Re: 440 bracket motor
[Re: SealockRacing]
#763387
08/02/10 12:46 PM
08/02/10 12:46 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
whats up guys
ive been asking about some suggestions recently, and i think ive come up with my combo.
im thinking the speedpro 2355F pistons(TRW # i think) six pack rods with arp bolts main studs head studs a set of 906's(ported, milled, good valve springs, and a fresh valve job) old school weiand intake 850dp holley and my mopar 528 solid cam
im thinking my compression ratio with those pistons would be around 10:1 maybe a little more
and im guessing it would put me into the low 11's
what do you guys think?
Those pistons at zero deck with a 79-80 cc chamber will be right at 11:1. The extra point in CR is well worth the money to have the heads cc's and cut. You'll have to deck the block as part of the basic prep anyway, so it will cost no more to cut to the correct height.
Do you have all of these parts already? Reason I ask is -
1) Consider a Holley Street Dominator intake. Flows very well and makes real good power on a motor like yours.
2) Consider LY rods. Lighter than the 6-bbl rods.
3) Main and head studs are a waste of money at this power level. Futher you will HAVE to align hone the block if you want main studs. Should not need it with OEM type bolts.
4) Any flow numbers on the heads??
Had a similar short block, head and main BOLTS, ported 906 heads, roller cam, Dominator go several years of 10.40's @ 127, with no issues, what-so-ever.
Get QUALITY machine work done. Get a GOOD converter. For your combo I think the best value out there is a Dynamic 9.5...
If the tune up is right, the converter is right...low 11's should be cake. You'll be a cam swap away from the high 10's.
[Re: cudadoug]
#763388
08/03/10 12:48 PM
08/03/10 12:48 PM
Posts: 602 Alexandria, VA
SealockRacing
Alexandria, VA
okay, well heres the rundown, im 19, bringing home 400-700 a week depending on how much work we got(commision..) i pay half of me and my moms rent and i help with the bills also. i also drive 80+ miles roundtrip to and from work so i spend alot on gas a month even though i drive my civic lol. so to sum it up, im super low budget...
heres what i got to work with, ive got a 72 440 i tore down, from the stamp(j440t) its a motorhome motor. the parts i got are valve covers, the weiand intake, the holley carb, the 528mp cam, harland sharp rocker setup, headers, aluminum waterpump housing, milodon gear drive(missing the cam cover and bearing the cam rides on), and ive got a nice milodon oilpan that was in the car and the converter that was used to go 10.xx's in the car.
seeing that i cant afford all this machine work at this time in my life, im almost considering just getting rings and bearings and sticking the motor together with what i got, i figure i can have some fun in a 13 second bracket car.
my dads car this is going in already has everything, dana 60, msd 7al, 727 i had freshened up(reverse man. valvebody), its got the good driveshaft that i had redone, its got wilwood discs in the front, 10in drums in the rear, manual steering, etc. the car used to run 10.xx's back in the day, and im just looking to get it up and running... im tired of watching racing from the fence.
so option 1 is to get rings, bearings, gaskets, for the the 440 i have, ball hone it, and stick it together with my dads buddies iron heads that have been done up, and id be running the 528 cam i have, along with all of the parts i have to go on it.
or
option 2, ball hone my block, get the standard size L2355F's, a set of rings, bearings, and gaskets, and put the motor together that way, and hope it stays together.
what would you guys do?
i just really want to get the car up and running, even if its slow, and run it at the mopar show at MIR in october, thats my goal, i wanted to last year, but after losing my dad, i just couldnt make it happen...
i need your oppions guys!
thanks for any help!
John Sealock
[Re: SealockRacing]
#763390
08/03/10 01:17 PM
08/03/10 01:17 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
I'll give my opinion, I would save up for the stock sized forged pistons,and put it together with what you have.You can get by with not having a lot of machine work,is it ideal? No,but it will work.The reason I think you need the forged pistons is,depending on the gear ratio/tire size,and the weight of the car,it might accelerate faster than you think. If the r.p.m's are there,the cast pistons won't last long,and then you will have to start all over. Good luck
[Re: Dunnuck Racing]
#763392
08/03/10 01:28 PM
08/03/10 01:28 PM
SealockRacing
Alexandria, VA
thanks guys for the quick responses!
yeah, the last year has been really hard, and seeing that thursday was one year, made it even harder...
i know hes up there watching over us, with my grandfathers!
the car has a 5.33 gear in it, its setup for 1/8th, i didnt think of that when posting, but he ran the 1/4 with that gear.
im leaning towards getting the forged speedpros and just ball honing it and sticking it all together. with those pistons i think id be around 10-10.5:1, somewheres in there.
also, the car weighs probably over 3300lb's, what do you guys think this combo would get me down the track at?
thanks
John
[Re: The Cuda Guy]
#763395
08/03/10 03:29 PM
08/03/10 03:29 PM
SealockRacing
Alexandria, VA
yeah, the motor i ended up with is a 72 motor home motor, its got a forged crank, and 6pack rods. only problem is the pistons, they sit like 1/4" in the hole, and according to google, its like 8.2:1 comp haha.
so yes i did lol
also, do you guys know if aircraft stripper will take the paint off of the block? i want to paint er' all up nice like i have done the rest of the car so far, and i gotta get the old crap off first!
