Hard starts advice...? #767997
08/07/10 08:27 PM
08/07/10 08:27 PM
US
Jay68RR Offline OP
Jay68RR  Offline OP
US
'68 RR, 383, MSD Ignition, TTI Headers, stock intake.
The car can sit for weeks and start like a champ with a few pumps of the gas peddle before starting. However, I can't seem to figure out how to start it cleanly after going somewhere and the car sitting for a bit. For example, I went to a car show last week and it sat for 1.5 hours. When I tried starting it to go home I had trouble. If it sits for just 20 minutes I don't have to pump it at all.
What is the general rule of thumb here?
'68 Road Runner, 383 Torqueflight, 3.73 Sure Grip, TTI headers, MSD
Re: Hard starts advice...? [Re: Jay68RR] #767998
08/07/10 08:32 PM
08/07/10 08:32 PM
pull the coil wire out of the dist & hold it 1/4" from a metal ground while someone turns the key & see if you have spark for starters
Re: Hard starts advice...? [Re: RapidRobert] #767999
08/07/10 09:07 PM
08/07/10 09:07 PM
Corona CA
wyotech_cuda440 Offline
Corona CA
My cuda fires on the first crank when it's cold, once it's warm it can be a pain to start. The trick for mine when it's warm is to hold WOT, if I do that, it starts right up with a nice rev and always catches some attention, just let off the gas quick so you dont look like an idiot hitting 6k
Re: Hard starts advice...? [Re: wyotech_cuda440] #768000
08/07/10 09:21 PM
08/07/10 09:21 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Timing to far advanced?
Can cause hard starts when warmed up.
Re: Hard starts advice...? [Re: Jay68RR] #768001
08/07/10 09:34 PM
08/07/10 09:34 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Hot start problems these days can be caused many times by our fine easy boil fuel.
Re: Hard starts advice...? [Re: bboogieart] #768002
08/07/10 09:49 PM
08/07/10 09:49 PM
US
Jay68RR Offline OP
Jay68RR  Offline OP
US
I'm pretty sure the spark is fine and 2 years ago the timing was advanced to increase power a little (got 10 hp and tq from doing that).
Thanks, guys. I'll try the WOT suggestion without looking stupid. Hilarious!
Re: Hard starts advice...? [Re: Jay68RR] #768003
08/07/10 10:18 PM
08/07/10 10:18 PM
hooziewhatsit Offline
Today's lovely fuel evaporates and fills the area under the air cleaner. Needs a few cranks to get some clean air in before it'll go bang.
