BB heat block off #772970
08/13/10 04:48 PM
08/13/10 04:48 PM
VA
DAMOPARS Offline OP
DAMOPARS  Offline OP
VA
How can I block off the hoses going to the heater box? Or put a valve in one of the hoses (which one)
Big block ,,,, No A/C ,,,Thanks
Re: BB heat block off [Re: DAMOPARS] #772971
08/13/10 05:26 PM
08/13/10 05:26 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What do you want to do , stop the flow because it's hot in the car of remove the heat path completely ?
Re: BB heat block off [Re: JohnRR] #772972
08/13/10 05:31 PM
08/13/10 05:31 PM
VA
DAMOPARS Offline OP
DAMOPARS  Offline OP
VA
Too hot in the car, in the summer.
Re: BB heat block off [Re: DAMOPARS] #772973
08/13/10 05:50 PM
08/13/10 05:50 PM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
PLUGS in the water pump ...or caps on the tubes.
Re: BB heat block off [Re: DAMOPARS] #772974
08/13/10 05:58 PM
08/13/10 05:58 PM
AndyF Offline
AndyF  Offline
Quick and dirty way to do it is to loop a short section of heater hose on the water pump. Then you don't have to pull the nipples out to replace them with plugs.
Re: BB heat block off [Re: AndyF] #772975
08/13/10 06:02 PM
08/13/10 06:02 PM
VA
DAMOPARS Offline OP
DAMOPARS  Offline OP
VA
But my hoses are different sizes.
Re: BB heat block off [Re: DAMOPARS] #772976
08/13/10 06:10 PM
08/13/10 06:10 PM
FL
74-440Charger Offline
FL
Use the larger of the two hoses and clamp it down, she will hold.
Re: BB heat block off [Re: 74-440Charger] #772977
08/13/10 07:00 PM
08/13/10 07:00 PM
Kirkland, Washington
Pacnorthcuda Offline
I simply installed a ball-valve up near the firewall, in the big (3/4" line) because that was the size of the valve I found.
Works like a charm. No tools required to turn heat on and off, but you do have to lift the hood of course.
Interior is noticably cooler on hot days!!!
Re: BB heat block off [Re: DAMOPARS] #772978
08/13/10 07:05 PM
08/13/10 07:05 PM
Florida STAYcation
Florida STAYcation
Get RUBBER caps to put over the pipes.... any good plumbing store has 'em !
Re: BB heat block off [Re: dOoC] #772979
08/14/10 02:10 AM
08/14/10 02:10 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
If you want to disable the heat but not remove it entirely, you could put in a valve on a heater hose so you can shut off coolant flow during the summer. Just in case you want to keep the heat around at the flick of a switch.
What I did with mine was my car has a valve for the heater hose that shuts off coolant flow when the heater controls are put in the strato-vent position. Vacuum switch didn't work anymore so I just ran the vacuum hose from the heater hose valve straight to the intake. Problem solved. If I wanted heat back I just unplugged the vacuum line and put a cap on.
Re: BB heat block off [Re: DAMOPARS] #772980
08/14/10 03:14 AM
08/14/10 03:14 AM
AndyF Offline
AndyF  Offline
Many cars came with a heater hose shut off valve. Just use one of those. My 1976 D200 truck had one mounted on the inner fender.
Re: BB heat block off [Re: AndyF] #772981
08/14/10 12:15 PM
08/14/10 12:15 PM
VA
DAMOPARS Offline OP
DAMOPARS  Offline OP
VA
Thanks guys
I put a ball valve in and will see how it works.
Re: BB heat block off [Re: DAMOPARS] #772982
08/14/10 01:43 PM
08/14/10 01:43 PM
Florida STAYcation
Florida STAYcation
OK ....BE SURE to put that valve IN the CORRECT side(the OUTLET side) of the water pump. IF you don't .... you can BLOW UP the heater core.
DON'T ask me how I know..
Re: BB heat block off [Re: DAMOPARS] #772983
08/14/10 01:56 PM
08/14/10 01:56 PM
TN Hoosier
jb500 Offline
jb500  Offline
TN Hoosier
Try a mini ball valve that you could install at the water pump to keep it out of sight.
