Re: Upper radiator hose collapsing
[Re: Moe]
#780011
08/22/10 02:15 AM
08/22/10 02:15 AM
Posts: 40 Corona CA
wyotech_cuda440
Corona CA
I have that exact same catch can, mine has the hose fittings on the top and bottom, same as the pic. You are supposed to hook the overflow hose to the bottom barb, and the top fitting is the vent. If you hook to the top, and the bottom is closed, then that is what's causing your issue.
Daily driver: 2002 Dakota R/T, slightly modded
Weekend machine: 70 cuda, 440-6 street/strip
[Re: wyotech_cuda440]
#780014
08/25/10 10:03 PM
08/25/10 10:03 PM
Posts: 304 Enfield, Ct
Moe
Enfield, Ct
Thanks. I set it up the way it should have been. I used a drain valve for a Sears air compressor as a vent.
