Modified Hemi 4 speed ? #781841
08/23/10 09:07 PM
08/23/10 09:07 PM
Bergen County NJ
N
NoJoke Offline OP
NoJoke  Offline OP
N
Bergen County NJ
I have a 1969 Cuda 440 with a Hemi 18 spline trans in it. I was wondering who here has modified one on the street with making it a crash box or face plating? I'm looking to redo the trans because I'm having shifting issues under high RPM and trans popping out of gear sometimes... I thought possibly going to a G-Force or Richmond 5sp. Please give me some input on what you guys have done or have had experience in the past.
Rob
Re: Modified Hemi 4 speed ? [Re: NoJoke] #781842
08/23/10 09:08 PM
08/23/10 09:08 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Done several.
Call me.
Re: Modified Hemi 4 speed ? [Re: HPMike] #781843
08/23/10 09:12 PM
08/23/10 09:12 PM
Bergen County NJ
N
NoJoke Offline OP
NoJoke  Offline OP
N
Bergen County NJ
Hey Mike we spoke you'll be doing the trans I was getting some feedback. We have been both busy to catch up.
Re: Modified Hemi 4 speed ? [Re: NoJoke] #781844
08/23/10 09:48 PM
08/23/10 09:48 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Do the face-plate on third and fourth at least
First and second can be slick or pro-shift.
I had my Richmond face-plated and it works perfectly
Gus
64 Plymouth Savoy
Dana 60
Re: Modified Hemi 4 speed ? [Re: fourgearsavoy] #781845
08/23/10 10:09 PM
08/23/10 10:09 PM
Bergen County NJ
N
NoJoke Offline OP
NoJoke  Offline OP
N
Bergen County NJ
Gus
Did you run the car on the street also or just raced it?
Re: Modified Hemi 4 speed ? [Re: NoJoke] #781846
08/23/10 10:47 PM
08/23/10 10:47 PM
Rittman Ohio
Rittman Ohio
Gus
I run it hard on the street and full throttle on the track leaving on the 2-step and it holds up well and doesn't miss a gear with a Long V-gate shifter.Make sure you get the HD Liberty modified side cover if you go with the 833 trans
Gus
64 Plymouth Savoy
Dana 60
Re: Modified Hemi 4 speed ? [Re: fourgearsavoy] #781847
08/24/10 12:02 AM
08/24/10 12:02 AM
Bergen County NJ
N
NoJoke Offline OP
NoJoke  Offline OP
N
Bergen County NJ
What clutch do you run in your car?
Re: Modified Hemi 4 speed ? [Re: fourgearsavoy] #781848
08/24/10 06:38 PM
08/24/10 06:38 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Gus
Gus
what is the benefit of that side cover, less case flex?
Re: Modified Hemi 4 speed ? [Re: NoJoke] #781849
08/24/10 09:03 PM
08/24/10 09:03 PM
Rittman Ohio
Rittman Ohio
I am currently just running an old school Hays MK XII plate and a Ram sprung hub bronze disc.It does good on the street but it bites too hard for the track.
Gus
64 Plymouth Savoy
Dana 60
Re: Modified Hemi 4 speed ? [Re: fourgearsavoy] #781850
08/24/10 09:06 PM
08/24/10 09:06 PM
Bergen County NJ
N
NoJoke Offline OP
NoJoke  Offline OP
N
Bergen County NJ
I have the McCleod dual disc set up boy there is no slippage at all with that set up... I noticed when it heats up there is no easing out at a red light car just jumps off the line...
Re: Modified Hemi 4 speed ? [Re: mshred] #781851
08/24/10 09:09 PM
08/24/10 09:09 PM
Rittman Ohio
Rittman Ohio
Gus
Gus
The cover is just a modified stock unit.The shift lever shafts are tool steel and they aren't machined for O-rings.They also have been upgraded with 3/8"threads for increased strength where you fasten the levers instead of the wimpy 5/16" stockers.The cover is machined for a positive lip seal that you can replace from the outside if it ever leaks
Gus
64 Plymouth Savoy
Dana 60
Re: Modified Hemi 4 speed ? [Re: HPMike] #781852
08/24/10 09:12 PM
08/24/10 09:12 PM
Connecticut
5126brl No more Offline
Connecticut
Done several.
