I'm in the process of rebuilding a hemi and noticed there are restrictors installed into the deck for the oil feeds to the heads. Should these be removed? I've read restrictors should not by used.
Also, I'm installing the intermediate shaft bushing and I can't remember if the grove cut into the center has to be in a particular orientation.
