Car goes out of control?
#784635
08/26/10 12:33 PM
08/26/10 12:33 PM
Posts: 353 Chesterfield, MIch
Cuda67
super street
super street
Chesterfield, MIch
Thanks for any help. I had BF Goodrich, now Coopers. (Sorry. The Goodrich didn't work either.) Tire pressure is 32 psi. When I launch and smoke the tires the rear goes to the right and keeps going farther no matter what I do. After a short distance I have to get out of it. It doesn't fish tail. The car is a Hemi powered 1965 coronet automatic. It has the race pinion snubber and heavy duty springs and std shocks. What can I do to make it go straight? (With slicks it goes straight.)
Re: Car goes out of control?
[Re: DAYCLONA]
#784641
08/26/10 01:25 PM
08/26/10 01:25 PM
Posts: 3,054 USA
b54406barrel
USA
Invest in a set of Cal-Tracs,....so that you can dial in the cars launch/squat/tracking characteristics
That's what I use to do with my 'brand x' cars with slappers, which were usually Lakewoods. Just preload one a little more than the other & I could usually get them to go straighter. I don't know what you do with a single snubber. You could try to play with your tire pressure side-to-side a little but I wouldn't try more than 3 or 4 lbs or it could cup or ride on the center treads.
[Re: SmallHurst]
#784644
08/26/10 02:37 PM
08/26/10 02:37 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
???? don't stand on it then. One should NEVER race a car on street tires. What's the point?
Tell that to the Pure Stock and F.A.S.T. racers!!! That is part of the challenge. Mine washes to the left almost everytime in the burnout box, but is fine going down the strip.
yeah because those tires are totally real old style bias plys.
[Re: Mr.Yuck]
#784646
08/26/10 03:56 PM
08/26/10 03:56 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
Do you actually know anything about the tires they run ?
[Re: JohnRR]
#784647
08/26/10 06:09 PM
08/26/10 06:09 PM
Mr.Yuck
Brookeville, Md
read a bit on them yes. and some of the "prep" work that is done
