SB Alternator bracket for a Meziere water pump. #774079
08/15/10 02:06 PM
08/15/10 02:06 PM
Rancho Cucamonga, Calif.
P
PUNK Offline OP
PUNK  Offline OP
P
I know some guys have been on the lookout for an alternator bracket for there SB engines when using a Meziere electric water pump. Bob Mazzolini has some neat brackets that work pretty good. We are using one on my brothers Cuda. 1-951-787-8783.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
Re: SB Alternator bracket for a Meziere water pump. [Re: PUNK] #774080
08/15/10 02:08 PM
08/15/10 02:08 PM
P
PUNK Offline OP
PUNK  Offline OP
P
We use this Powermaster 100 amp alternator that works GREAT on the street with electric water pump,fans, fuel pump, driving at night with all the lights on etc. and the voltage stays at 14.2 volts always. The battery has never been discharged even in stop and go traffic, and we are even runnin a small diameter Moroso lower crank pulley.
Re: SB Alternator bracket for a Meziere water pump. [Re: PUNK] #774081
08/15/10 03:50 PM
08/15/10 03:50 PM
Ma
Voluster Offline
Voluster  Offline
Ma
any installed pics?
how much?
I have some backyard ghetto looking one I made
Re: SB Alternator bracket for a Meziere water pump. [Re: Voluster] #774082
08/15/10 03:54 PM
08/15/10 03:54 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Thank you sir, I will be calling him next week.
You don't by chance have a part number for that alternator do you?
I have asked sloan about this a few times, I didn't want to put my gheto bracket back on this time around. Here is a picture he posted some time back.
68 Barracuda Formula S 340
Re: SB Alternator bracket for a Meziere water pump. [Re: Bad340fish] #774083
08/15/10 04:02 PM
08/15/10 04:02 PM
western pennsylvania
b1dartsport Online content
b1dartsport  Online Content
Does anybody know if that backet will work with a CSR pump?
Re: SB Alternator bracket for a Meziere water pump. [Re: b1dartsport] #774084
08/15/10 04:09 PM
08/15/10 04:09 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: SB Alternator bracket for a Meziere water pump. [Re: Adobedude] #774085
08/15/10 04:26 PM
08/15/10 04:26 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
Bring that puppy over and I will help you cut those lightening holes in it you have marked. Lord knows I have enough experience...........
SRT DEMON ONE SEAT
Re: SB Alternator bracket for a Meziere water pump. [Re: Bad340fish] #774086
08/15/10 07:06 PM
08/15/10 07:06 PM
P
PUNK Offline OP
PUNK  Offline OP
P
The picture of the bracket installed on the engine above is the origional (VERY) rough draft. Believe it or not I used an aluminum road sign like a stop sign to make that using a jig saw. My old man thought it was cheesy, so he drew up a design on his cad program and then Mazzolini sent it to his machinist to have it made. My Dads cad drawing actually is much nicer than the piece shown, but the machinist thought that the lightening holes and the finished chamfering was overkill. Whatever!!! It would have looked much nicer and more refined if it would have been made to my dads specs per his Cad blueprint. Anyways, that bracket does work very nice.
Re: SB Alternator bracket for a Meziere water pump. [Re: PUNK] #774087
08/15/10 07:08 PM
08/15/10 07:08 PM
Q
Quicktree Offline
Quicktree  Offline
Q
you would need the correct bottom pulley for it to work. I would sell them as a pair.
Re: SB Alternator bracket for a Meziere water pump. [Re: PUNK] #774088
08/15/10 07:09 PM
08/15/10 07:09 PM
Oconomowoc, WI.
Cudahlr Offline
Cudahlr  Offline
Oconomowoc, WI.
Do you think it will work with the moroso pump?
