rebuilt 440 running hot at idle #787937
08/30/10 11:08 AM
08/30/10 11:08 AM
Haymarket, VA
MOPARLZ Offline OP
MOPARLZ  Offline OP
Haymarket, VA
I have a rebuilt 440 that is running hot and it has electric dual fans that pulls 2500 cfm. Does anyone know how much CFM the factory fans pull???
The motor has about 500HP and 550 T and is bored 40 over.
Re: rebuilt 440 running hot at idle [Re: MOPARLZ] #787938
08/30/10 11:36 AM
08/30/10 11:36 AM
gtx69 Offline
super gas
gtx69  Offline
super gas
Fans came off of what?
Re: rebuilt 440 running hot at idle [Re: gtx69] #787939
08/30/10 11:40 AM
08/30/10 11:40 AM
Haymarket, VA
MOPARLZ Offline OP
MOPARLZ  Offline OP
Haymarket, VA
I'm working on a 68 Charger and the fans are new from summit eletric flx-210 part number.
Re: rebuilt 440 running hot at idle [Re: MOPARLZ] #787940
08/30/10 11:40 AM
08/30/10 11:40 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
what's the timing set at? have you opened the rad to remove any air pockets? upper and lower hoses staying open? Some of the cheap ones will collapse and restrict water flow. Also what H2O pump? Some have had issues w/ the 440 Source pump.
Coming soon!!!!
Re: rebuilt 440 running hot at idle [Re: Mr.Yuck] #787941
08/30/10 11:51 AM
08/30/10 11:51 AM
Haymarket, VA
MOPARLZ Offline OP
MOPARLZ  Offline OP
Haymarket, VA
I retarded the timing some and I don't have the right type light to tell and I opened the rad and let it run while adding some water to make sure no pockets. The hoses are not collaping and a high flow pump not sure as to which one. I just got the car last friday night.
Re: rebuilt 440 running hot at idle [Re: MOPARLZ] #787942
08/30/10 11:51 AM
08/30/10 11:51 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Sometimes the dual electrics can't get it done and need to pull through the entire core of rad.
Re: rebuilt 440 running hot at idle [Re: buildanother] #787943
08/30/10 11:52 AM
08/30/10 11:52 AM
Haymarket, VA
MOPARLZ Offline OP
MOPARLZ  Offline OP
Haymarket, VA
getting a few people telling me to go back to the factory stuff that the electric fans just can't cool as well. That why I was wondering what cfm they pulled.
Re: rebuilt 440 running hot at idle [Re: MOPARLZ] #787944
08/30/10 12:03 PM
08/30/10 12:03 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
If you have it..put it back on and give it a try. Any reason you went w/ the electric?
Re: rebuilt 440 running hot at idle [Re: Mr.Yuck] #787945
08/30/10 12:22 PM
08/30/10 12:22 PM
Haymarket, VA
MOPARLZ Offline OP
MOPARLZ  Offline OP
Haymarket, VA
I don't have the stuff to go back to factory. I bought the car with the electric fans on it. The guy I bought it from installed new motor and got tired of trying to work out the bugs. It had no power brakes and was missing bad when I got it. I replace the valve in the brake boost since it was bad and I know have brakes and replace the boots on the plugs that burnt from being to close to the headers.
Re: rebuilt 440 running hot at idle [Re: MOPARLZ] #787946
08/30/10 12:41 PM
08/30/10 12:41 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Those fans will never cool that motor, not even with a shroud which you also need. Stock is best when it comes to cooling old Mopars.
Re: rebuilt 440 running hot at idle [Re: Challenger 1] #787947
08/30/10 12:44 PM
08/30/10 12:44 PM
Haymarket, VA
MOPARLZ Offline OP
MOPARLZ  Offline OP
Haymarket, VA
guess I will go back I see yearone only has 3 row rads should I go 4 row???
Re: rebuilt 440 running hot at idle [Re: MOPARLZ] #787948
08/30/10 01:32 PM
08/30/10 01:32 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Save your money. Check e-bay if you think you need a Rad. I'd get a good fan and shroud 1st. You can probably find nice used items in the parts section here.
Coming soon!!!!
Re: rebuilt 440 running hot at idle [Re: MOPARLZ] #787949
08/30/10 02:06 PM
08/30/10 02:06 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
My 498 ran hot in traffic/hot days...cool down the road...(alum rad) final fix was shroud,7 blade steel clutch fan..car runs nice and cool in traffic....champion alum radiator...2 one inch rows...cheap price but does the same job a 700 alum rad does. Can't say enough good things about it
Re: rebuilt 440 running hot at idle [Re: terzmo] #787950
08/30/10 02:19 PM
08/30/10 02:19 PM
Haymarket, VA
MOPARLZ Offline OP
MOPARLZ  Offline OP
Haymarket, VA
I already have aluim rad so I will try a fan and see what happens.
Re: rebuilt 440 running hot at idle [Re: MOPARLZ] #787951
08/30/10 03:10 PM
08/30/10 03:10 PM
hooziewhatsit Offline
Can you define what temperature 'hot' means to you? To some people it's 180*. To others it's 215*.
Re: rebuilt 440 running hot at idle [Re: hooziewhatsit] #787952
08/30/10 03:12 PM
08/30/10 03:12 PM
Haymarket, VA
MOPARLZ Offline OP
MOPARLZ  Offline OP
Haymarket, VA
200 degree's and On saturday it got to 220 degree's.
Re: rebuilt 440 running hot at idle [Re: MOPARLZ] #787953
08/30/10 09:15 PM
08/30/10 09:15 PM
Morris County NJ
Rustydog Offline
Rustydog  Offline
Morris County NJ
Do you have an overflow bottle?
If so are there bubbles comming out of the overflow hose in the overflow container?
I have seen bad head gaskets leak compression into the water jacket. That will always cause an overheat situation. Worse yet, instead of a bad head gasket there maybe a crack somewhere that allows compression to go into the water jacket. Don't assume that you'll see white smoke out of the exhaust. Coolant may not be able to get into the combustion chamber.
Re: rebuilt 440 running hot at idle [Re: Challenger 1] #787954
08/30/10 11:36 PM
08/30/10 11:36 PM
IN
ahy Offline
ahy  Offline
IN
The stock setup moves a lot of air and works well. First priority is a clutch fan and shroud. You may score one at a JY or you can find it at Mancini. Add a new radiator only if needed.
The MP clutch fan kit from Mancini includes a 5 blade fan. It has low drag and works in many situations but some setups require a more aggressive fan. Bouchillon sells a 6 blade or you can find a 7 blade at a JY. I have one from a '78 Cordoba... which I didn't need as the 5 blade was enough.
