Re: who is the six pack king
[Re: Mopar Mitch]
#759075
06/19/13 01:33 PM
06/19/13 01:33 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Thanks for the extra info.
Last night I worked with a Mopar friend/racer (Greg Bosak) and we got it running, some cracking of exhaust sounds, but still idles too rough. timing is 34 total, 12 btdc w/o vacuum hookup. Vacuum is 13, so the 65 PV should be OK (??). We pulled the plugs and saw they are fouled (64 jets); will put 62 jets in and new plugs/cap/rotor tonight. I do have another 340 center carb (4292) which I may rebuild and see if that makes any differe
I've got to get it running near perfect as I'm the Pace Car for Elkhart Lk. Road America this wknd!!!. IF the carbs/plugs/cap/rotor doesn't make any difference, I'll have to put back my LD340/Carter 625 Comp Series setup Thursday night/Friday... have to leave early Sat monrng.
Mitch cell 847-682-0807
If it doesn't run 10x better w/ the six-pack you got something REALLY wrong. It's not hard to tune. My unit is right out of the box. I don't have billet this or Pro-Max that. If you can tune one holley you can tune 3. For this build I upped the squirtter (35) jets and went with purple springs. Best way to tell if your outborads are opening is to drive it nice and easy up to about 20mph and stomp it, your tires should explode...well w/ a 340 at least chirp Tune the primary like you would any other carb, nake sure you linkage is set and opens all the way, time it and roll.
[Re: Mr.Yuck]
#759076
06/20/13 12:30 PM
06/20/13 12:30 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Although its been a couple years since my last posts on this subject, I eventually got the six-pack running very well... vacumm, idle, floats, timing... repeatedly checked and tuned (took about 2 hours).. runs awesome! I do have the entire Promax setup (center metering block, f/r plates, and rear adjustable base plate. I'll give credit to my couple friends (Greg Bosak, and later David Jahns-SCCA Pro TransAm road racer).
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: mattpar]
#759079
12/02/13 01:46 PM
12/02/13 01:46 PM
Posts: 43,386 Bend,OR USA
Cab_Burge
One sure way of telling if the outbard carbs are opening or not is to disconnect the vacume hose from the center carb tha goes to the outboard carbs and go drive the car, if it loses a bunch ofpower from when hook up there working. If there is no change there not opening, make sure the hose to the outboards is hook up to the vacume nipple on the carb and not on the metering block ![](/ubbthreads/images/graemlins/scope.gif) Please let us know what you find out ![](/ubbthreads/images/graemlins/thumbs.gif) Good luck ![](/ubbthreads/images/graemlins/thumbs.gif)
