'68 Coronet Drum to Disc help needed please!!! #773750
08/14/10 07:56 PM
08/14/10 07:56 PM
Mansfield,Ohio
moparrulzzz Offline OP
Mansfield,Ohio
I am doing the drum to disc on my '68 Coronet with a sway bar.
Have the 73-76 spindles and the 11.75 caliper adapters. Going to use the '80 Volare calipers so I can rear mount.
Question is has anyone done this swap and what front brake lines did you use? I know I can get SS made but for now I want to just get the swap done and upgrade later (maybe) to SS if I feel it is necesary.
Anyone help me out??
Re: '68 Coronet Drum to Disc help needed please!!! [Re: moparrulzzz] #773751
08/14/10 08:34 PM
08/14/10 08:34 PM
Puttin' on the foil in Charles...
not_a_charger Online mad
Mr. Big Shot Moparts Moderator
not_a_charger  Online Mad
I believe the brake line you need if you're flipping the calipers to the rear is one from a Diplomat, though AndyF would know for sure.
Earning every penny of that moderator paycheck.
DBAP
Re: '68 Coronet Drum to Disc help needed please!!! [Re: not_a_charger] #773752
08/14/10 08:55 PM
08/14/10 08:55 PM
Mansfield,Ohio
Mansfield,Ohio
If he doesn't chime in I will PM him..
Re: '68 Coronet Drum to Disc help needed please!!! [Re: moparrulzzz] #773753
08/14/10 09:21 PM
08/14/10 09:21 PM
AndyF Offline
AndyF  Offline
I've never seen a stock hose fit correctly when doing that swap. I just get custom hoses built that fit and work rather than trying to drive around with a hack job for the hoses.
Re: '68 Coronet Drum to Disc help needed please!!! [Re: AndyF] #773754
08/14/10 11:12 PM
08/14/10 11:12 PM
Mansfield,Ohio
Mansfield,Ohio
Andy, If I can determine the proper legnth to get and can find a local (or Web)place to make some SS what do I tell them the(correct) names of the ends to be?
And I am correct in the '80 Volare caliper so I can rear mount them?
Thnx for the help!!
Chuck
Re: '68 Coronet Drum to Disc help needed please!!! [Re: AndyF] #773755
08/14/10 11:13 PM
08/14/10 11:13 PM
ohio
moparinator Offline
moparinator  Offline
ohio
I did the swap a few months ago and tried many different lines. I ended up just using a brake line with a banjo bolt setup. If I would have done this to begin with, I would have saved myself a lot of time and money.
Re: '68 Coronet Drum to Disc help needed please!!! [Re: moparinator] #773756
08/14/10 11:17 PM
08/14/10 11:17 PM
Mansfield,Ohio
Mansfield,Ohio
What application hose did you use on yours? Do you have a '68 B Body as well? Do ya have any specifics?
Re: '68 Coronet Drum to Disc help needed please!!! [Re: moparrulzzz] #773757
08/14/10 11:58 PM
08/14/10 11:58 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
I know it’s a little extra time and money, but instead of complicating the issue with custom brake lines, banjo bolts, different caliper applications, etc… I just took the time of locating a 1970 B-Body K-member and lower control arms with the inward sway bar mounts so I can front mount the calipers.
Now I can simply use off the shelf parts (Hoses, Calipers, etc.) for 1970 B-Body disc brake applications the way the engineers originally intended. Plus I like the design of the 1970 and later sway bar.
With this swap, there’s different ways of doing it. It’s up to you in what you want in the end result.
Re: '68 Coronet Drum to Disc help needed please!!! [Re: CompSyn] #773758
08/15/10 12:12 AM
08/15/10 12:12 AM
Mansfield,Ohio
Mansfield,Ohio
If I would go that route with a '70 K and LCA's would I still use the 73-76 A Body spindles. The Volare slider calipers..etc..
I have the 11.75 rotors, calipers, bearings, seals, everything but the hoses.
I doubt I could return this stuff as I have been slowly collecting it till the big day arrives.
Re: '68 Coronet Drum to Disc help needed please!!! [Re: moparrulzzz] #773759
08/15/10 12:15 AM
08/15/10 12:15 AM
AndyF Offline
AndyF  Offline
Use a banjo fitting at the caliper and then a #3 AN at the frame. You'll need the correct adapter at the frame that goes from flare to #3AN. It is a standard conversion fitting at the frame which mounts in the stock bracket with the stock clip.
Re: '68 Coronet Drum to Disc help needed please!!! [Re: AndyF] #773760
08/15/10 12:36 AM
08/15/10 12:36 AM
Mansfield,Ohio
Mansfield,Ohio
Thnx Andy!!!!
