engine diaper
#791274
09/02/10 11:10 PM
09/02/10 11:10 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I was just looking at our lovely online NHRA rule book and from the way I am reading things a diaper is not required until you get into advance ET running 7.49 or faster am I reading this correct? Under super pro running 7.50 or slower it states a diaper is permitted but doesn't say required.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: engine diaper
[Re: The Duster]
#791276
09/02/10 11:57 PM
09/02/10 11:57 PM
Posts: 19,360 Las Vegas
Al_Alguire
Las Vegas
Also a requirement of certain classes, ie Super Gas, Super Com and Comp. I am sur we will all see a trickle down affect eventually. I know after the hemi had the rods try and get out the side of the block and 155 and there was not a drop of oil on the track I wont be without one again.
Re: engine diaper
[Re: HEMIFRED]
#791279
09/03/10 12:18 AM
09/03/10 12:18 AM
dusturbd340W5
Kissimmee Fl.
I get the safety argument about having 1 but I am just looking at letter of the way it is written and if I am required to run 1 or not from the way I see it it's not required with me running a bracket super pro car running slower than 7.50.
Re: engine diaper
[Re: Thumperdart]
#791285
09/03/10 05:00 AM
09/03/10 05:00 AM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
There are some tracks that are requiring them on their own track rules. They don't need the down time, nor the cost of clean ups.. I have a russler also. great guy. Good ol racer.. Chris..
Re: engine diaper
[Re: Chris'sBarracuda]
#791286
09/03/10 08:04 AM
09/03/10 08:04 AM
Posts: 6,314 The Swamp
MegaDart
The Swamp
that is exactly the case at most tracks I race at, 9.99 and quicker they are required
Re: engine diaper
[Re: dusturbd340W5]
#791291
09/03/10 08:37 PM
09/03/10 08:37 PM
MegaDart
The Swamp
It shows the diaper has to be recerted every year that's as bad as every 2 years on the belts
IMO, it is a good rule and was long overdue. As for the recert only Top Sportsman, Top Dragster and faster require SFI certed diapers. You will be fine with just a sportsman diaper.
Re: engine diaper
[Re: MegaDart]
#791292
09/03/10 09:10 PM
09/03/10 09:10 PM
Chris'sBarracuda
Arizona
What he said..
Re: engine diaper
#791293
09/03/10 09:19 PM
09/03/10 09:19 PM
dusturbd340W5
Kissimmee Fl.
so the sportsman's is just a 1 time purchase.
