what hp is needed for 6.50/6.00 in the 1/8mile #788917
08/31/10 12:21 AM
08/31/10 12:21 AM
nc
E
earthmover Offline OP
E
nc
hay guys what hp will we need to run this 1972 dart swinger in the 6.50/6.00 range in the 1/8mile..car will be ladder bar with coil oversand as light as possible.power plant will be 400 block the inches are in the air right now with some good aluminum heads and a roller cam..thanks mike
Re: what hp is needed for 6.50/6.00 in the 1/8mile [Re: earthmover] #788918
08/31/10 12:23 AM
08/31/10 12:23 AM
Bama
Randy.. Offline
Randy..  Offline
Bama
the lighter you are the less HP you will need, whats your goal for weight?
Re: what hp is needed for 6.50/6.00 in the 1/8mile [Re: Randy..] #788919
08/31/10 12:43 AM
08/31/10 12:43 AM
nc
E
E
nc
i dont know as far as weight goes i dont even know what it weights now. just picked it up sat. its a 72 dart swinger . would be nice 3000 or under.. we are going to try for some fiber glass parts along the way with 2 race seats and a cage ,back will be ladder bars with stock frame rails, thanks mike
Re: what hp is needed for 6.50/6.00 in the 1/8mile [Re: earthmover] #788920
08/31/10 12:51 AM
08/31/10 12:51 AM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
Do you want to go 6.50 or 6.00 in the 1/8 mile?
6.50 will take about 560-575 hp @ 3000lbs
As for 6.00, i'll let you know when i get there... But i'm guessing over 700hp at 3000lbs
Be forewarned, anything quicker than 6.40 in the 1/8 will require certified,caged car, NHRA license, etc...
Re: what hp is needed for 6.50/6.00 in the 1/8mile [Re: earthmover] #788921
08/31/10 12:52 AM
08/31/10 12:52 AM
Bama
Randy.. Offline
Randy..  Offline
Bama
ck the wallace racing calculator. think you will need around 750 hp.
Re: what hp is needed for 6.50/6.00 in the 1/8mile [Re: earthmover] #788922
08/31/10 01:28 AM
08/31/10 01:28 AM
iowa
wesw Offline
wesw  Offline
iowa
this 69 dart is 3200 lbs with 500ci indy 440-1 heads. makes right at 750 hp. all steel but the hood with full cage, sfi to 8.50. 4-link car, 29.5x10.5W. it runs 6.20s @ 111 mph in the 1/8. it should go 6.0s with a little more tuning on it.
my son and i drive it for a friend of ours. he can't pass the competition lic.
598 ci predator
Re: what hp is needed for 6.50/6.00 in the 1/8mile [Re: earthmover] #788923
08/31/10 01:34 AM
08/31/10 01:34 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I put a measley 495 hp and tq at the tires w/my 72 dart and 470 stroker and have been 6.22`s at 109+ and that`s at 3150 lbs ready to race. Heard loose verts give inaccurate numbers though so who knows.
Re: what hp is needed for 6.50/6.00 in the 1/8mile [Re: Thumperdart] #788924
08/31/10 02:08 AM
08/31/10 02:08 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
my junk does 6.0's almost everytime at 112mph. it weighs 2950 with my fat ass in the chair & we're guessing it's about 720-730 hp with the undersized carb on it. rear gears are 4.8's with 32x14 slicks & a 5500 verter. common 60's are 1.38 & we pull the shifter at 7k.
Re: what hp is needed for 6.50/6.00 in the 1/8mile [Re: rebel] #788925
08/31/10 05:34 AM
08/31/10 05:34 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...Only pic I have handy, my tube chassis street car. It's been 5.99/115/1.33 with a serious pump gas motor (10.28 comp). Did those number's with race gas. Weight is about 2625 with me, 2700 with street trim. Been on the street for ~ 6 yrs. Guessed 695-725 hp @ motor, don't know. 499ci, program caps, Indy-1 350cfm, ported intake,1050 carb,old Herb Mcandless/Ken Lasari roller,glide,4.56, & can set in traffic all day, serious!
...Note: the red hoses go to my small heater inside the car.
Re: what hp is needed for 6.50/6.00 in the 1/8mile [Re: thehemikid] #788926
09/01/10 11:35 PM
09/01/10 11:35 PM
nc
E
E
nc
ok guys this is what i was thinking on the start of the build let me know what you would do or change to make this combo work.
car is 1972 dart
plan is to put fiber glass on the hood deck maybe fenders,keep stock glass, gonna keep stock frame rails and ladder bar the car,open wheel tubs up to fit as large a tire as possible,8 gal cell,cage.
motor 400 stroked 451/493 not sure yet
alum. rods as long as possible,short piston as light as possible
inter. bal. ass. crank will be forged
heads we're in the air first big block project but thought about the pro comps/ez/1s
cam will be a roller with the roller rockers
single plane intake with 4500 top if possible
727 worked over with a brake init 8' verta with some 4.56 gears...
