3" or 3˝" borla or magnaflow mufflers blown smallblock #790737
09/02/10 01:53 PM
09/02/10 01:53 PM
sweden
1Fast340 Offline OP
1Fast340  Offline OP
sweden
what size exhaust would be enough for a twinscrewblown 340 at about 14pounds of boost ? small solidroller 242/248@.050 .570/.576 lift ported edelbrock heads and 1 7/8" primary headers on ethanol
3" or 3˝"
borla or magnaflow? i want straight thru but not sure if the packing in the magnaflows will survive the heat for very loong since this thing will be driven to the track and back and to local cruisenights alot
looking at either the 18"body magnflows or 16" body borla mufflers
i realize this wont be a quiet car by any means but trying to keep it at a level wich is tolerable
any sugestions ?
also im not made out of money for some odd reason but i dont mind spending the extra money if the quality diferens is there to justify it
thanks
Re: 3" or 3˝" borla or magnaflow mufflers blown smallblock [Re: 1Fast340] #790738
09/02/10 02:04 PM
09/02/10 02:04 PM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
I would go 3.5" Magnaflow with an X-pipe (If 3.5" pipe will fit). I have never disliked the way a car sounds with Mangaflow mufflers. The X-pipe will aid in taming the exhaust note as well as help flow.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: 3" or 3˝" borla or magnaflow mufflers blown smallblock [Re: 1Fast340] #790739
09/02/10 02:12 PM
09/02/10 02:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What size is the collector and how many revs do you turn
Re: 3" or 3˝" borla or magnaflow mufflers blown smallblock [Re: MR_P_BODY] #790740
09/02/10 02:17 PM
09/02/10 02:17 PM
sweden
1Fast340 Offline OP
1Fast340  Offline OP
sweden
collectors are 3" but will cut them of and weld on some 3˝" collectors if it would make a diference in power that is noticeable engine is still waiting to be finnished but i think this thing may peak around 7-7500rpms same combo as NA motor realy liked being shifted at alitle over 7000rpms while my thinking is that the blower will shift the powerband even higher since it should take away any limitation the heads are to the rpm.
Re: 3" or 3˝" borla or magnaflow mufflers blown smallblock [Re: 1Fast340] #790741
09/02/10 02:21 PM
09/02/10 02:21 PM
sweden
1Fast340 Offline OP
1Fast340  Offline OP
sweden
and i dont see a problem with making 3˝" tubing fit the car,if anything is in the way i will make it work anyway i dont mind massaging the car alitle when it makes a diference
Re: 3" or 3˝" borla or magnaflow mufflers blown smallblock [Re: 1Fast340] #790742
09/02/10 08:15 PM
09/02/10 08:15 PM
Toronto
mshred Offline
mshred  Offline
Toronto
if you want quiet go with the magnaflows...my 3 inch xr-1's on a mild 340 with an x pipe are anything but quiet
Re: 3" or 3˝" borla or magnaflow mufflers blown smallblock [Re: mshred] #790743
09/02/10 10:53 PM
09/02/10 10:53 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
I can't say the magnaflows are quiet. Heck, my 2 chamber flowmasters were about the same.
Re: 3" or 3˝" borla or magnaflow mufflers blown smallblock [Re: mshred] #790744
09/03/10 05:19 PM
09/03/10 05:19 PM
sweden
1Fast340 Offline OP
1Fast340  Offline OP
sweden
yep but you have the shortest ones from what i remember another 4" of mufflerbody should help some in that department, i have heard your car from youtube and it sound real good
and not that picky on being quiet just want it somewhat tolerable
Re: 3" or 3˝" borla or magnaflow mufflers blown smallblock [Re: MR_P_BODY] #790745
09/03/10 05:20 PM
09/03/10 05:20 PM
sweden
1Fast340 Offline OP
1Fast340  Offline OP
sweden
Re: 3" or 3˝" borla or magnaflow mufflers blown smallblock [Re: gsmopar] #790746
09/03/10 05:23 PM
09/03/10 05:23 PM
sweden
1Fast340 Offline OP
1Fast340  Offline OP
sweden
thats some nice work what brand is that x-pipe? im not all that in love with the x-pipe sound but power and streetability in the same package is nice
also i will probably have my exhaust go all the way out the back with some turndowns just sticking out under the bumper and from the experience i have with exhaust i have learnt that pipes all the way out behind the car helps alot with soundlevels
Re: 3" or 3˝" borla or magnaflow mufflers blown smallblock [Re: 1Fast340] #790747
09/03/10 07:37 PM
09/03/10 07:37 PM
Toronto
mshred Offline
mshred  Offline
Toronto
true, i do have the smallest one because i wanted the loudest sound lol...the clips i have on youtube are actually very quiet compared to it in person...they are loud! all i know is that gauging from what i have heard many say, the magnaflows will be the quieter of the two in general, while still sounding good and delivering awesome power...but man, i love how my borla's sound, i can just imagine them on your setup
Re: 3" or 3˝" borla or magnaflow mufflers blown smallblock [Re: mshred] #790748
09/04/10 10:00 AM
09/04/10 10:00 AM
sweden
1Fast340 Offline OP
1Fast340  Offline OP
sweden
now you make me feel old i used to realy like loud:p now i prefer it álitle more melow unless it will cost me power
its a shame it seems like the borla mufflers are so much louder,when i realy like the quality of borla compared to magnaflow,wich isnt realy bad but still diferent levels so to speak..