Call me.
Just give it to HPMIKE and then ENJOY!!!
I love the one he did for me,, Shifts like a dream!! Get a nice Ramrod shifter and never think about a missed shift again!!
Re: Modified Hemi 4 speed ? [Re: NoJoke] #781853
08/24/10 09:13 PM
08/24/10 09:13 PM
Rittman Ohio
Rittman Ohio
I had one in the car for a while until I started breaking sliders and gears,I split 2 third gear sliders and trimmed all the teeth off third gear before I realized it was too stiff for racing use with traction
Gus
64 Plymouth Savoy
Dana 60
Re: Modified Hemi 4 speed ? [Re: 5126brl No more] #781854
08/24/10 09:14 PM
08/24/10 09:14 PM
Bergen County NJ
N
NoJoke Offline OP
NoJoke  Offline OP
N
Bergen County NJ
Mike will be doing my trans 100% Im just getting some feedback from some of the other mopar owners what they run... I heard nothing but great things about him and his work and the best part about it he lives 2 blocks away from me..lol
Re: Modified Hemi 4 speed ? [Re: fourgearsavoy] #781855
08/24/10 09:19 PM
08/24/10 09:19 PM
Bergen County NJ
N
NoJoke Offline OP
NoJoke  Offline OP
N
Bergen County NJ
Gus
Lol last time out at the track with the car was Oct 0f 2009 at a mopar event. Mind you I run a ford 9" with moser axles detroit locker. I dumped the clutch at 5k I broke the pinion yoke off the rear plus the u-joint. I was in shock when the pinion yoke broke off.. Now I have a spool with billet yoke and new drive shaft with 1350 jojnts. I doubt it will break again. I this the hemi 18 spline will hold up well...
Re: Modified Hemi 4 speed ? [Re: NoJoke] #781856
08/24/10 09:40 PM
08/24/10 09:40 PM
Rittman Ohio
Rittman Ohio
Well I guess you are learning the first rule of stick racing,build it from the rear forward.I really would recommend an aftermarket carrier for that 9" like the Strange or Moser unit with a good pinion bearing support as well
Gus
64 Plymouth Savoy
Dana 60
Re: Modified Hemi 4 speed ? [Re: fourgearsavoy] #781857
08/24/10 10:35 PM
08/24/10 10:35 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Gus
Gus...how fast (ET and MPH) is your car?
How much to build a trans (clutch and all) similar to your setup?
Re: Modified Hemi 4 speed ? [Re: fourgearsavoy] #781858
08/25/10 01:00 AM
08/25/10 01:00 AM
Canada
Cape Offline
Cape  Offline
Canada
What does it mean to face plate the gears. I just never herd doing that before
Re: Modified Hemi 4 speed ? [Re: NoJoke] #781859
08/25/10 08:47 AM
08/25/10 08:47 AM
Vernon Ct.
bp27 Offline
bp27  Offline
Vernon Ct.
From left to right stock pro-shift fase plate
Re: Modified Hemi 4 speed ? [Re: Quicksilver440] #781860
08/25/10 08:21 PM
08/25/10 08:21 PM
Rittman Ohio
Rittman Ohio
Gus
I haven't been able to hook it up yet on my one and only time at the track this summer but spinning through first gear it went 7.13 at 99.45 on a humid 92 degree day I don't know if thats any good or not,this was my first 1/8 mile race.
Plate was NOS E-bay $140.00
Flywheel used Hays 143 tooth $50.00
Richmond 5-Speed got from buddy $1900.00
Face-plate mods and cryo treat on the gears with me building the box $850.00
New Ram disc $180.00
Long V-gate shifter $525.00
Figure 400-800 misc for TO bearing,pilot,bell,yoke,shaft,mount,bolts etc.
Add an entire weekend for cutting and boxing the torsion crossmember,fabbing a new trans crossmember,clutch linkage etc...
Not a cheap drivetrain for sure
Gus
64 Plymouth Savoy
Dana 60
