Car goes out of control? #784635
08/26/10 12:33 PM
08/26/10 12:33 PM
Chesterfield, MIch
Cuda67 Offline OP
super street
Cuda67  Offline OP
super street
Chesterfield, MIch
Thanks for any help.
I had BF Goodrich, now Coopers. (Sorry. The Goodrich didn't work either.) Tire pressure is 32 psi. When I launch and smoke the tires the rear goes to the right and keeps going farther no matter what I do. After a short distance I have to get out of it. It doesn't fish tail. The car is a Hemi powered 1965 coronet automatic. It has the race pinion snubber and heavy duty springs and std shocks. What can I do to make it go straight? (With slicks it goes straight.)
Re: Car goes out of control? [Re: Cuda67] #784636
08/26/10 12:42 PM
08/26/10 12:42 PM
USA
b54406barrel Offline
USA
If it went straight w/ goodrich tires, try swapping the new ones side to side. Sounds like maybe one is slightly larger diameter. Almost every car I've had though wants to fishtail w/street tires if I'm really roasting them.
Re: Car goes out of control? [Re: b54406barrel] #784637
08/26/10 01:04 PM
08/26/10 01:04 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I'm trying to figure out the problem ...
Re: Car goes out of control? [Re: Cuda67] #784638
08/26/10 01:11 PM
08/26/10 01:11 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
???? don't stand on it then. One should NEVER race a car on street tires. What's the point? want to go straight and hook-up, buy some slicks. I've only had a few cars that would track straight under full waffle.
"(With slicks it goes straight.)" then you're good
Coming soon!!!!
Re: Car goes out of control? [Re: Mr.Yuck] #784639
08/26/10 01:15 PM
08/26/10 01:15 PM
Lees Summit, MO
SmallHurst Offline
SmallHurst  Offline
Lees Summit, MO
Tell that to the Pure Stock and F.A.S.T. racers!!! That is part of the challenge. Mine washes to the left almost everytime in the burnout box, but is fine going down the strip.
Snarl softly and carry a BIG stick 1969 Hurst/Olds Pure Stock 13.23@ 103.1 and the a/c blows cold! Rusty Small
Re: Car goes out of control? [Re: Cuda67] #784640
08/26/10 01:17 PM
08/26/10 01:17 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Invest in a set of Cal-Tracs,....so that you can dial in the cars launch/squat/tracking characteristics
Re: Car goes out of control? [Re: DAYCLONA] #784641
08/26/10 01:25 PM
08/26/10 01:25 PM
USA
USA
That's what I use to do with my 'brand x' cars with slappers, which were usually Lakewoods. Just preload one a little more than the other & I could usually get them to go straighter. I don't know what you do with a single snubber. You could try to play with your tire pressure side-to-side a little but I wouldn't try more than 3 or 4 lbs or it could cup or ride on the center treads.
Re: Car goes out of control? [Re: b54406barrel] #784642
08/26/10 01:39 PM
08/26/10 01:39 PM
Oregon City, OR
Baxter61 Offline
Baxter61  Offline
Oregon City, OR
make sure your rear-end is straight also.
Re: Car goes out of control? [Re: Baxter61] #784643
08/26/10 02:34 PM
08/26/10 02:34 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
you shouldn't roast radial tires anyway, they seem to hook up best when only dry hopped a few times. if you roast them the rubber can ball up and cause less traction than with doing nothing at all.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Car goes out of control? [Re: SmallHurst] #784644
08/26/10 02:37 PM
08/26/10 02:37 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
yeah because those tires are totally real old style bias plys.
Re: Car goes out of control? [Re: Jerry] #784645
08/26/10 02:41 PM
08/26/10 02:41 PM
VA
DAMOPARS Offline
DAMOPARS  Offline
VA
I welded in frame rail and clamped the springs and it goes straight ,,, oh and good shocks.
Re: Car goes out of control? [Re: Mr.Yuck] #784646
08/26/10 03:56 PM
08/26/10 03:56 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Do you actually know anything about the tires they run ?
Re: Car goes out of control? [Re: JohnRR] #784647
08/26/10 06:09 PM
08/26/10 06:09 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
read a bit on them yes. and some of the "prep" work that is done
Coming soon!!!!
Re: Car goes out of control? [Re: Mr.Yuck] #784648
08/26/10 06:32 PM
08/26/10 06:32 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Link ? I like to see that ...
Re: Car goes out of control? [Re: Mr.Yuck] #784649
08/26/10 06:33 PM
08/26/10 06:33 PM
Alabama
BigMoneyLewis Offline
Alabama
I used to have a Road Runner with 4:30 gears without a sure grip. Right after I would launch I always had to turn the steering wheel about a half turn to the right. The car would track at about a 45 degree angle all the way through 1st, 2nd, and as it would finally gain traction I could straighten it up about 3rd gear .
Nothing to worry about. You will get used to it .
The spectators love it, your flagman will possibly need to change his underwear.
Greg
gregward@mchsi.com phone 256-852-0955
