Page 2 of 3 1 2 3
Re: Changing oil on your daily-driver ... ?? [Re: MoparforLife] #757924
07/26/10 06:01 PM
07/26/10 06:01 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I had a 1980 ford F-350 with a 351 V8 on Propane since it was new.
I only changed the oil on that thing about ever 25K miles. We drove it to 380K miles and sold it. It's still in the neighborhood, I see it sometimes. I have had other vehicles on propane gas boy do they run clean.
The ford I talked about above made it to about 375K miles before it broke a valve spring. I took the valve cover off for the first time and stuck a chevy valve spring in there, it's still running today. The top of the head was spotless after 375k MILES WITH 25k OIL CHANGES ON lp GAS.
Re: Changing oil on your daily-driver ... ?? [Re: Challenger 1] #757925
07/26/10 07:46 PM
07/26/10 07:46 PM
Florida STAYcation
dOc ! Offline OP
The village idiot's idiot
dOc !  Offline OP
Florida STAYcation
LOTS depends on how "sweet" the motor is ...and how much compression it has.
SWEET ? ... how sealed-up-tight it is. I must have a sweetie-pie 4 banger. The last oil I dumped was over 4k miles ...and it had barely changed color. That just-over 9k mile change ... it STILL looked good .. but it was nearing winter-time and I put in a load 5-30.
Re: Changing oil on your daily-driver ... ?? [Re: MoparforLife] #757926
07/26/10 08:01 PM
07/26/10 08:01 PM
It is funny that people really think that just because they use synthetic oil that they can extend their oil change frequency. The oil whether Dino or synthetic collect the same contaminants and it the contaminants that do the damage not the oil wearing out.
The chrysler owners manual suggests the same oil change schedule either way.
Oh well to each their own. Like I said oil is cheap maintenance so I will continue with my frequent changes.
So you're saying that synthetics "break down" at the same interval that dino juice oils do?
Re: Changing oil on your daily-driver ... ?? #757927
07/26/10 08:11 PM
07/26/10 08:11 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I change mine every 3 months and it's usually pretty black looking by then. I rarely get on the freeway, and most of my trips are in the 30-40 minute range.
Re: Changing oil on your daily-driver ... ?? #757928
07/26/10 09:13 PM
07/26/10 09:13 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
No what I am saying is that they collects the same dirt and crud as dino oil and will do the same damage in the same amount of time. Even Mopar recommends the same oil change intervals using it.
In the same breath I wouldn't use a sythetic but that is up to you.
Re: Changing oil on your daily-driver ... ?? [Re: MoparforLife] #757929
07/26/10 09:49 PM
07/26/10 09:49 PM
ne
broncobra Offline
broncobra  Offline
ne
When I bought my Buick GN new, I'd use Mobil 1 and a new filter every 2000 miles. I drove it really hard like it was meant to be driven and always try to let the turbo cool down, but still the 2000 mile change. The trans went out at 100,000 miles but never had any problem with the motor. Wish I still had it. Wish a total Mobil 1 and filter change was still $25. That seemed really high back then. HaHa.
Re: Changing oil on your daily-driver ... ?? [Re: dOc !] #757930
07/26/10 10:06 PM
07/26/10 10:06 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Have dak w/4.7 and a 3.2 intrepid. Neither are users, have over 100k miles and get changed every 3 or 4 months or 3500 mi.
Re: Changing oil on your daily-driver ... ?? [Re: Baxter61] #757931
07/26/10 10:07 PM
07/26/10 10:07 PM
NY NY
3
340duster340 Offline
NY NY
My neon burns enough oil that it gets a fresh quart every 1500 or so so I dont feel the need to change the oil anymore; it changes itself.
good to know i am not the only one!
i have to add a quart or 2 a week to my chevy beater pick up.
it smokes like a fog machine at a kiss concert, but wont die.
1966 Dart GT ...down to only 1 mopar for the first time in 15 years!
Re: Changing oil on your daily-driver ... ?? [Re: 340duster340] #757932
07/26/10 11:25 PM
07/26/10 11:25 PM
Colorado Springs, Colorado
Dartthunder340 Offline
Ha,ha! smokes like a fog machine at a kiss concert! Too funny. I change oil every other month. 120 miles per day. '99 Dakota R/T.
Better get inside Ma. Looks like a storm's comin'.
Re: Changing oil on your daily-driver ... ?? [Re: dOc !] #757933
07/27/10 07:09 AM
07/27/10 07:09 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
WHAT determines WHEN you change it ? ... I do the eyeball, smell and feel-test more than actual mileage.
Go to this YouTube video and fast forward to 1min, 10sec. into the film - http://www.youtube.com/watch?v=BB7PL5MHicU
Case in point, the color of motor oil doesn't determine it's useful life.
It's equally funny how people think oil filters are created equal just like motor oil. If you want to run an extended life synthetic motor oil, you probably should step up to an extended life oil filter.
Look, I've been driving the point here for a while. The key to determining oil change intervals is with Used Oil Analysis.
I've been doing Used Oil Analysis on my daily driver and can back up what I'm talking about with laboratory analysis.
For example, I went 10-months/7,500-miles on an extended life synthetic motor oil and appropriate oil filter. I then changed the oil and filter, caught a used oil sample and sent it off to an ISO accredited lab for analysis. I even went one step further and paid extra for an ISO particle count to see the larger contaminate particles suspended in the oil. The report I got back stated that the oil was still suitable for use and to re-test after another 3,500-miles or 65-hours. Too bad the oil was already dumped and at the recyclers at that point; money down the drain.
