Hemi oil restrictor ? #787138
08/29/10 05:07 PM
08/29/10 05:07 PM
Odessa, Fl
blowndart Offline OP
Odessa, Fl
I'm in the process of rebuilding a hemi and noticed there are restrictors installed into the deck for the oil feeds to the heads. Should these be removed? I've read restrictors should not by used.
Also, I'm installing the intermediate shaft bushing and I can't remember if the grove cut into the center has to be in a particular orientation.
Re: Hemi oil restrictor ? [Re: blowndart] #787139
08/29/10 05:56 PM
08/29/10 05:56 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
I wouldn't remove the restrictors if this is a non world block. Hemi's need all the oil they can get up top especially the exhaust push rods with heavy valve springs.
Doesn't matter which way the slot in the bushing points.
Re: Hemi oil restrictor ? [Re: torkrules] #787140
08/29/10 06:07 PM
08/29/10 06:07 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
I would remove the restrictors if this is a non world block. Hemi's need all the oil they can get up top especially the exhaust push rods with heavy valve springs.
AND GROOVE #4 CAM JOURNEL FOR MORE OIL TO THE TOP
home of the
Sox and Martin Hemi Duster
Re: Hemi oil restrictor ? [Re: torkrules] #787141
08/29/10 06:29 PM
08/29/10 06:29 PM
Odessa, Fl
Odessa, Fl
Thanks. That's what I was thinking.
Re: Hemi oil restrictor ? [Re: blowndart] #787142
08/29/10 07:47 PM
08/29/10 07:47 PM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
That was common practice thirty years ago. Get them out of there....it never was necessary.
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
