stock 98 318 vs comp XR265, results
#789319
08/31/10 05:01 PM
08/31/10 05:01 PM
Posts: 1,397 Toronto Ontario, Can
Glen440
I ran my Volare with a stock 98 318 with airgap intake,750 vac carb, headers, 3000 stall, 727 and 4.10 gear a couple weeks ago and it was running 14.4@ 94 mph.
I did only a cam and valve spring change and went back. I put the Comp XR265 in it. its .506/.506 216/224 @.050 and 265/273 adv duration.
Car ran some 13.5's @ 102.5 mph. Still running 2.0 60' so I know there is more in it. I did not play with it as I was racing. I lost 4th round with a breakout
Was a real good gain.
87 dakota 6.1 hemi
Re: stock 98 318 vs comp XR265, results
[Re: Glen440]
#789320
08/31/10 05:16 PM
08/31/10 05:16 PM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
8mph and almost 1 second increase from a cam change? Very nice How much does you car weigh?
[Re: HotRodDave]
#789321
09/01/10 12:31 AM
09/01/10 12:31 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Any cam change is an upgrade from the stock Magnum cams. They barely bump the valves off their seat. Is the new cam a roller too? Killer improvement Glen. Any modifications to the heads to run the higher lift? Few can claim a one second improvement from one mod.
[Re: Magnum]
#789322
09/01/10 01:27 AM
09/01/10 01:27 AM
HotRodDave
Kalispell Mt.
The comp XR cams are hydraulic roller cams.
I don't know what springs he used but the GM V6 springs can handle that with no mods to the heads. I think huges also sells springs that will work as well as mopar performance.
[Re: HotRodDave]
#789323
09/01/10 05:42 PM
09/01/10 05:42 PM
Glen440
Car is around 3400lbs.
I used hughes 1110 springs with their retainers. I had .045 clearance to the valve seal at full lift. Was around .550 with valve shut.
My cam selection was based mostly on not taking the heads off.
Once I get the 60' sorted out I expect low 13's and better air will help as well.
87 dakota 6.1 hemi
[Re: HotRodDave]
#789324
09/01/10 05:50 PM
09/01/10 05:50 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
good results! who says you need a big cam to go fast? my junk is similar to yours, but in a heavier 5th ave, with 3.55's and an A500 (low first gear). my cam is a reground stocker, it's 208@.050and .506" lift......both our cams are pretty aggressive, lobe wise. mine is 259@.006" lift, [Email]208@.050[/Email], and 127@.2" with .318" lobe lift....yours, according to the comp lobe catalog (looks to be lobe #3303) is 265@.006", 216@.050, and 136"@.200" with the same lobe lift. for comparison to a flat tappet hydraulic, a comp XE262 is 262@.006, 218@.050, 130@.200", with .308" lobe lift, while an XE268 is 268@.006", 224@.050, and 137@.200" with .318" lobe lift. could you snap a pic of the retainers next time you have the valve cover off?
[Re: patrick]
#789325
09/03/10 12:06 PM
09/03/10 12:06 PM
Glen440
The retainer is just a plain steel retainer for the 8mm valve stem and a single spring. I will be in the valve covers at some point and will snap a pic. An interesting thing I noticed is what happened to the cylinder pressure. I had 180 before the swap and 155 after. This engine had 270 000km on it before I did rings and bearings. It really should have gotten a bore and new pistons as the cylinders are not round anymore. I'm sure if it was healthier and with a zero deck piston I could likely hit high 12's. I had a big block in this car that was slower
87 dakota 6.1 hemi
[Re: Glen440]
#789326
09/03/10 12:20 PM
09/03/10 12:20 PM
patrick
Grand Haven, MI
I was just wondering if the retainer had any dish or was a flat steel retainer...did you measure what your installed height was with their retainers? IIRC mine, the 2.2L retainers with no valve job done to the head was ~1.60"...I purposely had the seats sunk a skoash to get 1.63" IH.
my regrind is in that same range, compression check of 155-160 or so.
in hind sight, I kinda wish I woulda decked the block .040. mine was .055" in the hole, which currently yields 9:1 comp even. had I decked it .040, I'd have about 10:1 with .043" quench (using the thin Mr. gasket head gaskets)....
one thing I forgot to do on mine was replace the freeze plugs on the block, and now one is leaking
that's awesome to see a nearly stock 'teen outmuscle a big block!
[Re: patrick]
#789327
09/03/10 02:45 PM
09/03/10 02:45 PM
Posts: 760 Texas
TexasStroker
mopar addict
mopar addict
Texas
[Re: patrick]
#789328
09/03/10 02:56 PM
09/03/10 02:56 PM
Glen440
They are a flat retainer. I did not measure installed height, the heads do have a valve job. I also used the head gasket that came in the gasket set from chrysler and was around .060 thick. We were laughing when I measured it. I have no idea how much valve to piston clearance it has, would love to set quench at .040.
87 dakota 6.1 hemi
