Re: Modified Hemi 4 speed ?
[Re: NoJoke]
#781842
08/23/10 09:08 PM
08/23/10 09:08 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
[Re: NoJoke]
#781844
08/23/10 09:48 PM
08/23/10 09:48 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Do the face-plate on third and fourth at least First and second can be slick or pro-shift. I had my Richmond face-plated and it works perfectly Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#781845
08/23/10 10:09 PM
08/23/10 10:09 PM
Posts: 641 Bergen County NJ
NoJoke
Bergen County NJ
Did you run the car on the street also or just raced it?
[Re: fourgearsavoy]
#781848
08/24/10 06:38 PM
08/24/10 06:38 PM
Posts: 3,415 Toronto
mshred
Toronto
I run it hard on the street and full throttle on the track leaving on the 2-step and it holds up well and doesn't miss a gear with a Long V-gate shifter.Make sure you get the HD Liberty modified side cover if you go with the 833 trans Gus
what is the benefit of that side cover, less case flex?
[Re: HPMike]
#781852
08/24/10 09:12 PM
08/24/10 09:12 PM
Posts: 1,946 Connecticut
5126brl No more
Connecticut
Done several.
Call me.
Just give it to HPMIKE and then ENJOY!!!
I love the one he did for me,, Shifts like a dream!! Get a nice Ramrod shifter and never think about a missed shift again!!
[Re: fourgearsavoy]
#781855
08/24/10 09:19 PM
08/24/10 09:19 PM
NoJoke
Bergen County NJ
I have the McCleod dual disc set up boy there is no slippage at all with that set up... I noticed when it heats up there is no easing out at a red light car just jumps off the line...
I had one in the car for a while until I started breaking sliders and gears,I split 2 third gear sliders and trimmed all the teeth off third gear before I realized it was too stiff for racing use with traction Gus
Lol last time out at the track with the car was Oct 0f 2009 at a mopar event. Mind you I run a ford 9" with moser axles detroit locker. I dumped the clutch at 5k I broke the pinion yoke off the rear plus the u-joint. I was in shock when the pinion yoke broke off.. Now I have a spool with billet yoke and new drive shaft with 1350 jojnts. I doubt it will break again. I this the hemi 18 spline will hold up well...
[Re: fourgearsavoy]
#781857
08/24/10 10:35 PM
08/24/10 10:35 PM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
What clutch do you run in your car?
I am currently just running an old school Hays MK XII plate and a Ram sprung hub bronze disc.It does good on the street but it bites too hard for the track. Gus
Gus...how fast (ET and MPH) is your car?
How much to build a trans (clutch and all) similar to your setup?
[Re: Quicksilver440]
#781860
08/25/10 08:21 PM
08/25/10 08:21 PM
fourgearsavoy
Rittman Ohio
I haven't been able to hook it up yet on my one and only time at the track this summer but spinning through first gear it went 7.13 at 99.45 on a humid 92 degree day I don't know if thats any good or not,this was my first 1/8 mile race. Plate was NOS E-bay $140.00 Flywheel used Hays 143 tooth $50.00 Richmond 5-Speed got from buddy $1900.00 Face-plate mods and cryo treat on the gears with me building the box $850.00 New Ram disc $180.00 Long V-gate shifter $525.00 Figure 400-800 misc for TO bearing,pilot,bell,yoke,shaft,mount,bolts etc. Add an entire weekend for cutting and boxing the torsion crossmember,fabbing a new trans crossmember,clutch linkage etc... Not a cheap drivetrain for sure Gus