1968 Barracuda 360/727 11.20 @ 121 mph 421 rwhp
1985 Harley Sportster Bobber
2006 Ram 2500 sport - The Cudahlr
Re: SB Alternator bracket for a Meziere water pump. [Re: PUNK] #774089
08/15/10 07:13 PM
08/15/10 07:13 PM
P
PUNK Offline OP
PUNK  Offline OP
P
Also, the pictures of our origional bracket show the lower pulley and the crank spacer made by www.dotymi.com, the small spacers required to shim the alternator out are also available through doty as well. I think we will eventually have the bracket made ourselves with the chamfering, lightening holes, polishing and anodizing. But for now, there is little to no demand for this part so this is the best we can do. I actually wasnt going to have them made, but Bob Mazzolini said he has been getting requests for this part. So he sprung for the machining costs and had a handfull of them made. I think he only had 10 of them made. So if you need one, you better get one soon!! As far as the CSI water pump, Im not sure. I will buy a CSI soon for my wifes car and will let you guys know.
Re: SB Alternator bracket for a Meziere water pump. [Re: Cudahlr] #774090
08/15/10 07:17 PM
08/15/10 07:17 PM
P
PUNK Offline OP
PUNK  Offline OP
P
Looking at the Moroso electric water pump, I dont think that it would be difficult to adapt this piece to it. Im trying to work with Bob to get all the necessary spacers/shims and pulleys together to sell as a whole kit or just seperately knowing what works. I know how nice it is to just buy a kit that has everything in it that just works without any pains.
I can tell you the bracket works great, but you will need to get the necessary spacers to make it work. Its really not all that bad to figure out though. The spacers from Dotymi.com are anodized black and are nice looking.
Re: SB Alternator bracket for a Meziere water pump. [Re: PUNK] #774091
08/15/10 07:19 PM
08/15/10 07:19 PM
Renton Washington
Triple Threat Offline
Renton Washington
Any idea the cost?
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: SB Alternator bracket for a Meziere water pump. [Re: Triple Threat] #774092
08/15/10 07:24 PM
08/15/10 07:24 PM
P
PUNK Offline OP
PUNK  Offline OP
P
The alternator pictured above is an 8062 from powermaster. It produces all the juice you need for a street/strip car and then some. We had a smaller alternator from powermaster that fit this same bracket, but it wouldnt keep up with the demand of the components in the car. Actually it could, but we were working the alternator too hard and we burned up 3 of them. THe part number for that smaller and lighter alternator slips my mind, but for race only I would think it would work out great. My brothers car is a street car that he drives all the time, and this 8062 alternator kicks butt.
Re: SB Alternator bracket for a Meziere water pump. [Re: Triple Threat] #774093
08/15/10 07:27 PM
08/15/10 07:27 PM
P
PUNK Offline OP
PUNK  Offline OP
P
Any idea the cost?
Honestly I have no idea. You will have to call Bob for that one.
Re: SB Alternator bracket for a Meziere water pump. [Re: PUNK] #774094
08/15/10 08:53 PM
08/15/10 08:53 PM
Renton Washington
Renton Washington
Just curious, what kind/brand of battery are you running in the Black 'cuda?
-Dustin
Re: SB Alternator bracket for a Meziere water pump. [Re: PUNK] #774095
08/16/10 10:26 PM
08/16/10 10:26 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Re: SB Alternator bracket for a Meziere water pump. [Re: Triple Threat] #774096
08/17/10 04:01 PM
08/17/10 04:01 PM
P
PUNK Offline OP
PUNK  Offline OP
P
I believe its a drycell Odyssey battery. Its a little sucker.
Re: SB Alternator bracket for a Meziere water pump. [Re: PUNK] #774097
08/18/10 03:38 PM
08/18/10 03:38 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I ordered one of these last night, he said I was the first one. I was afraid I would be to late!
Re: SB Alternator bracket for a Meziere water pump. [Re: Bad340fish] #774098
08/18/10 04:26 PM
08/18/10 04:26 PM
Ma
Voluster Offline
Voluster  Offline
Ma
How much?
I didn't see it posted on his site