Re: '68 Coronet Drum to Disc help needed please!!! [Re: moparrulzzz] #773761
08/15/10 01:23 AM
08/15/10 01:23 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Yes! Same 73-76 A Body spindles work with the 70 K-frame and LCAs. Not familiar with how the Volare slider calipers mount or if they are reversible from front rear and vice versa?
Again, the same 11.75" rotors and 73-76 A Body spindles work with 70 K-frame and LCAs . If you have slider style caliper adapters, you'll have to do some research into what caliper will work best. I happened to come across pin style caliper adapters off a 1977 Plymouth Fury Salon with 11.75" rotors. So in my case, the the pin style calipers for the 1970 B-Body application are the same.
And again, more than one way of doing the swap. It becomes more a matter of how the individual wants the end result to look and function.
Re: '68 Coronet Drum to Disc help needed please!!! [Re: moparrulzzz] #773762
08/15/10 12:23 PM
08/15/10 12:23 PM
AndyF Offline
AndyF  Offline
What you want is something like the hose at the top of this picture. The flare to AN adapter is also shown at the top. This is a special part that mounts to the frame with the stock clip. You could also go with a hose like the one shown at the bottom of the picture which has the frame clip built in. That way you have one less fitting to mess with but the hoses are more expensive.
Re: '68 Coronet Drum to Disc help needed please!!! [Re: AndyF] #773763
08/15/10 12:27 PM
08/15/10 12:27 PM
AndyF Offline
AndyF  Offline
For a rear hung application your caliper should look like the one on the left. That is the correct caliper to rear hang on the driver's side. The other caliper is a front hung unit. I see people use the front hung calipers on the rear but the hose gets pointed the wrong way. Not sure why people do that.
Re: '68 Coronet Drum to Disc help needed please!!! [Re: CompSyn] #773764
08/15/10 12:40 PM
08/15/10 12:40 PM
ohio
moparinator Offline
moparinator  Offline
ohio
I did the swap on a 73 e body with 74 dart spindles and calipers. Calipers did not work, so I tried coronet spindles. They did not work quite right either with the lines, and that is when I tried all the different lines. I ended up with e body calipers and the banjo bolt setup, which was perfect.
A few guys helped me out on here, and there is a tech article that says exactly what to get and do. I skimmed it the first time and thought I knew what was going on. Reading all of it would have saved me some major time and a few dollars.
I also changed master cylinders to the dual reservoir and did not mess with any proportioning valve stuff. I had a hard time finding a master cyclinder and was shipped the wrong one to begin with and didn't figure it out until I looked at several pictures. Everything works fine once I figured it all out. I hope you do not run into the same problems.
Here is one site that helped. I thought there was a good one on moparts that show pictures of what calipers to use depending on what car you had, but I can not seem to locate it.
http://www.moparaction.com/tech/archive/disc-main.html
Re: '68 Coronet Drum to Disc help needed please!!! [Re: moparinator] #773765
08/15/10 12:44 PM
08/15/10 12:44 PM
ohio
moparinator Offline
moparinator  Offline
ohio
AndyF's pics are exactly what you need.
Re: '68 Coronet Drum to Disc help needed please!!! [Re: moparinator] #773766
08/15/10 01:06 PM
08/15/10 01:06 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
The 1974 Dart has slider calipers like the one in THIS picture link.
The 1973 E-Body has pin style calipers like the one in THIS picture link .
Since I have the pin style caliper adapters for 11.75” rotors, the 70-to-74 B and E body pin style calipers will bolt up just fine in the factory front mounted location.
Re: '68 Coronet Drum to Disc help needed please!!! [Re: CompSyn] #773767
08/15/10 01:18 PM
08/15/10 01:18 PM
Mansfield,Ohio
Mansfield,Ohio
Thnx for all the Help
ANDYF
Compsyn
Moparinator ...BTW where are you in Ohio?
I think I have it all sorted out now!!
Re: '68 Coronet Drum to Disc help needed please!!! [Re: moparrulzzz] #773768
08/15/10 08:39 PM
08/15/10 08:39 PM
ohio
moparinator Offline
moparinator  Offline
ohio
Mt. Pleasant 43939
not far from Wheeling WV,and St. Clairsville, OH
what kind of shape is your Coronet in?
Re: '68 Coronet Drum to Disc help needed please!!! [Re: moparinator] #773769
08/15/10 10:59 PM
08/15/10 10:59 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Dr. Diff has the stainless braided lines.
