Re: Drag Radials
[Re: Voluster]
#781195
08/23/10 02:48 PM
08/23/10 02:48 PM
Posts: 365 Motor City
Shaker223
Motor City
I run mine on a 10 inch rim
some have squeezed them on a 12
Or is that stretched?
Re: Drag Radials
[Re: 1967dartgt]
#781199
08/23/10 06:33 PM
08/23/10 06:33 PM
Posts: 52,972 Romeo MI
MR_P_BODY
On the subject of drag radials which has better bite the MT or Hoosier 275/60 15
The hoosier is a bigger tire (taller&wider)and also alot lighter then the mickey.I think the hoosier is a more consistant tire,more forgiving on bad tracks but I feel the mickey would 60 ft a little better on a well prepped track.Only a few hundreds I would guess.With mickeys on my car one pass it would hook next pass it would blow them off, it either hooks hard or doesn't at all.I personaly run the hoosier on my car.
What kind of 60' are you talking
Re: Drag Radials
[Re: Monte_Smith]
#781203
08/24/10 09:29 AM
08/24/10 09:29 AM
MR_P_BODY
Guys routinely go low 1.20s and high teens for 60ft, in 3000+ lb cars, on the 275 Hoosiers. The Hoosier is not a "true" radial and not sure how it got the DOT rating for a radial. It is way closer to a bias tire, than a radial. I know the Mickeys work, but you can hit the Hoosier harder initially.
Monte
Thanks for that info Monte
Re: Drag Radials
[Re: Monte_Smith]
#781205
08/24/10 07:01 PM
08/24/10 07:01 PM
Posts: 2,463 Sydney,Australia
tex013
Sydney,Australia
Monte, which part number Hoosier ? i am up in the air re et street radial or try a radial slick. thanks, Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
