engine diaper #791274
09/02/10 11:10 PM
09/02/10 11:10 PM
Kissimmee Fl.
dusturbd340W5 Offline OP
Kissimmee Fl.
I was just looking at our lovely online NHRA rule book and from the way I am reading things a diaper is not required until you get into advance ET running 7.49 or faster am I reading this correct?
Under super pro running 7.50 or slower it states a diaper is permitted but doesn't say required.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: engine diaper [Re: dusturbd340W5] #791275
09/02/10 11:28 PM
09/02/10 11:28 PM
Auburn, Indiana
The Duster Offline
The Duster  Offline
Auburn, Indiana
That's what I read too. The real question is what percentage of crashes could have been avoided if they had a diaper? $200 sounds like cheap insurance to me.
Re: engine diaper [Re: The Duster] #791276
09/02/10 11:57 PM
09/02/10 11:57 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Also a requirement of certain classes, ie Super Gas, Super Com and Comp. I am sur we will all see a trickle down affect eventually. I know after the hemi had the rods try and get out the side of the block and 155 and there was not a drop of oil on the track I wont be without one again.
Re: engine diaper [Re: The Duster] #791277
09/03/10 12:09 AM
09/03/10 12:09 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
they start at 158 custom made to fit russileri did mine
http://www.russlerii.com/
home of the
Sox and Martin Hemi Duster
Re: engine diaper [Re: dusturbd340W5] #791278
09/03/10 12:15 AM
09/03/10 12:15 AM
MD
Kevins493 Offline
Kevins493  Offline
MD
DRE made mine. I run stock front suspension and it hasn't been an issue (k member is notched to clear the pan though). The NSS organization i run with had an incedent a couple weeks ago that could have been avoided had the car that lost the motor had a diaper (or if the track was cleaned.....) Luckily no one was hurt and the damage was minimal.
Re: engine diaper [Re: HEMIFRED] #791279
09/03/10 12:18 AM
09/03/10 12:18 AM
Kissimmee Fl.
Kissimmee Fl.
I get the safety argument about having 1 but I am just looking at letter of the way it is written and if I am required to run 1 or not from the way I see it it's not required with me running a bracket super pro car running slower than 7.50.
Re: engine diaper [Re: dusturbd340W5] #791280
09/03/10 12:46 AM
09/03/10 12:46 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
what so confusing? not required means not required like you don't have to have it 7.50 and upp and permitted means you can have it and they permit it's use
OIL-RETENTION DEVICE
All vehicles running 7.49 or quicker must utilize an NHRA-accepted
lower engine oil-retention device; may use a belly pan in lieu of a
device attached to the engine. The belly pan must extend from
framerail to framerail and extend forward of the harmonic balancer
and rearward to rear engine plate and must incorporate a minimum
2-inch-high lip on all sides. A nonflammable, oil-absorbent liner
mandatory inside of retention device. See General Regulations 1:8.
home of the
Re: engine diaper [Re: HEMIFRED] #791281
09/03/10 01:06 AM
09/03/10 01:06 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
What he said..Pretty simple if you have a racecar running 7.50 or slower you dont need one. UNLESS you run Comp, Super Gas or Super Comp, they need one regardless of ET.
Re: engine diaper [Re: Al_Alguire] #791282
09/03/10 01:10 AM
09/03/10 01:10 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Are we talking 1/8th mile or 1/4? Now I`m confused.............
Re: engine diaper [Re: Thumperdart] #791283
09/03/10 01:16 AM
09/03/10 01:16 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
1/4 mile...
Re: engine diaper [Re: Al_Alguire] #791284
09/03/10 01:20 AM
09/03/10 01:20 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That`s a relief.............although a great safety item.
Re: engine diaper [Re: Thumperdart] #791285
09/03/10 05:00 AM
09/03/10 05:00 AM
Arizona
Chris'sBarracuda Offline
Arizona
There are some tracks that are requiring them on their own track rules.
They don't need the down time, nor the cost of clean ups..
I have a russler also. great guy. Good ol racer..
Chris..
Re: engine diaper [Re: Chris'sBarracuda] #791286
09/03/10 08:04 AM
09/03/10 08:04 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
that is exactly the case at most tracks I race at, 9.99 and quicker they are required
Re: engine diaper [Re: MegaDart] #791287
09/03/10 10:56 AM
09/03/10 10:56 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Man, it becomes a bit crazy once you`re in the 9`s but it does make tracks/drivers safer I guess. I`m WAY under the 6.39 1/8th mile legal thing w/only a bar already and after my 6.10 I PROMISE I`ll make it legit..........
Re: engine diaper [Re: Thumperdart] #791288
09/03/10 11:25 AM
09/03/10 11:25 AM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I hope to participiate in a couple of races where they're required. A diaper wont work on mine but I'm in the middle of a belly pan project which looks like may work well. I'll post some pics when its installed.
Re: engine diaper [Re: DavidDean] #791289
09/03/10 11:51 AM
09/03/10 11:51 AM
gregsdart Online content
gregsdart  Online Content
I hope to participate in a couple of races where they're required. A diaper wont work on mine but I'm in the middle of a belly pan project which looks like may work well. I'll post some pics when its installed.
This to me is the best approach. You get the benefits of oil control, and improved aerodynamics through better airflow under the car. Might as well extend it forward a bit and add a front air dam under the valance?
Kinda follows the philosophy, nothing rides for free!
Re: engine diaper [Re: Thumperdart] #791290
09/03/10 08:20 PM
09/03/10 08:20 PM
Kissimmee Fl.
Kissimmee Fl.
yeap they are just looking for every way they can to nickle and dime the small guy to death.
It shows the diaper has to be recerted every year that's as bad as every 2 years on the belts
Re: engine diaper [Re: dusturbd340W5] #791291
09/03/10 08:37 PM
09/03/10 08:37 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
IMO, it is a good rule and was long overdue. As for the recert only Top Sportsman, Top Dragster and faster require SFI certed diapers. You will be fine with just a sportsman diaper.
Re: engine diaper [Re: MegaDart] #791292
09/03/10 09:10 PM
09/03/10 09:10 PM
Arizona
Arizona
What he said..
Re: engine diaper [Re: Chris'sBarracuda] #791293
09/03/10 09:19 PM
09/03/10 09:19 PM
Kissimmee Fl.
Kissimmee Fl.
so the sportsman's is just a 1 time purchase.
