Upper radiator hose collapsing #780010
08/21/10 10:58 PM
08/21/10 10:58 PM
Enfield, Ct
Moe Offline OP
Moe  Offline OP
Enfield, Ct
Upper radiator hose collapsing when engine cools down. I run a Be Cool overflow can. Very little coolant ever collects in the can. How do, or can I make this a coolant recovery tank that I could fill 1/2 way and have the radiator draw out of it when it cools? It does not seem vented?
440
It looks like this, but w/ a petcock at the bottom (major error in this pic)
Re: Upper radiator hose collapsing [Re: Moe] #780011
08/22/10 02:15 AM
08/22/10 02:15 AM
Corona CA
wyotech_cuda440 Offline
Corona CA
I have that exact same catch can, mine has the hose fittings on the top and bottom, same as the pic. You are supposed to hook the overflow hose to the bottom barb, and the top fitting is the vent. If you hook to the top, and the bottom is closed, then that is what's causing your issue.
Daily driver: 2002 Dakota R/T, slightly modded Weekend machine: 70 cuda, 440-6 street/strip
Re: Upper radiator hose collapsing [Re: wyotech_cuda440] #780012
08/22/10 10:16 PM
08/22/10 10:16 PM
Enfield, Ct
Moe Offline OP
Moe  Offline OP
Enfield, Ct
Thanks. This is how it was set-up when I bought the car. What are you using for a vent at the top?
Re: Upper radiator hose collapsing [Re: Moe] #780013
08/22/10 11:30 PM
08/22/10 11:30 PM
hobbs, new mexico
SixDRacing Offline
SixDRacing  Offline
hobbs, new mexico
test the radiator cap.
Re: Upper radiator hose collapsing [Re: wyotech_cuda440] #780014
08/25/10 10:03 PM
08/25/10 10:03 PM
Enfield, Ct
Moe Offline OP
Moe  Offline OP
Enfield, Ct
Thanks. I set it up the way it should have been. I used a drain valve for a Sears air compressor as a vent.
Re: Upper radiator hose collapsing [Re: Moe] #780015
08/25/10 10:46 PM
08/25/10 10:46 PM
Corona CA
Corona CA
I just left the barb fitting open on top, the a/c drain you used will work fine, but leave it open. A catch can is suppsoed to be vented, so that the coolant can move in and out freely as the radiator pressure changes.