add in what you think on this como please, my first big block and looking points from you fast guys....i like the build above
Re: what hp is needed for 6.50/6.00 in the 1/8mile [Re: earthmover] #788927
09/02/10 01:20 PM
09/02/10 01:20 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I think your list looks good. I would use -1's and a 274-280 @ .050 cam my
Re: what hp is needed for 6.50/6.00 in the 1/8mile [Re: earthmover] #788928
09/02/10 01:45 PM
09/02/10 01:45 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...It seems the Eddy heads are hard to beat for the $. I haven't used any myself, but i have a friend that has. His car is as light as mine, maybe lighter. He's motor is built healthier than mine (track only). He's down deeper in the 5's, last i remember 5.70's. He's was running a Toilet on Alky too, (more torq, more consistent) he was S/P Champ 3 out of 4yrs, ...deadly! "The Man". I think he was using the RPM head, the Vic's weren't out yet at that time.
Re: what hp is needed for 6.50/6.00 in the 1/8mile [Re: thehemikid] #788929
09/02/10 02:29 PM
09/02/10 02:29 PM
Q
Quicktree Offline
Quicktree  Offline
Q
my challenger runs 6.50s @ 3000lbs and I will be lucky to make 500hp. stock stroke 360 with good heads and a street roller.
Re: what hp is needed for 6.50/6.00 in the 1/8mile [Re: Quicktree] #788930
09/02/10 02:45 PM
09/02/10 02:45 PM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
I have been 6.02 in the 1/8
493, 12.8:1, indy cam R2 I think, 440-1 heads, indy intake, 1050, 8in PTC, 4:30 gear dana on 325 drag radials. best 60' of 1.29. 3380 Race weight. Drive it on the street a good bit. Horespower??? I have no idea.
Re: what hp is needed for 6.50/6.00 in the 1/8mile [Re: RonP] #788931
09/02/10 03:57 PM
09/02/10 03:57 PM
nc
E
E
nc
thanks guys i didnt know the vic. where cap. of doing that so ill look into them as well.. that might save a few $ to use somewhere else....
hay Ron hows it going was hopeing you jump in i talk to you i think last year at the farmington mopar show we where on our way out the gate and stopped by to talk me and a few buddies....that thing you got really goes....
thanks guys and keep it coming in the combo....
does anybody have any idea of how much this 72 dart weight with all steel. i know i gotta get it out to weight it just kicks ...thanks mike
Re: what hp is needed for 6.50/6.00 in the 1/8mile [Re: earthmover] #788932
09/02/10 04:25 PM
09/02/10 04:25 PM
Y-town ohio
68valiant68 Offline
68valiant68  Offline
Y-town ohio
Indy has the 470 stroker kit for $1495! Or call bob George he has quite a few shortblocks ready to go! He is also an Indy dealer if you want a kit.
Re: what hp is needed for 6.50/6.00 in the 1/8mile [Re: earthmover] #788933
09/02/10 04:39 PM
09/02/10 04:39 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
http://www.edelbrock.com/automotive_new/mc/cylheads/chrysler/main_chrysler_bb.shtml
...I'm not steering you towards the Eddy's just helping with info.
...Then there's the B1 head.
Re: what hp is needed for 6.50/6.00 in the 1/8mile [Re: thehemikid] #788934
09/02/10 04:59 PM
09/02/10 04:59 PM
nc
E
E
nc
thanks i looked over on hughes site and they have them cnc ported as well.good info
getting some good ideas and info to start collecting parts for the build
also thats a pretty good price on the kit all the 1s i have seen was over 1700.00 thanks mike
come on with the combos guys
Re: what hp is needed for 6.50/6.00 in the 1/8mile [Re: earthmover] #788935
09/02/10 05:38 PM
09/02/10 05:38 PM
Swamps of South Jersey.
W
wildcargo Offline
wildcargo  Offline
W
I have run 6.38 at 107mph with my 64B body at 3080 with driver. I used a .055 over 440, a 620-MP cam, a set of E-heads shaved .060 and a set of Rross 14cc domes at 0 deck, and 950-HP on a victor intake. On leaf springs. It dont take mutch.
Go to my web site fo more info
Bud www.wildcar-go.itgo.com
64 DODGE
60' 1.433,
1/8 6.38 at 107.4,
1/4 10.08 at 132.02
foot brake, leaf springs
Re: what hp is needed for 6.50/6.00 in the 1/8mile [Re: earthmover] #788936
09/03/10 01:13 PM
09/03/10 01:13 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I had mine weighed at a divisional meet several years ago. all steel, all stock glass, w/small block 3402 with me in it I go 230lbs. When I put a bb in it I just factored in another 100lbs Now I'm all aluminum up front so I just factor back to 3402.
