Hot track hints? #769779
08/09/10 05:51 PM
08/09/10 05:51 PM
Longview, Texas
marvo451 Offline OP
marvo451  Offline OP
Longview, Texas
Any help with suspension changes when the track temp is HOT (140+). I can't seem to get the car stuck until after dark. Duster is ladder bar, single adjustable QA1 coil overs with 14.5 X 32W Hoosier stiff wall slicks.
Re: Hot track hints? [Re: marvo451] #769780
08/09/10 09:16 PM
08/09/10 09:16 PM
Btween a rock and a hard place
moparlulu Offline
moparlulu  Offline
I cant give you anything as far as a ladder bar car. But on a leaf spring, I talked to John at M&H and he told me. If your spinning on a hot day, dot radial,1 pound down, shorten your burn out to just cleaning the tire off and soften the rear shocks up. By god if it didnt work for me!
Re: Hot track hints? [Re: moparlulu] #769781
08/09/10 10:54 PM
08/09/10 10:54 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Best bet is to hope they diddle around till the sun goes down.
Brian
Re: Hot track hints? [Re: '72CudaRacer] #769782
08/10/10 01:34 PM
08/10/10 01:34 PM
Longview, Texas
marvo451 Offline OP
marvo451  Offline OP
Longview, Texas
BTT.......with the wealth of knowledge here, I was hoping for a little more input.
Re: Hot track hints? [Re: marvo451] #769783
08/10/10 01:46 PM
08/10/10 01:46 PM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
If you just want to do shock/tire adjustments then try going full soft on your extension. On a ladder bar car it extends the shock first and then transfers. If the shock is full soft on extension it will hit the tire harder. You will want to stiffen the compression up some when you do this to keep the rearend planted longer. You may also try playing with air pressure on your slicks. What psi are you running now? Rear ballast also helps some. If you want to move your ladder bars then going up a hole will also hit the tire harder.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Hot track hints? [Re: marvo451] #769784
08/10/10 02:50 PM
08/10/10 02:50 PM
Back the motor down, timing, squirter, collector length, try differnt stall speeds so it doesn't flash as high and so on BTW, it ain't hard to slow them down, it is a lot harder to speed them up when they hook good Once you make enough power to spin the tires it is harder to back them down Do you have a set of drill front shocks
Re: Hot track hints? [Re: Cab_Burge] #769785
08/10/10 05:48 PM
08/10/10 05:48 PM
Longview, Texas
marvo451 Offline OP
marvo451  Offline OP
Longview, Texas
Strange adjustable front shocks and QA1 single adjustable rear shocks. Tire pressure 10.5-11.0. Ladder bars are in the next to highest hole. The car has 2 boat batteries in the trunk(140 lbs.)
Re: Hot track hints? [Re: marvo451] #769786
08/10/10 06:07 PM
08/10/10 06:07 PM
NC
440Jim Offline
440Jim  Offline
NC
My car is pretty good under most conditions, but when the air is over 90F, and the sun is shining on the track (afternoon vs night race), then I have problems too.
This past Saturday we had another afternoon session, so I threw a bunch at it. I was able to fix the hook, even though the car was slow. I ran 3 passes from 2pm to 5:30pm with sixty foot times within 0.001 (no spin) and at 5pm they announced the track temperature was 138F.
  • Front suspension travel limiters (bump stop spacers): Normally 0.375", changed to 0" to maximize front end travel and weight transfer.
  • Reduced rear tire pressure 0.5 psi
  • Added 26 pounds with steel trunk lid instead of fiberglass
  • Added another 20 pounds ballast in back
  • Minimum burn out (but I don't do much normally anyway)
I always have my front shocks fully loose in extension damping. That is what is needed to get my front heavy chassis to work.
I don't like track temperatures over 120F...
Re: Hot track hints? [Re: 440Jim] #769787
08/10/10 06:59 PM
08/10/10 06:59 PM
Longview, Texas
marvo451 Offline OP
marvo451  Offline OP
Longview, Texas
I guess this is going to sound prety stupid, but here goes........are the single adjustable shockss I have in the rear causing a lot of my problems?
Re: Hot track hints? [Re: marvo451] #769788
08/10/10 09:08 PM
08/10/10 09:08 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Funny you guys mention shorter burnouts. I might try that. I had been doing harder burnout on the greasy track as I though you wanted the tires hotter.
track temp + X = best hook.
This must have been bad advice.
Re: Hot track hints? [Re: Leon441] #769789
08/10/10 09:19 PM
08/10/10 09:19 PM
NC
440Jim Offline
440Jim  Offline
NC
Leon,
I don't know for sure, but that is what I do and have been sucessful with. Like I said, I don't do a big burn out normally; except after weeks of not running and the first burn out of the day gets more smoke.
I agree that on cooler tracks, more heat in the tire is good. But on tracks over 120F, it seems too much burnout just makes the tires worse.
Re: Hot track hints? [Re: 440Jim] #769790
08/10/10 09:36 PM
08/10/10 09:36 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Great post!
I'm going to try a few of these ideas when the valiant gets back out.
Re: Hot track hints? [Re: marvo451] #769791
08/10/10 10:03 PM
08/10/10 10:03 PM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
With that sized tire that seems like a lot of tire pressure to me. I am running 33*15 M/T stiff sidewall tires on my Dart Sport and was running 7.5lbs this past weekend on the worst track in DFW for bracket racing lately. It was still spinning a little bit and I don't have a lot of time tuning the chassis in this car because it is mainly my backup but it ran within .010 in the 60' all day. 1.390 was the worst and 1.380 was the best. Maybe Hoosier can tell you what psi they recommend for those tires.
14x Track Champ
Re: Hot track hints? [Re: Jacob Pitt] #769792
08/11/10 01:02 PM
08/11/10 01:02 PM
Longview, Texas
marvo451 Offline OP
marvo451  Offline OP
Longview, Texas
Thanks, I'll check with Hoosier. This is the first set of stiff walls I've ever used. Might have to shell out some $$$ and replace the shocks with double adjustable.
Re: Hot track hints? [Re: marvo451] #769793
08/11/10 01:18 PM
08/11/10 01:18 PM
PA
moparacer Offline
moparacer  Offline
PA
I gave up trying everything in the book so I gave up and put weight in the trunk....
150lbs fixed mine right up last race.
Worst track conditions I have ever seen this summer.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Hot track hints? [Re: moparacer] #769794
08/13/10 11:28 PM
08/13/10 11:28 PM
Longview, Texas
marvo451 Offline OP
marvo451  Offline OP
Longview, Texas
Any input from the weekend crowd?
