Would you run this head? #789183
08/31/10 01:30 PM
08/31/10 01:30 PM
Colo
P
PJ68RT Offline OP
PJ68RT  Offline OP
P
Colo
Casting flaw in the intake port. Would be going on a mild 440 build. Approx. 425-450 HP. What do ya think? Would this cause issues with leakage? Affect HP?
Re: Would you run this head? [Re: PJ68RT] #789184
08/31/10 01:38 PM
08/31/10 01:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Lay a gasket on it but I'm sure it will seal so yes
I would run it
Re: Would you run this head? [Re: PJ68RT] #789185
08/31/10 01:45 PM
08/31/10 01:45 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Seen a few like that, should be fine.
Re: Would you run this head? [Re: buildanother] #789186
08/31/10 02:48 PM
08/31/10 02:48 PM
North Carolina
K
keelsracing Offline
keelsracing  Offline
K
North Carolina
have had one with a piece missing between both ports and did not know untill intake was removed that it was like this and could not see anything wrong
so in closing you shoud be fine to run this
Re: Would you run this head? [Re: PJ68RT] #789187
08/31/10 04:25 PM
08/31/10 04:25 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Seal it and run it.
RIP Monte Smith