So you have people changing their oil based on color, feel, smell, opinion, but not on the reality of modern oils, filters, and mechanics.
Re: Changing oil on your daily-driver ... ?? [Re: CompSyn] #757934
07/27/10 07:20 AM
07/27/10 07:20 AM
Cincinnati, Ohio
Cincinnati, Ohio
I used to send my oil out to be tested about 20 years ago, it always came back usable. I really didn't learn much other than the oil was still good and I was wasting money on oil testing. I guess that's why I run the miles that I do on motor oil.
I own a oil company, you would think I'd be preaching 3000 mile oil changes. lol
BTW as soon as I dump new oil in a diesel crankcase and start the motor, it turns black. You can't tell anything by looking at it.IMO
Re: Changing oil on your daily-driver ... ?? [Re: Challenger 1] #757935
07/27/10 08:00 AM
07/27/10 08:00 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Every 9 months on all three. Less than 7,000 miles a year COMBINED. Amsoil/Napa Gold.
09 Challenger 0-20
06 Daytona 5-20 (MDS)
69 Coronet R/T 10-40
Ride the Train to work and save the weekends for tire smoke.
Re: Changing oil on your daily-driver ... ?? [Re: dOc !] #757936
07/27/10 08:01 AM
07/27/10 08:01 AM
Slidell, La.
doctor_mopar Offline
Slidell, La.
I go different periods of time and mileage depending on the vehicle and how it is driven. I run Mobil one in my 350 Tuned Port engine in my daily driver El Camino. It sees 60 miles a day, mostly highway, and is still pretty clean when I change it between 7500 and 10,000 miles, and does not use any oil. The original 305 went 280,000 miles without the benefit of synthetic oil for the first 180,000 miles ! When I pulled it apart, it was clean with no visible wear.
My Barracuda with 360 six pack , Mobil One oil, gets alot more contamination in the oil, and gets changed every year. It sees little mileage usually , but sees too many warm ups.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: Changing oil on your daily-driver ... ?? [Re: Challenger 1] #757937
07/27/10 05:43 PM
07/27/10 05:43 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Used Oil Analysis was worth it for me. What I learned from it was that my oil was averaging 2-to-3% fuel dilution which prompted me to get caught up on some maintenance items.
I had my fuel injectors professionally flow tested and cleaned and I replaced my PCV valve.
Although I haven't retested my oil since those changes, my car idles better and has improved low end torque. And since excessive fuel in the oil degrades it more rapidly, I'm hoping for an even better Used Oil Analysis report next run.
Now had I continued the rut I was in by changing my oil every 3-months regardless of mileage, I probably wouldn't have been so proactive about targeting the aforementioned maintenance items the oil analysis promoted me to do.
Also, the money I saved by changing my oil less paid for the Used Oil Analysis.
Back to the issue of fuel dilution. It's a known fact that PAO synthetics take a beating to fuel dilution better than conventional oils.
For example:
Re: Changing oil on your daily-driver ... ?? [Re: CompSyn] #757938
07/27/10 05:55 PM
07/27/10 05:55 PM
Canada
RobR Offline
RobR  Offline
Canada
Every 3000 km for my everyday driver...
Re: Changing oil on your daily-driver ... ?? [Re: RobR] #757939
07/27/10 06:13 PM
07/27/10 06:13 PM
Wilmington, NC
donbarnes Offline
Not THAT Don Barnes!!
donbarnes  Offline
Wilmington, NC
Oil change every 3,500 miles on our 3 daily drivers. On the boat, motorcycle, and Mopar when it changes color on the stick and I can't see through the oil anymore- Regardless of whether that's 500 miles, a thousand, 6 months or 2 years..
Re: Changing oil on your daily-driver ... ?? [Re: Dartthunder340] #757940
07/27/10 06:20 PM
07/27/10 06:20 PM
california u.s.
dodge41969 Offline
dodge41969  Offline
california u.s.
Wow!, I thought I was the only one with a crazy commute, I drive 115 miles a day, and I use:10w30
Mobil 1 synthetic, every 10,000 miles (all freeway miles) 65+M.P.H. all the way, '97 Ford Crown Victoria (cop car) 4.6 V8,25 M.P.G.,
the last Crown Vic. I had went 420,000 miles and still ran great,the tranny was toast though!
Re: Changing oil on your daily-driver ... ?? [Re: dOc !] #757941
07/27/10 06:23 PM
07/27/10 06:23 PM
P
Pauls69 Offline
super gas
Pauls69  Offline
super gas
P
change mine every 4 months (Dec/April/Aug). the every 5K is a good idea too (easy way to remember), but i like to change mine a little more frequently. just use wallymart's supertech oil & filters & have never had a problem. someone told me it was just rebranded penzoil, but i'm not sure if that's true.
on a sidenote, no one i know changes their own oil anymore. they've all farmed it out to the quickie lube spots.
Re: Changing oil on your daily-driver ... ?? [Re: Pauls69] #757942
07/27/10 06:28 PM
07/27/10 06:28 PM
Florida STAYcation
dOc ! Offline OP
dOc !  Offline OP
Florida STAYcation
Well ....knock me over with a feather .... ole C S is here !!!
Come on now ...the eye-ball "test" can sure give you the quick basics
Re: Changing oil on your daily-driver ... ?? [Re: Pauls69] #757943
07/27/10 06:32 PM
07/27/10 06:32 PM
Under My Car
Mopar_Country Offline
Under My Car
Every 10,000. I have 1 Dodge truck with over 200,000, 1 Dodge van pushing 200,000 and an 03 Dodge truck with 130,000, never an issue.
Page 2 of 3 1 2 3
