Re: QFT/Proform race carbs= lets hear the good/bad&ugly
[Re: Blown 68 R/T]
#785907
08/27/10 09:11 PM
08/27/10 09:11 PM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have a 1050 with Pro-Max stickers on it but it looks like all Quick fuel parts,bowls,plates,base plate and a Proform 1050 body. It runs and drives perfect for a street strip car I wouldn't hesitate to get one from QFT or Pro-Max Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Blown 68 R/T]
#785908
08/27/10 09:37 PM
08/27/10 09:37 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I sent my 1050 dom into QF for them to set up for E-85... worked perfect other than a minor jet change for the engine I ordered it for... I changed it over to another engine and had to do some work on it... so far its great
[Re: Dragula]
#785910
08/27/10 09:45 PM
08/27/10 09:45 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
my QFT has been great right out of the box a small jet change is all I have done to it.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: Dunnuck Racing]
#785912
08/27/10 11:11 PM
08/27/10 11:11 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
My Quick Fuel Q-750 was pig rich at idle, I changed air bleeds even drilled holes in the primaries, no help. Their customer service tried, but nothing worked. It's sitting on the shelf now. My Bigs 950HP is great , great customer service too .
[Re: BradH]
#785915
09/02/10 04:10 PM
09/02/10 04:10 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
I run a QF 4150 950 on my 499" in the Challenger and have been happy with it. It reacts to changes well. Also run a QF 850 on my Mom's 362" Duster and was faster than the Holley 750. I thought it might slow down because I figured it would be to big for the motor.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: 68LAR]
#785918
09/02/10 08:14 PM
09/02/10 08:14 PM
Posts: 17,923 Akron, Ohio
ProSport
Akron, Ohio
I ran 2 Quickfuel 750's on a tunnel ram and they were the best carbs I've ever used. All adjustments are solid, no play in them, set the idle and everything and never have to adjust it again. Also LOVED the big glass sight windows in the bowls, I could see the bowls fill to proper level from the drivers seat when the hood was up.
[Re: fullmetaljacket]
#785920
09/02/10 10:42 PM
09/02/10 10:42 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
if you go the "center section swap" route and use your holley plates and bowls.. make sure there is no interference with the base of the center section and the base plate.. some situations require you to file and or clearence the boss at the vacume port or other areas...to get the plate to set flat on the center section with out a vacumme leak.. the topic was just carb for carb swap.... but i thought id mention this based on experience. cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
