/10 06:55 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Use the one that has the same thickness as the one on the driver's side.
Re: Need opinions on which head gasket to use [Re: Neil] #794569
09/06/10 07:28 PM
09/06/10 07:28 PM
Virginia
RM21N0A Offline OP
RM21N0A  Offline OP
Virginia
Well, yeah, that would make sense.
The gasket that came off was a Felpro (.030").
So I would guess that is what is on the other side.
The Mr. Gasket is .040".
I'd like to know if anyone has had any problems with sealing with the white, slick material of the Mr. Gasket product.
Re: Need opinions on which head gasket to use [Re: RM21N0A] #794570
09/06/10 09:16 PM
09/06/10 09:16 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I didn't know felpro made an .030 composite gasket , what's the number on it ?
Re: Need opinions on which head gasket to use [Re: JohnRR] #794571
09/07/10 03:07 AM
09/07/10 03:07 AM
Beaverton, OR, USA
Alikazam Offline
super gas
Alikazam  Offline
super gas
Beaverton, OR, USA
If you're going to replace both... I'd use Cometic Multi-Layer Steel head gaskets. Best I've ever used. Have re-used them 3 times on my engine, just sprayed with copper coat and slapped em on after the first usage and sealed up good. Available in custom thicknesses too, I'm running .027" thick ones to up my compression a little on my 360. Good luck!
Re: Need opinions on which head gasket to use [Re: JohnRR] #794572
09/07/10 08:28 AM
09/07/10 08:28 AM
Virginia
RM21N0A Offline OP
RM21N0A  Offline OP
Virginia
8519 PT-1.
You can barely make it out in the pic if you blow it up.
This another reason I love this site - it forces you to double-check yourself.
I probably should have been more specific.
Using my dial caliper in about 10 different places on the gasket, the Fel-pro showed exactly .030".
But, doing a search is showing that people say the thickness is in the range of .040".
Here is some info I found - no surprise that both of these are on Moparts:
https://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=6136576&Main=6134460
https://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=6084813&Main=5930299
Couple of other sites showing up on a search say the same thing.
So, could be that my caliper is off, and that would make the Mr. Gasket head gasket more like .050".
Mercy.
Re: Need opinions on which head gasket to use [Re: RM21N0A] #794573
09/07/10 12:35 PM
09/07/10 12:35 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Any chance of posting some close-up pictures of the Mr. Gasket part?
Re: Need opinions on which head gasket to use [Re: RM21N0A] #794574
09/07/10 01:04 PM
09/07/10 01:04 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
8519 PT-1.
Mercy.
Use another 8519 if that is what is on the other side , it's not .030 unless you got some oddball that made it out the door , it'sa .039ish gasket .
Re: Need opinions on which head gasket to use [Re: JohnRR] #794575
09/07/10 08:49 PM
09/07/10 08:49 PM
Virginia
RM21N0A Offline OP
RM21N0A  Offline OP
Virginia
Ah, well, this turned into a "Don't ask me how I know" kind of a thing...
Called Central High Performance (800-222-6805), talked to a good guy who had plenty of specs on non-stock head gaskets, but not on the 8519 PT-1.
He did tell me though that Fel-pro was owned by Federal Mogul, and I could call them (248-354-7700) and get the thickness.
Called, got transferred around for a while, then got in touch with a great guy that gave me the thickness:
.045" off the shelf
.0388" compressed
Took my gasket to the machine shop, to get it measured with a decent caliper, he read .043".
Went upstairs into the NAPA store, with my caliper and gasket, to shop for another caliper, and while the guy was looking up caliper part numbers, it hit me.
So, when reading your dial caliper, if you want to read thousandths, be sure that you are not looking at 64ths. See picture.
But at least now I know that 3/64" equals .045".
Re: Need opinions on which head gasket to use [Re: BradH] #794576
09/07/10 08:54 PM
09/07/10 08:54 PM
Virginia
RM21N0A Offline OP
RM21N0A  Offline OP
Virginia
Does this help?
Thickness on this one is actually reading between .058" and .062" for me, now that I remembered how to correctly read the caliper.
The guy at the machine shop got a reading of .058".
The material is kind of "waxy" feeling.
Re: Need opinions on which head gasket to use [Re: RM21N0A] #794577
09/07/10 09:48 PM
09/07/10 09:48 PM
Western Pa
joewhite440 Offline
joewhite440  Offline
Western Pa
I have always ran Felpro for many years. I have never had one fail....
Re: Need opinions on which head gasket to use [Re: RM21N0A] #794578
09/08/10 04:14 PM
09/08/10 04:14 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
.045" off the shelf
.0388" compressed
It's called COMPRESSED thickness for a reason , you need to measure it with the head bolted to the block, it will slightly spring back when the clamping force is removed.
Re: Need opinions on which head gasket to use [Re: JohnRR] #794579
09/08/10 05:43 PM
09/08/10 05:43 PM
Virginia
RM21N0A Offline OP
RM21N0A  Offline OP
Virginia
No problem there - I fully understood that part.
Where I went wrong was just that I had boneheadedly forgotten how to read my caliper.
Re: Need opinions on which head gasket to use [Re: RM21N0A] #794580
09/08/10 06:02 PM
09/08/10 06:02 PM
BradH Offline
BradH  Offline
Does this help?
Yes, thanks!
BTW, those look like one of the head gasket options that 440 Source offers now, too.
Re: Need opinions on which head gasket to use [Re: BradH] #794581
09/08/10 06:56 PM
09/08/10 06:56 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Capt'n, The white head gaskest shown at the 440 source site are the old Corteco/ROL gaskets which are hard to find.They mention that Edelbrock uses these,but in fact Edelbrock now uses the FelPro 8519PT-1 as their gasket of choice for their cylinder heads.I have a set that are in Edelbrock bags.
Nautilus Racing-
Re: Need opinions on which head gasket to use [Re: Chris2581] #794582
09/08/10 10:10 PM
09/08/10 10:10 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
Throw the Mr. Gasket crap in the trash and use the Fel-Pro. Mr. Gasket, Summit, Jegs and all those other off brand gaskets are garbage. Just measure arouind the fire ring, and look at the wall thickness near waterjackets and you will start to understand what I'm talking about.
Re: Need opinions on which head gasket to use [Re: drew72] #794583
09/09/10 09:34 AM
09/09/10 09:34 AM
Virginia
RM21N0A Offline OP
RM21N0A  Offline OP
Virginia
I'm pretty much locked into using the Fel-pro anyway, simply to match what should be on the other side.
But, I think I'm getting what you are talking about, if you mean the variation in thickness. That's what I meant above when I said that I am getting different thicknesses when I measure in different places on the gasket - between .058" and .062".
Myself I don't have enough experience with them to know if this is a big deal, but I did talk to another buddy (former Chrysler mechanic) at a cruise-in last Friday that said he would stay away from that brand.
Or are you talking about the diameters of the holes not matching up with the ones on the head?
I think I'll check that out tomorrow.
