Drag Radials #781191
08/23/10 09:16 AM
08/23/10 09:16 AM
Brisbane Australia
572B1 Offline OP
572B1  Offline OP
Brisbane Australia
Anyone running Mickey Thompson 275/60-15 on a 10'' rim. Is it worth the effort or are you better off with 8 '' rims.
Re: Drag Radials [Re: 572B1] #781192
08/23/10 10:38 AM
08/23/10 10:38 AM
Elbridge, NY
Dart1031 Offline
Dart1031  Offline
Elbridge, NY
I've run that size on a 10" rim, no problems. Yes it's worth using the 10" over the 8"
Re: Drag Radials [Re: 572B1] #781193
08/23/10 10:50 AM
08/23/10 10:50 AM
nc
cold85 Offline
cold85  Offline
nc
we run them on a 12inch wheel
Re: Drag Radials [Re: cold85] #781194
08/23/10 02:16 PM
08/23/10 02:16 PM
Ma
Voluster Offline
Voluster  Offline
Ma
I run mine on a 10 inch rim
some have squeezed them on a 12
Re: Drag Radials [Re: Voluster] #781195
08/23/10 02:48 PM
08/23/10 02:48 PM
Motor City
Shaker223 Offline
Shaker223  Offline
Motor City
Or is that stretched?
Re: Drag Radials [Re: 572B1] #781196
08/23/10 04:07 PM
08/23/10 04:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On the subject of drag radials which has better bite
the MT or Hoosier 275/60 15
Re: Drag Radials [Re: MR_P_BODY] #781197
08/23/10 04:19 PM
08/23/10 04:19 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
The hoosier is a bigger tire (taller&wider)and also alot lighter then the mickey.I think the hoosier is a more consistant tire,more forgiving on bad tracks but I feel the mickey would 60 ft a little better on a well prepped track.Only a few hundreds I would guess.With mickeys on my car one pass it would hook next pass it would blow them off, it either hooks hard or doesn't at all.I personaly run the hoosier on my car.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Drag Radials [Re: 1967dartgt] #781198
08/23/10 06:17 PM
08/23/10 06:17 PM
Brisbane Australia
572B1 Offline OP
572B1  Offline OP
Brisbane Australia
Thanks Guys, I have 10'' rims, so ten it is.
Re: Drag Radials [Re: 1967dartgt] #781199
08/23/10 06:33 PM
08/23/10 06:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What kind of 60' are you talking
Re: Drag Radials [Re: MR_P_BODY] #781200
08/23/10 10:21 PM
08/23/10 10:21 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
The car goes 1.43 on motor and 1.36 on 150hp that is with the hooiser never ran mickeys on spray was afraid the way they would lose traction.All of this was with ss springs and a snubber.
Re: Drag Radials [Re: 1967dartgt] #781201
08/23/10 10:26 PM
08/23/10 10:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks... this is for a friend for his ford pick up
that we are taking on drag week... thanks again
Re: Drag Radials [Re: MR_P_BODY] #781202
08/24/10 03:13 AM
08/24/10 03:13 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Guys routinely go low 1.20s and high teens for 60ft, in 3000+ lb cars, on the 275 Hoosiers. The Hoosier is not a "true" radial and not sure how it got the DOT rating for a radial. It is way closer to a bias tire, than a radial. I know the Mickeys work, but you can hit the Hoosier harder initially.
Monte
Re: Drag Radials [Re: Monte_Smith] #781203
08/24/10 09:29 AM
08/24/10 09:29 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Monte
Thanks for that info Monte
Re: Drag Radials [Re: Monte_Smith] #781204
08/24/10 11:43 AM
08/24/10 11:43 AM
GA
Boosted Offline
Boosted  Offline
GA
Monte
I am glad you posted this Monte... I spoke with M/T about a drag radial or the et streets.. My car is a 4 spd and per the guy at M/T I do not want to use a drag radial with a brake or a clutch transmission The said for me to stick with the ET Streets as my clutch car would need the sidewall flex that the radial does nto have,,
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: Drag Radials [Re: Monte_Smith] #781205
08/24/10 07:01 PM
08/24/10 07:01 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Monte,
which part number Hoosier ?
i am up in the air re et street radial or try a radial slick.
thanks,
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Drag Radials [Re: tex013] #781206
08/24/10 08:37 PM
08/24/10 08:37 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
If you don't plan to drive the car on the street, or class rules do not require you to run a Drag Radial, just stick with a slick, or ET street type tire. Now don't get me wrong, drag radials work well and guys fly on them......BUT....they are not a just throw them on and be fast situation. The car has to work and you have to know how to make the tire work. They can be extremely tricky.
Monte
Re: Drag Radials [Re: Monte_Smith] #781207
08/24/10 09:27 PM
08/24/10 09:27 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Monte
the Hoosier is a lot lighter and yes a lot more consisten than the MT's
I have been the same ets on both, but the Hoosiers are a lot more forgiving. Honestly they are like a radial slick
....BAD A$$ STREET CAR.....
Re: Drag Radials [Re: n20mstr] #781208
08/24/10 09:45 PM
08/24/10 09:45 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Part # 17317 ?
Tex
New best MPH 130.32