yeah i think they would sound bada$$ on my build wich i think will be just alitle wilder than yours but not all that much
Re: 3" or 3˝" borla or magnaflow mufflers blown smallblock [Re: 1Fast340] #790749
09/04/10 12:52 PM
09/04/10 12:52 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Thanks!
Pypes 3.5 in X-pipe kit and Magnaflow race mufflers.
Re: 3" or 3˝" borla or magnaflow mufflers blown smallblock [Re: gsmopar] #790750
10/17/10 01:05 PM
10/17/10 01:05 PM
sweden
1Fast340 Offline OP
1Fast340  Offline OP
sweden
ok i have decided i dont care about if the borla mufflers are louder and i dont care they are more expensive than magnaflows since im putting enough money into this stuff everywhere so a few 100$ more on mufflers are not a big thing even if im not made out of money
any advice on whats the diference betwen the XR1 raceline multicore mufflers and the sportsman series? its a pretty good diference in price
looking at the 16" long body mufflers,i think i will use an X-Pipe even if i dont realy like the sound of the X and exhaust will end in front of the wheels or out the back of the car have not decided on that yet
Re: 3" or 3˝" borla or magnaflow mufflers blown smallblock [Re: 1Fast340] #790751
10/18/10 11:20 AM
10/18/10 11:20 AM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
Haven't installed mine yet but they were not too loud on my buddy's big block with 3 1/2 full exhaust.
There big mothers though
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: 3" or 3˝" borla or magnaflow mufflers blown smallblock [Re: megajoltman] #790752
10/18/10 12:10 PM
10/18/10 12:10 PM
La Vernia, Texas
Pat7272 Offline
Pat7272  Offline
La Vernia, Texas
Are those the sportsman or multi-core?
Re: 3" or 3˝" borla or magnaflow mufflers blown smallblock [Re: Pat7272] #790753
10/18/10 01:47 PM
10/18/10 01:47 PM
sweden
1Fast340 Offline OP
1Fast340  Offline OP
sweden
3˝" not being loud they must be good
Re: 3" or 3˝" borla or magnaflow mufflers blown smallblock [Re: 1Fast340] #790754
10/18/10 04:36 PM
10/18/10 04:36 PM
megajoltman Offline
megajoltman  Offline
Sportsman
Case Length (in) 16.000 in.
Overall Length (in) 19.000 in.
Thickness (in) 4.250 in.
Width (in) 7.850 in.
My daily driver is a 12V cummins 4x4 so my not too loud might be different then your not too loud
Procharged 350Z
Re: 3" or 3˝" borla or magnaflow mufflers blown smallblock [Re: megajoltman] #790755
10/18/10 05:05 PM
10/18/10 05:05 PM
sweden
1Fast340 Offline OP
1Fast340  Offline OP
sweden
Sportsman
hey its cheating to use one of those boostproducing mufflers in front of the regular muffler
Re: 3" or 3˝" borla or magnaflow mufflers blown smallblock [Re: 1Fast340] #790756
10/18/10 10:04 PM
10/18/10 10:04 PM
Cab_Burge Online work
Cab_Burge  Online Work
I have a set of 3x14 Magnaflows on my N/A 518 C,I. low deck stroker street Duster that has ran 10:34 at 128.6 MPH through the muffs on Oregon pump gas, the muffs are mounted behind the rear end at the rear bumper. The further back you mount the mufflers the quieter it will be and not affect back pressure due to having more pipes behind the muffs I do have a new set of the 14x3.5 stainless Magnaflow Ultra, they look just like the picture of the Sportmans Borla
