E-body under dash questions #779289
08/20/10 11:42 PM
08/20/10 11:42 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
When the antenna wire comes through into the interior, how does it route after that? Does it lay on the top of the heater coar or is it held in place somehow?
When the speedometer cable comes through the firewall where should it go? To the left of the steering colomb bracket or through the center of that bracket?
Finally, I bought all new insulation last weekend. Inside the package of kick panel insulation was a third piece. Is that just a scrap piece or does it go somewhere? It's oddly shaped and looks more like firewall insulation than anything. Thanks
Re: E-body under dash questions [Re: burdar] #779290
08/21/10 03:05 AM
08/21/10 03:05 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Antenna wire was clipped to the bottom portion of the dash..
Speedo cable was routed through the center area of the column support..
Got a picture of the insulation..
Re: E-body under dash questions [Re: 1_WILD_RT] #779291
08/21/10 03:18 AM
08/21/10 03:18 AM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
So I can just lay the antenna cable ontop of the heater box for now and hook it to the dash as it's being installed?
Does anyone have a pic of how the speedo cable gets routed? I have some reference pics but the speedo cable isn't installed in any of them.
Here's a pic of the insulation.
Re: E-body under dash questions [Re: burdar] #779292
08/23/10 05:51 AM
08/23/10 05:51 AM
Switzerland, Europe
Swiss_Robert Offline
Switzerland, Europe
May be I've got the same package with kick-panel insulation? I have mine from Year One.
This third piece goes directly under the driver side kick panel, between metal body frame and plastic moulding, covering the door hinge area. The one small screw, that holds the kick-panel, goes through it...
I know that cause I kept the old one (when I had this new part in my fingers I've had the same idea to ask here in the forum where it goes to ). There is no "shape" that will fit this part and make it obvious where it exactly goes... it's some kind of "free flowing". On your pic it's upside down, the one corner off is because the park brake pedal.
But the worse thing is, there is SUCH A PIECE ON THE PASSENGER SIDE TOO, a fourth piece, which is not in the kit!
IF my car had those insulation right before I took it off.
After all these years having a 440 I realized that this means having an attitude... and a budget.
Re: E-body under dash questions [Re: burdar] #779293
08/23/10 06:05 AM
08/23/10 06:05 AM
Switzerland, Europe
Switzerland, Europe
Dont' really want to steal that thread but...
Where are the ventilation control cables routed? Heat and defrost cable going THROUGH the column bracket? The driver side vent cable - goes OVER the bracket??
Re: E-body under dash questions [Re: Swiss_Robert] #779294
08/23/10 12:44 PM
08/23/10 12:44 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
Can you post a pic of that insulation in its correct position on the car please?
I had the same question reguarding the cables. Two cables from the passengers side go through the center of the steering colom bracket. The fresh air cable from the drivers side goes up over the top of the colom bracket.(between the bracket and the underside of the cowl)
Re: E-body under dash questions [Re: burdar] #779295
08/23/10 05:27 PM
08/23/10 05:27 PM
Switzerland, Europe
Switzerland, Europe
Here a pic. Looked for them again - they fit into the plastic kickpanels, both of them. And the small screw on each side goes NOT through the insulation (in my car they were not quite correctly installed) but they have a recess for that (you'll see the screw-hole, if you look carefully).
I have absolutely no idea, why they sell this kit with only three parts and leave the fourth part away .
I'll have to use the old one on the passenger side...
Re: E-body under dash questions [Re: Swiss_Robert] #779296
08/23/10 05:50 PM
08/23/10 05:50 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
Thanks for that pic. It's exactly what I needed.
When you have time, could you take some measurements of the passengers side piece? I've got a scrap section of insulation from the firewall kit that might be big enough.
The hole for the blower motor and heater hoses isn't completely cut out of the firewall insulation. It's just perferated. That scrap piece might be big enough to make the missing passengers side one.
Re: E-body under dash questions [Re: burdar] #779297
08/24/10 04:45 AM
08/24/10 04:45 AM
Switzerland, Europe
Switzerland, Europe
Nope, sorry to destroy your hope. Had the same idea... is too small
You can make "a" piece that may cover the door hinge cavern...
The genuine piece is not rectangular. Biggest width is 7 3/8" (at bottom), heigth is 8 1/2".
Width at top is 6". The lower part up to the recess for the screw is 4 1/2" heigth, there width is 7 1/4" (cause it's not rectangular).
Re: E-body under dash questions [Re: Swiss_Robert] #779298
08/24/10 01:28 PM
08/24/10 01:28 PM
cataclysm80 Offline
cataclysm80  Offline
Good info here. Thanks guys!
Tav
Re: E-body under dash questions [Re: Swiss_Robert] #779299
04/08/11 08:07 AM
04/08/11 08:07 AM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Does anyone have one of these missing pieces so I can create it?
Re: E-body under dash questions [Re: 71TA] #779300
09/23/13 09:20 PM
09/23/13 09:20 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Did anyone cure this issue? I just got a kit from Dante and I believe it only has 3 pieces. I haven't opened it yet so I could be wrong.
Careful, your character's showing!
Re: E-body under dash questions [Re: mopar346] #779301
09/24/13 03:50 AM
09/24/13 03:50 AM
Switzerland, Europe
Switzerland, Europe
Hah ! Wouldn't be surprised if not... still three pieces, I bet!
Oh boy: My car's still on jacks and is still not back on the road... shame on me! Haven't done anything for about two years...
Re: E-body under dash questions [Re: Swiss_Robert] #779302
09/24/13 01:57 PM
09/24/13 01:57 PM
mopar346 Offline
mopar346  Offline
Don't feel bad, I went about 10 years without working on mine. I am back at it now though, hopefully for the duration. I made a few commitments to have it at a few shows next summer so time to put up or shut up.
I could see the spare piece serving the purpose with a little modification, wont be the exact size but how many people are gonna see it in the first place.
Re: E-body under dash questions [Re: mopar346] #779303
09/24/13 03:01 PM
09/24/13 03:01 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
I sent my original insulation to Jim at Detroit Muscle, contact him and he should be able to hook you up on the missing piece, as he made one for me from the piece I sent
Re: E-body under dash questions [Re: burdar] #779304
09/24/13 07:56 PM
09/24/13 07:56 PM
NE Ohio
66HP2 Offline
66HP2  Offline
NE Ohio
the antenna cable clips to the back of the glove box
Re: E-body under dash questions [Re: AAR#2] #779305
09/24/13 09:45 PM
09/24/13 09:45 PM
mopar346 Offline
mopar346  Offline
That's about normal, I order something from them today. Thanks though.
