Terrible night last night #793219
09/05/10 10:22 AM
09/05/10 10:22 AM
Woodstock , Georgia
Mopar_racer_99 Offline OP
Woodstock , Georgia
Well Guys, It looks like we wont be coming to Norwalk. Took car out for some shake down runs. First pass car did good burn out then, walked out at launch 2.39 60 foot. What the Hell????? It was like driving moms car from redlight. Check the motor everything looks good nothing loose or broken. Try second pass, Car launches 1.69 60' runs a 6.33 114 something still doesnt feel rightcheck all connections fuel spark motor is good trans was quart low added a quart. 3rd pass car goes 1.49 60 still felt like it walked out from idle at lauch half track trans sounded like a blower motor, trans temp went to 300 and climbing shut down , Amsoil compressor oil smells like nothing I have ever smelt. I think trans and convertor are gone but thing is let it cool and it moves around fine. John
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
Re: Terrible night last night [Re: Mopar_racer_99] #793220
09/05/10 10:41 AM
09/05/10 10:41 AM
Q
Quicktree Offline
Quicktree  Offline
Q
don't give up, pull it out and fix it. maybe something simple in the tranny.
Re: Terrible night last night [Re: Mopar_racer_99] #793221
09/05/10 10:52 AM
09/05/10 10:52 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Do you have a restriction in the cooler lines(fittings)
thats alot of heat for a pass
Re: Terrible night last night [Re: Quicktree] #793222
09/05/10 10:54 AM
09/05/10 10:54 AM
Columbia Station, OH
MrBelvedere Offline
Mr Zipper Lips
MrBelvedere  Offline
Mr Zipper Lips
Hope ya get it sorted out John. Good luck
Re: Terrible night last night [Re: MrBelvedere] #793223
09/05/10 11:15 AM
09/05/10 11:15 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
I agree pull it, fix it, report back, move ahead. Your bad luck has got to end one of these days.
Re: Terrible night last night [Re: HardcoreB] #793224
09/05/10 01:10 PM
09/05/10 01:10 PM
Woodstock , Georgia
Woodstock , Georgia
The fittings, and cooler are same ones, we have had for the pass 4 years, the trans has never gone 180 on run before, reading my TSR book it giving things like servo and band also filter clogging, We will pull the pan and see but I think its going to need a rebuild and convertor check.
Re: Terrible night last night [Re: Mopar_racer_99] #793225
09/05/10 01:40 PM
09/05/10 01:40 PM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
If it's a glide you may have killed the sprag in the convertor
Re: Terrible night last night [Re: SB412DUSTER] #793226
09/05/10 02:39 PM
09/05/10 02:39 PM
Woodstock , Georgia
Woodstock , Georgia
Yes it is a glide Reid case with full roller set up 1.80 straight cut, built by Sid Neal. John
