Race car front end rebuild: Rubber or Poly?? #760567
07/29/10 02:06 AM
07/29/10 02:06 AM
Between a rock & a hard place
cudadoug Offline OP
cudadoug  Offline OP
Title says it all: Rubber or Poly?? I did my old Cuda in rubber and that dude was STIFF! Had to loosen all four shocks after to get to "leave".
What have you all used and how did it work?
Thanks in advance...
Re: Race car front end rebuild: Rubber or Poly?? [Re: cudadoug] #760568
07/29/10 02:25 AM
07/29/10 02:25 AM
NW Indiana USA
727specialist Online content
727specialist  Online Content
NW Indiana USA
When I got my shocks from calvert they said they use rubber.
Re: Race car front end rebuild: Rubber or Poly?? [Re: cudadoug] #760569
07/29/10 05:47 AM
07/29/10 05:47 AM
Texas
Steve Reynolds Offline
Texas
Mancini told me to use rubber on drag car & poly on anything else.
Steve
Re: Race car front end rebuild: Rubber or Poly?? [Re: cudadoug] #760570
07/29/10 07:01 AM
07/29/10 07:01 AM
MR_P_BODY Offline
MR_P_BODY  Offline
From what I see now is there are 2 different styles
of poly bushings... one the poly is pressed into the
sleeves(very low movement) and the second style is the
poly slips into the sleeves where the poly will rotate
(free movement) so look what you are buying
Re: Race car front end rebuild: Rubber or Poly?? [Re: cudadoug] #760571
07/29/10 07:12 AM
07/29/10 07:12 AM
Georgia
moparjimbo60 Offline
Georgia
bought the poly for my demon was so tight it wouldnt transfer weight, 60 ft was all over the place spun sometimes and not others. replaced them with tubular control arms with hiem joints, car settled down and got deadly consistant.
Re: Race car front end rebuild: Rubber or Poly?? [Re: cudadoug] #760572
07/29/10 07:20 AM
07/29/10 07:20 AM
Mountains of NM
65superstock Offline
Mountains of NM
Poly here and I am happy with it.
-Jason
Re: Race car front end rebuild: Rubber or Poly?? [Re: 65superstock] #760573
07/29/10 08:11 AM
07/29/10 08:11 AM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
Personaly, I love poly.......Here are a couple good threads on the subject;
This one............... and this one......................
If you can't handle the truth, you're living a lie.......
Re: Race car front end rebuild: Rubber or Poly?? [Re: cudadoug] #760574
07/29/10 10:32 AM
07/29/10 10:32 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Poly here...........Car`s consistant driver, not so much.
Re: Race car front end rebuild: Rubber or Poly?? [Re: moparjimbo60] #760575
07/29/10 06:46 PM
07/29/10 06:46 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Had the same issue with my Duster....I took it all apart again and put a light hone on the inside of the bushings....problem solved
5.53 @ 125 1/8th on the launch control..more left in her!