[Re: SealockRacing]
#763396
08/03/10 10:46 PM
08/03/10 10:46 PM
cudadoug
I'm on the fence as to the pistons. While the forged is stronger, it's also heavier meaning a re-balance. I'd be tempted to save the $300 on pistons (If the OEM ones are in GOOD shape) and do $300 worth of machine work instead...food for thought.
Okay, so you're (bucks) down and dirty. Save the aircraft stripper deal. Take some oven cleaner and a wire brush to the car wash and go at it. That will get the block cleaner than you think it would.
Make sure you knock the freeze plugs out first. New brass one would be good...add a dab of JB Weld to the perimeter as cheap insurance against one popping out.
Ball hone it and wash it again in HOT soapy water and blow it dry. Go ahead and assemble it with what you have, replacement rings and all. I would use a full grove bearing. Use a steel shim (.017 I think) head gasket and bolt it all together (reusing the stock main and head bolts).
Have the rods been resized? If not, that will be needed with the new bolts.
Get a new oil pump, (standard volume is fine) and a new timing set. The gear drive will need just as much $$ spent on the missing parts AND will eat up HP. Like the main and head studs, it's simply not needed. Plus the timing chain will be a breeze to install!
It SHOULD go low 12's - high 11's as is. BUT, with that much gear it's going to be "done" well before the finish line. Besides I wouldn't want to take it over 6,000 with the stock parts. Hopefully the crank is within spec, (even if on the high side of the tolerence) but be prepared to have it ground 10-10 or whatever it's going to take to get it fixed. The good news is a crank turn is pretty cheap.
It will probably have too much converter and labor real bad in high gear...not having enough steam to use all of that converter.
If you're going to have to keep the gear and run the converter you have, I would strongly suggest keeping it on the 1/8 mile...will prolong the life of the motor and be SAFER with so many stock parts.
On another note, I am very sorry about your loss...but it appears that your folks raised a GREAT son. Your Dad (and I bet your Mom) is VERY PROUD of you!!
If I can be of any help, please feel free to PM me. I've built several bucks down deals (Wait, I'm STILL bucks down...LOL!) That have ran (and lasted) pretty good.
[Re: Thumperdart]
#763401
08/04/10 09:58 AM
08/04/10 09:58 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
John, Put it together (option 1) and go have fun racing. It’s hard losing a parent at any age, but 18 is even harder. Your dad would be proud of the way you’re helping your mother and keeping his legacy alive. Best of luck to you!
x2, It`s great to see the younger generation diggin into the old iron and I really respect the fact that you`re helpin keep the castle alive. Sorry about your loss and no matter what you build your dad would be proud and you can honestly say you did the work yourself.
I agree with their sentiments. The only place I would differ is if you can get it bored an d honed with plates to fit new pistons. This will add much life to the shortblock, paying for itself more than once. The other thing is run an aircleaner, even at the track. Keep in touch with us as you put this together, so we can help you avoid problems. Stuff like scuffing lifter bottoms with 1000 grit paper to make them live, proper break in lube, assembly tips. We will be glad to help you in any way we can. Good luck and God bless.
[Re: The Cuda Guy]
#763404
08/04/10 03:53 PM
08/04/10 03:53 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
I think he is looking at bare bones options eg. he already has the 6pk rods.
If I was on a tight budget and in your shoes here is what I would do:
- New 9.5 - 10.0 comp Forged Pistons (cheapest ones, maybe used?) - Ball Hone - New Rings and Bearings - New Oil Pump - ARP Rod & Head Bolts - Main Studs - Sell the cam you have and buy a new larger cam - Do you have headers???
Keep in mind you may want to keep it on the simple side as your income isnt going to be able to support a robust plan at this time. Also keep in mind that there is always something that comes up along the way that you were not expecting that will throw off your budget.
Put it togeather and go racing!
Don
I like this advice, except main studs and ARP head bolts are a waste of money for this combo. Also, he already has the 528 cam, why not use it? It'll make plenty of power for him to have fun with.
ARP rod bolts are a good idea, just make sure you get the rods resized with them.
What Weiand intake do you have for this motor?
[Re: an8sec70cuda]
#763405
08/04/10 05:42 PM
08/04/10 05:42 PM
SealockRacing
Alexandria, VA
yeah i have headers and as far as what intake, best way i can describe it is as an old school wiand, that looks similar to a M1 intake...
when i have those speedpro pistons pressed on the rods at the machine shop, i was going to have the rods done with the arp bolts, just the way i did my honda... im also going to just ball hone it and go with it.
i can also get the crank checked out for free, i figure if its free, it wont be a bad option.
and even though i dont necessarily need the main studs, and arp head studs(id want to use studs over bolts anyways) i feel that they would be money well spent, i know i wont NEED them, but they cant hurt, and it would be a nice peace of mind type thing for me.
also, my dads old buddy who was my old boss has a 670 avenger i believe carb he gave me, im sure his offer still stands since im sure the 850 would probably be too much carb for this combo.
and im sure you guys wont like it, but the 528 cam i have is used... and i was going to just get a set of lifters and a new set of pushrods and just stick it all together
also, a new melling hv oilpump is on my list
i also hate to say it, but this is getting pushed back even further seeing that i had to pay 1200 rent today since my mom didnt have it... soooo, another few checks maybe i can get my parts ordered up!
thanks for all the help so far, and you guys that wanted me to pm yall, ill have to find time at work, since my laptop at home took a dump lol.
thanks guys!
John Sealock
